Question about Zenith D52WLCD 52" Rear Projection HDTV-Ready Television
Zenith IQB50M92W rear projection. What I believe to be the blue crt unit (not 100% sure if that is what it is called)is popping and shooting electricity. The picture has also begun to round. Is this worth my time and money to fix and why would it be doing this?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
Probably not - invest that money in a new LCD tv with warranty.
Posted on Jul 03, 2010
I am unable to adjust the red color in the convergence adjustment on my IQC50H94W 2000 Zenith 50". From everything I read I believe I need to replace my Convergence IC Chips, however I am not 100%...
Your convergence has failed and needs to be repaired. Once quick test is to goto your convergence menu and see if you can adjust red and blue. If not its has failed and needs to be fixed. You can call in a repair shop or you can get the parts and instructions from www.TvRepairKits.com and do the repair yourself. Its a fairly easy DIY fix.
Jul 24, 2011 | Zenith IQC50H94W 50" Rear Projection...
My tv zenith is working the only ploblemb is the escreen get blue you see evryting blue de color of the people too
Your problem sounds like the projection bulb is going bad. It is the main problem with projection TV's, and is usually very spendy. I would recommend calling Zenith and request a new bulb.
May 03, 2011 | Zenith D60WLCD 60" Rear Projection...
Direct TV Code for remote
It is a hitachi chasis so use the hitachi code
May 14, 2010 | Zenith IQB50M92W 50 in. Rear Projection...
2 pictures image showing on screen trimed in read and yellow
Well - Good news - This is a convergence issue. Some how the Red's CRT's image has drifted off of where it should be of overlaying itself on top of the green and blue 'which make yellow by the way'.
If you contact a Zenith/LG Service center they may have a TV Tech that can come out and fix this issue. May be between $100 to $200 charge. Just guessing but this is fixable.
Blessings,
A/V Media Guy
Nov 20, 2009 | Zenith IQB50M90W 50" Rear Projection...
Need a red bulb for Zenith PVR5263RK rear projection tv
It sounds like your looking for a CRT (red) the part # is on the CRT and could be puchased through any Zenith (LG) distributer- usually around $300- $500. Google the part # when you get it and you may find a used Picture Tube (CRT)for cheaper.
Sep 22, 2009 | Zenith R57W46 57" Rear Projection...
CRT Arch / Blue Tube, Now what do I do.
Replace Blue Tube and re-align - Big job and expensive Tube cost min $300 + installation. You can see the tube arching internally?
Sep 21, 2009 | Zenith R56W36 56" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Replacement Lamp
Is Your correct model number a zenith R57W46? If it is your set doesnt have a lamp. Its a CRT projection so you have 3 CRT (picture tubes) RED GREEN an BLUE
May 10, 2008 | Zenith R57W46 57" Rear Projection...
Red and blue light ajust but green one will not
believe you would have a open resistor on the green crt board, was either a 120k or 110k resistor
Oct 28, 2007 | Zenith IQB50M90W 50" Rear Projection...
Zenith D60WLCD 60 in. Rear Projection
CALL ZENITH AND PROVIDE SERIAL NUMBER AND PROOF OF PURCHASE. THEY WILL SEND TECH OUT TO FIX OR REPLACE TV. THIS IS A PROBLEM WITH MANY PROJECTION TV'S BECAUSE OF A FAULTY PART.
Oct 03, 2007 | Zenith D60WLCD 60" Rear Projection...
Zenith D52WLCD 52" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
