Question about JBL Marine Audio Wired Remote
Problem with jbl mr 145 and mr 4.2b remote
I connected my new jbl marine mr 145 to an old remote from jbl marine mr 4.2b. When I plug the wired remote, the radio doesn't work anymore, none of the buttons are working and I cannot shut it down or change channel...
Also, I've seen that the colors from each side of the connectors (remote and radio) are almost all the same except for 2 colors.
Is it possible that the remote is not compatible with the new radio? Prospect electronic told me it was the replacement ...
5 Suggested Answers
MarineTech1
  • 76 Answers
SOURCE: I am trying to find
You will find the maual you need by using the following link :
http://www.prospecelectronics.com/JBL%20MR6%20manual.pdf
Posted on Sep 13, 2009
Benimur
  • 6966 Answers
SOURCE: jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 04, 2008
tom9990
SOURCE: JBL MR-17.2 not recognizing Sirius satellite receiver.
I have the exact same issue. I have swapped with two identical MR17.2 radios and swapped out the sirius receiver. No change. I even bought a remote thinking I had to have a remote installed to get it to work...still no diff. Have you ever found a solution?
Posted on Aug 28, 2010
SOURCE: I have a jbl mr-145
I have the same model stereo in a brand new hot tub that was having the same issue. To fix it all u need to do is pull the front cover off to access the pump controls and in there you will find a black box where a power cable runs yo the stereo. There are two screws that open a little door in the black box. In there you will need a small flat head screwdriver to move a redswit over to the 110 volts position. Turn the radio on and it should work. That black box just controls the power to the stereo.
Posted on Oct 07, 2011
Radio changes stations by itself and volume goes up and down all by itself. just not working properly. whats going on?
My solution was just to buy a new wired remote on ebay for $50. That way I had the same dimensions for the cutout on my center console. Essentially the remote is a remove and replace item. I bought one in chrome and just traded out my old cover and bezel which was a grey plastic.
Jul 15, 2012 | JBL Mc19 Chrome CommanderRemote W Display
How to connect aftermarket radio into 2002 toyota camry JBL radio (the standart wiring doesn't work).Thanks
Your aftermarket radio should have color-coded wires which identifies power, ground, speakers, etc. most depaetment stores carry a radio harness adapter kit. This will connect to your radio's exact color coded wires, and will plug right in to your factory's wiring plug. And don't forget electrical tape.
Aug 28, 2011 | 2006 Toyota Camry
I have a jbl mr-145 in a hot tub. It keeps powering on and off???
Oct 09, 2010 | JBL Marine Audio Wired Remote
Jul 13, 2009 | JBL MR-17 Sirius-Ready AM/FM/CD Receiver...
JBL Marine Audio Wired Remote Logo
262 people viewed this question
Top JBL Boating Experts
drshaddock
drshaddock
Level 1 Expert
DocZachary
DocZachary
JonSnell Electronic
JonSnell Electronic
Are you a JBL Boating Expert? Answer questions, earn points and help others
