Question about NewAir AC-12000E Portable Air Conditioner
Too noisy hard to watch tv or sleep
Any way to cut the noise level
  • 456 Answers
Raise the setpoint a couple of degrees, this will cut down on the noise of the compressor, put fan speed on low and that should cut down on blower noise.
Make sure you have some rubber pads underneath the unit and that should cutdown on vibration.
Posted on Jul 04, 2010
I have a Dutchman travel and the roof air is so
If you have the expertise or if you do not then you need someone with the necessary knowledge to open the unit up and while it is running look for the cause or find out he area of most noise/vibratin and fix it or post more information about it.
Sep 21, 2014 | Heating & Cooling
Why does my hard drive make grinding noise in sleep mode?
Hi Lou, that's a good question. In sleep mode there should be absolutly no noise at all as the machine is asleep. If there is a noise then it is not asleep. Also, the chances of a hard drive in a laptop making a grinding noise is pretty slim so it is probably not the HD - if it was you would be having trouble using the Mac. It could be a fan that is still running to cool the machine down. How long does the noise go on for after you put it to sleep?
Apr 09, 2012 | Computers & Internet
Hi. I have just connected my Bose Acoustimass 6 series III speakers. When I run a MCACC test, the display shows 'noisy' and there is no error message. If I run it again it stops and shows just noisy after...
Either your ambient noise level is too high for the test, or you need to increase the volume for the test tones.
For any such audio calibration testing your ambient noise level should be as quiet as possible, preferably below the measurable level of an SPL meter...usually 50dB for most models.
Dec 12, 2010 | Pioneer VSX-818V-K Receiver
Fan speed changes so slightly it's hardly noticable. Is this normal?
You haven't stated which exact model, but yes, on many electronic devices the cooling fan speed is automatically controlled according to need. Most current flat panel tv's (except for ultra budget, old technology "no name" designs) incorporate this feature.
This cuts fan noise, prolongs fan life, and uses a little less power. Just make sure that the ventilation slots on the tv are not choked with dust, and on models with removable gauze filters make sure that you clean them every month or every week if it's a dusty environment. Removable filters are more commonly fitted to LCD projectors, but I've seen a few flat panel tv's with them fitted as well.
If the fan becomes especially noisy or stops altogether (some designs do allow the fan to stop for short periods though) then you must get the tv serviced as a failed fan is cheap, but an overheated tv can be more expensive to repair. They all have thermal cut-outs which usually put the tv into "protection mode" if the tv overheats, but fault diagnosis is usually faster and cheaper if this can be avoided. Much better to avoid letting it overheat to begin with.
Relax and enjoy your tv :-)
Feb 05, 2010 | LG Televison & Video
We had a power cut and then turned T.V back on and it made a
check all the fuses u will find the prob, every board has at least one fuse.
Dec 07, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Noisy Fan on Copier CS-3035
actually fan really works even at sleep mode to exhaust heat, the problem is one of the three fan located at the left side if your facing the machine, is deffective a broken blade causes it to sound bad try to remove its connector, afer all you have two more working
Nov 01, 2008 | Copystar - CS-3035 Printer
Whirring noise. No other problems.
Sounds like you have a noisy color wheel. Very common on all Samsung DLP`s. The part # is BP96-00250A for model HLN5065W.
Oct 16, 2007 | Samsung HLN5065W 50" Rear Projection...
Toshiba 36A50 Noise Issue
your tv needs a tech the problem is in the IF circuit.good luck.
Apr 29, 2007 | Toshiba 36A50 36" TV
Sanyo DS32920 Blue Screen
My panasonic Tv pic suddenly turned into a blue color I can't see the pic any more just can hear the audio.....any solutions????
Mar 19, 2006 | Sanyo DS32920 32" TV
NewAir AC-12000E Portable Air Conditioner Logo
151 people viewed this question
Top NewAir Heating & Cooling Experts
Donni Steen
richie46
Tom Chichester
Are you a NewAir Heating and Cooling Expert? Answer questions, earn points and help others
