Question about Mitsubishi WD-60735 Projection Television
I need to find a replacement lenticular screen for my mitsubishi 65" inch tv because it has a medium sized crack in it. Any ideas on where I can find one?
  • 58 Answers
Mitsubishi parts department will sell them directly to the consumer since it is not usually covered by warranty. Goodluck.
Posted on Jul 05, 2010
Find generic dlp lenticular screen and fresnel screen
I would find out the make of the lens, probably cannon. The Fresnel and Lenticular screens are nothing to do with the size of the picture, the lens does that bit.
Oct 01, 2017 | Televison & Video
Mitsubishi hdtv 1080 ws-a65 screen broke need replacement
there are 2 functionality screens and 1 screen protector (on some)
front screen = lenticular
back screen = fresnel
very front screen = screen protector (you can replace w plexiglass)
the fresnel and lenticular are very specific.. contact your local repair center for a new one. you can cut them from old screens but have to do just right (fresnel is a lens type - pic will be distorted if off center)
maybe find a old junker tv to pull screens from because new ones are about $100 a piece
Jun 03, 2010 | Mitsubishi WS-65311 65" Rear Projection...
After a move to a new home the screen broke. need
Howdy,
Yes, you can still get them from the Factory. I just checked and Mit's has all items in stock.
The SCREEN- LENTICULAR IS; 491P103030: $171.10. The LENS-FRENSEL IS; 491P104030: $212.80. The Diamond Shield IS; 760D639020: $77.90.
Dec 29, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi DLP 65 in half of screen is tinted yellow - 3 mth old
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD, DLP & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 26, 2017 | Mitsubishi WS-65857 65" Rear Projection...
Replacement lenticular screen for vs6041 60 inch mitsh
we recently cracked our lenticular screen on our 73 in mitsubishi i called the manufacturer and they said they no longer make them. so i looked thru websites to see if i could find some one with a 73 in tv or bigger that they were no longer using or didnt work and i found a guy on www.ksl.com that had an 80 inch tv and we went to go pick up screen cut it to my tv size and it worked!!.
Jun 24, 2008 | Televison & Video
65 inch Mitsubishi replacement screen? (WS-65311)
I think I can help you out if you still need that screen, I have a new screen, both fresnel and lenticular lens in a frame for a ws-65411. contact me at jgrisz@comcast.net
May 07, 2008 | Mitsubishi WS-65311 65" Rear Projection...
Need to replace a cracked screen
WD-57731 & WD-65731 Front Disassembly
57” & 65” Models Screen Frame
Removal
1) Pull off the Speaker Grill.
2) Remove all the screws (b) from the
upper rear cover (except one at an
upper corner to support the frame).
3) Remove 10 screws (a) from the
front of the screen frame.
4) Remove the remaining ***** (b)
(supporting the frame). Carefully
pull the Screen Frame from the TV
and disconnect the ES and LE
connectors.
57” & 65” Models Screens Removal from Frame
1) From the rear of the Screen Frame remove 20 screws (a) from the top and bottom rails
2) Remove 6 screws (b) from each side rail.
3) Carefully lift the Screen assembly from the Frame.
MODEL: WD-52631 / WD-57731 / WD-65731
Screen Replacement
CAUTION: Wear gloves when handling the Lenticular Screen and Fresnel Lens.
This prevents cuts and finger prints. Do not place Fresnel Lens in the sun.
This may cause fire and heat related injuries.
Lenticular Screen and Fresnel Lens Replacement
1) Apply LENS-TAPE along the rear top edge of the Lenticular Screen.
2) Place the Fresnel Lens on top of the Lenticular Screen, and apply pressure along the top edge.
3) Place the screens in the screen frame and reinstall the cushions, top, bottom and side rails.
NOTE: The Lenticular Screen label must face the front and the Fresnel Lens label face the rear.
4) Reverse the Screen Removal Procedure and insert the screens in the Bezel.
Lenticular Screen and Fresnel Lens Removal
1) Remove the top, bottom and side HOLDER-SCREEN rails and their cushions from the Screen Frame.
2) Lift the screens as a single unit from the frame.
2. Separate the Lenticular Screen and Fresnel Lens.
Note: When separating the Lenticular Screen from the Fresnel Lens, use caution
while prying the Screen and Lens apart. Use a slot type ***** driver, and
remove the pressure sensitive double sided tape.
Mar 11, 2008 | Mitsubishi WD-65731 65" HDTV
TV screen
You can try vancebaldwin or MCMelectronics
Dec 01, 2007 | Mitsubishi WS-65857 65" Rear Projection...
Toshiba 50A60 Lenticular cracked.
I don't have a particular source, but if you fail to find one you may try using a similar screen fopr a different model if you're a bit handy. Depending on how the screen is fastened, you might even be able to fit a regular canvas (roller curtain type or similar, user with video projectors)
If it has to ba some kind of specific frame on it you miahgt have to "hack" it, and it might not be that pretty. If it's just a screen fastened inside a frame, kind of like the glass in a picture frame you can get one in the same size, or a bit bigger and cut it down to size yourself.
Nov 26, 2007 | Toshiba 50A60 50" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
608 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
