Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
When i turn my tv on i have no picture and i hear a beeping noise
But i have power coming from it
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and also check the power resistor, if values are not exact you have to replace them. These ICs are located behind the black heat sink; you can see once you open the back off the TV. The convergence board should be checked for cracked solder joints and please make sure to check the resistors as if they are shot the ICs might blow again. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please also make sure to turn off and unplug the TV for at least 1 hour to drain off the current from all the components especially capacitors before you perform any repairs. Also note that the TV consists of very high voltages even when it is in off condition. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
My playststion will turn on but no picture on my tv
try doing this when it is off (red light is glowing on power button) push and hold down the power button when you first push it you hear a beep while you hold it down you will hear another beep when you do release the button and see if it comes on, I had the same problem with my nephews ps3 and that solved it
Aug 12, 2015 | Sony Playstation 3 (PS3) Console
Im not getting a picture to come in to tv
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 17, 2009 | Sony Playstation 3 (PS3) Console
Nothing comes up on tv when i turn ps3 on and controllers wont connect
Read this very carefully. Turn off your ps3 from the back. Then turn it back on wait unit the light is red. Turn on the system through the front keep holding the power on. You will hear a beep one time that just tell you that the ps3 is powering on keep holding the button until you hear the second beep this will rest your video setting. If that dosnt work call me at sony
Nov 07, 2008 | Sony Playstation 3 (PS3) Console
RCA 32 in TV no picture no sound just a beeping noise TV power is on
HELLO.! IT SOUND'S LIKE A POWER SUPPLY PROBLEM TO ME.!!! & FOR THE TIME YOU WILL PUT IN TO IT & THE MONEY .!!! YOUR BETTER OFF GETTING A NEW SET.!!!HOPE THIS HELP'S YOU.!!!"GOOD LUCK"
Jul 20, 2008 | RCA 20F511T TV
Hello cote,
This indicates a problem in the power supply either the low voltage switching supply or the High voltage power supply. The sounds you hear is the shutdown circuit activating, I would not suggest that you try to repair this problem because of the dangers involved. I would suggest that you take it to a qualified TV repair shop. This problem should not cost you much, however it is the best choice for the problem you described.
I hope this helps,
Thank you,
Shuttle83
Mar 14, 2008 | RCA 32V524T TV
My TV shut off and will not come on
This is an issue with one of your power supplys wether it be high voltage horizontal power supply or the reg power supply. The beeping noise is letting you know that it has some power but not enough to start the high voltage needed to create the picture on your tube. I would seek professional help for this issue.
Nov 03, 2007 | RCA F36668 36" TV
Samsung Tantus - turning on and off... on and off...
have the main power supply checked sounds like its weak or out
Oct 12, 2007 | Samsung PCH521R 52" Rear Projection...
No picture or sound
sounds like the PTV Small Signal Board.
Jul 22, 2007 | Philips 60P8341 60" Rear Projection...
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
70 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
