Question about Canon PowerShot SD750 / IXUS 75 Digital Camera
My camera got wet and now the built-in rechargeable lithium battery charge is low. what do i do?
4 Suggested Answers
SOURCE: SD600, the camera time resets everytime i turn it
There's a little battery in the camera under where the tripod mount is. Make sure your camera is out of warranty before attempting any repairs. Opening the case will void your warranty. Do this at your own risk.
1) Remove all six screws from the outside of the case.  2) You'll need to loosen the LCD panel, there are two little tabs holding the panel, and one screw up by the speaker (photo/movie/view) switch.  3) Remove the screw by the speaker, this will give you access under the LCD. Do not unhook the LCD cables.  4) Now under the LCD panel you should see a screw that connects the metal backplate with the tripod mount, remove that screw.  5) On the bottom, on the main motherboard, there's another screw holding the tripod mount in.  6) After removing the tripod mount, you should see a battery under the LCD cable.  7) On the main motherboard, gently (GENTLY) remove the large LCD cable and pull it through to the other side.  8) You should now see the battery pretty clearly.  9) Replace the battery. MS614X 10) Reverse the steps.
Posted on Mar 17, 2009
rajdeepdutta
  • 2517 Answers
SOURCE: when i turn on my camera with full recharge
Hi there if you use much this Camera last one year then its time to change the battery.If not then its a problem of your camera power transformer unit.
Posted on Dec 28, 2010
sharpkins
  • 5 Answers
SOURCE: My Canon powershot G9 rechargeable lithium battery build in
It sounds more like the camera has a short which is what would more commonly drain a battery. There's a common issue as you're describing on the G9 for this exact issue. Try this site: www.camerasandparts.com They only deal with service for the canon powershots and they are quite familiar with the problem you are experiencing. I'm sure they can help you with this problem.
Posted on Oct 25, 2011
Just purchased lithium batteries and indicator showing low battery
Are you sure you bought lithium cells? In your camera you should use Ni-MH batteries. The SNB-2512 could be very expensive, but normal Ni-MH from any brand should work fine.
Depending of what you use, always be sure all batteries are the same, charged and suited for your camera. Most of the time even new Ni-CD rechargeable batteries won't work, because the voltage is low, according to NiMH or alkaline batteries.
Always charge NiMH batteries before using them for the first time, or if they have not been used for a long period. 3 months is a very long period.
Always charge sets of batteries (2 or 4) together.
Do not use alkaline batteries unless it is absolutely necessary. In some cases, alkaline batteries may have a shorter service life than NiMH. Alkaline battery performance is limited, especially at low temperatures. The use of NiMH batteries is recommended.
Never use manganese (Zinc-Carbon) batteries in your camera.
Jan 09, 2014 | Samsung S860 Digital Cameras. 8-megapixel...
Toshiba PDR-3300 Digital Camera
Hi this is common problem if your sure that these batterys are new and you have used that make and type of battery before than the problem will be on the board of the camera itself.
If these batterys are ones you have not used in your camera before then the chances are these batterys are just not powerfull enough so you can by a recharge pack for your camera ok so let me know if its new batterys and if you have used this type before.
Also insted of using the lcd can you turn the screen of then try taking picture using normal view finder as you would on a none digital cam
It could just be that the batterys you brought are faulty and might be worth trying another set before giving up.
These camera usuall wont switch on with normal batterys so just try another set or if you have let me know.
If the battery says low bat then goes off then these batterys will not work if tryed again but if you can get camera on turn off the screen then try taking picture ok get back to me and let me know ok
Apr 06, 2008 | Toshiba PDR-3300 Digital Camera
18 v lithium-ion battery will not charge
The batteries were discharged too low. A lithium battery should be recharged as soon as you see a loss of power.
Jan 12, 2013 | Ryobi Two 18V Lithium-Ion Batteries +...
How many way to charge ?
You cannot charge the battery using the USB cable.
Here are the battery specs for this camers.
Power Battery Form Factor: Proprietary D-LI8 Usable Battery Types: Lithium Ion rechargeable Batteries Included: Proprietary D-LI8 Lithium-Ion rechargeable Battery Charger Included: Yes
Mar 11, 2012 | Pentax Optio S5i Digital Camera
Nimh batteries give low batt signal even when
the trouble with rechargable batteries is their voltage is low to start with even when charged. they only give 1.2 volts each instead of 1.5 volts from proper AA bateries. I use Energizer Lithiums in all my camers and they are great and last a long time. You can find cheap suppliers on eBay I use a site called 7dayshop.com in jersey (europe).
Jul 25, 2010 | Olympus FE-25 Digital Camera
My Z812 keeps telling me I need to reset the date/time every time I turn it on, even if I have just done it. Also drawing batteries very quickly (lithium, camera type)
It may only happen enter date and time if you remove the battery in the camera., If your not removing the batteru out of the camera you should not recieved that message, unless battery is out of charge or no power.
You should use this battery Kodak Li-Ion rechargeable battery KLIC-8000. This is a special battery for Z812 camera,
Note: You must also need to purchase a charger for this type of battery.
I guarantee you it will provide stable longer power for on your camera
Nov 20, 2009 | Kodak EasyShare Z812 IS Digital Camera
When I placed my Lithium Ion Battery in the charger it doesn't carge the batter and the red light that's supposed to stay lit while it's charging keeps on blinking on and off.
How old is the battery?
It's very possible that the blinking light is indicating a bad/old battery. These rechargeable batteries after so many cycles lose it's charging capability and the fault system built into the recharging base will indicate by giving you the red light on & off. Energizer rechargeable station is a good example when it detects old or bad batteries.
Nov 08, 2009 | Casio Exilim EX-Z57 Digital Camera
Replace battery sign in New canon A590si camera.
You're using the wrong batteries. You need to purchase lithium batteries. They are quality batteries for high powered, battery operated electronics. Personally, I have a battery charger and use rechargable duracell batteries. (HR6/ DC1500/ NiMH/ 1,2V) Gives you approximately 16 hrs before having to recharge.
Dec 01, 2008 | Canon PowerShot A540 Digital Camera
Batteries are Depleted
A camera rep told me that use about 2500mi (?) batteries instead of the 900 I was using otherwise the batteries will be depleted with just one picture. Digital cameras or any other digital piece of equipment needs the extra power. Make sure that your charger will charge the 2500 power ones fully.
Dec 17, 2007 | HP Photosmart M407 Digital Camera
Batteries
The Lithium batteries that are provided with the camera will supply approximately 200 images. The Ni-MH batteries will provide approximate 100 shots per charge. The B-10LPB Lithium Polymer battery will allow 500 - 700 shots per charge and can be recharged approximately 500 times. B-12LPB Lithium Polymer Battery will deliver twice the power allowing 1000- 1400 shots per charge and can be recharged approximately 500 times. The Alkaline batteries, although can be used, is not recommended due to very low battery life.
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Canon PowerShot SD750 / IXUS 75 Digital Camera Logo
132 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
