Question about ECHO, Inc. PB-251C Handheld Blower
My Echo pb251 is only 3 months old. After about a month of perfect running, one day it would not run above idle. You have to partially choke it to get any speed out of it. It's like the high speed jet is clogged? I took the carborator off and tried to remove the jets but they are not removable? Spayed carberator cleaner in just for the heck of it and put it back togeather, runs the same. Please advise as soon as possible. Thank you
Check your exhaust (muffler), it has 4 or 5 small exit holes, the new gasket between the exhaust port and "muffler" has been known to come apart and plug the exhaust holes which will keep your engine from running much above idle, it can't exit the air/fuel because of the blockage and that will let it run barely above idle, its probably hard to start too.
Posted on Jul 27, 2010
1986 Honda VF 1100 C only run with choke on
Hi, Mark and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
1986 Honda Magna 700 won idle off choke
V65 Magna Starts Runs Stalls
Honda 83 86 V65 Official Shop Manual pdf
http://www.partsfish.com/page/oem-parts-for-honda
http://mybikemanuals.com/honda/honda-vf-owners-manuals
Aug 29, 2017 | 1986 Honda VF 1100 C
2007 Honda shadow spirit 1100. Has set up for 6 months and will fire but will not idle without choke on full.
Failure to idle (or even start/ run) without the choke is indicative of dirty carb(s), partially clogged slow jet. Leaving a bike to sit with un-stabilized fuel is inviting problems, ethanol is the culprit.
Nov 23, 2014 | Honda Motorcycles
Only runs with choke on
Sounds like some of the TINY passages [called "galleries"] inside the carburetor have become clogged or partially clogged with fuel residue called "gum" or "varnish."
Go to your local auto parts store and describe the problem to them, and ask for a solvent "kit" to unclog the carb.
There are a couple of brands, but generally they require that you empty the "old" stale fuel from the tank, add their solvent, crank the engine a few times to get the cleaner into the carb, allow to stand for a few days, add fresh gas and start.
Jul 03, 2014 | Echo HC 152 Hedge Trimmer - 20"""
2004 Vstar 1100 idles too fast when hot. It sat for a while and when I first started riding it consistantly I would have to keep partial choke on to maintain idle. Recently it started idling too fast when...
2004 V Star 1100 Custom, It has been sitting for several months, Bike starts and runs, It just Idles out of control when it is warmed up. ??? Any Sugestions ??
Oct 16, 2011 | 2004 Yamaha V Star 1100 Custom
I have an Echo PB-500T blower that won't throttle up. I bought this blower new about 3 months ago. Before this blower I had an exact same blower that gave me the same problem. I returned that blower...
Remove the in tank fuel filter and take it apart, the felt Echo uses on the filter clogs quickly. There is still a mesh screen filter in the assembly so make sure you put it all back together and reinstall the fuel filter into the tank.
Oct 02, 2011 | ECHO, Inc. PB-251C Handheld Blower
I have an echo pb-250 blower. This is the second blower ive had issues with. I have had it for maybe three months and this is the second time that ive experienced this problem. I can easily start it but...
what you need to do is remove the white plastic plug just above the diaphram gskt in the base of the carb use a pick or drill bit (but only turn it by hand) till you get it out then you will see a screw which will take a small flat blade screwdriver, start and warm up the blower then turn that screw counterclockwise till your Blower runs right on full throttle. the new equipment made now a days is set so lean for emissions that one change in the weather will affect how they run..... 2StrokeJim
Jun 08, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
It won't run prorerly
I had the same problem. I took it to the dumpster and used my old echo that I purchased in 1986. The Homelite was 2 years old. My sugesstion is to dump it.
Apr 06, 2010 | Homelite Mighty Lite Lawn Trimmer
Echo CS-440 Chainsaw. Was cutting firewood, saw running fine until I refilled the gas tank. The gas was a few months old but looked clean and smelled OK. But after I filled the tank could not get the...
unleaded fuel is notorious for going stale,and it can leave a resinous coating in the carb-try running the saw on half choke with new gas and less oil eg 50 to 1 for say ten minutes,this should clear the gunk out-if this does not work,you have two choices-strip and clean the carb,or adjust the H (high) scew on the carb anti-clockwise by a quarter turn a time till it revs out full bore-good idea to remove the chain and wear ear defenders when adjusting-and always use a chainsaw at its max rpm,or you run the risk of "kickback"
Feb 25, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
ECHO 2000 WEED EATER I changed the fuel line,
You may need the carburetor adjusted or rebuilt. The other possible item is "bad gas". If the gas has been sitting around longer than 30 days, it may be time to mix up some fresh fuel mixture.
HTH
Good Day.
Oct 29, 2009 | Garden
Won't keep running except at 1/2 choke or a little above
ahter you start it up turn choke too off position
Feb 26, 2009 | Ryobi Backpack Blower 25.4cc
ECHO, Inc. PB-251C Handheld Blower Logo
799 people viewed this question
Top Echo Garden Experts
Jim Parker
Jim Parker
Jim London
Jim London
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
