Question about Kenmore Kitchen Ranges
Error code F30 on Kenmore Elite 790.4660 Range??
I keep getting Error code F30 on Kenmore Elite 790.4660 Range??
    President:
  • 1,194 Answers
Hi Cmirabile,
The F30 error code indicates an open oven temperature sensor probe.
A failed sensor probe will usually be the cause of this fault.
A broken or loose wire could also cause it.
In some cases, you could have a failed electronic oven control board.
I recommend replacing the temperature sensor probe first.
You should be able to access this sensor from inside the oven.
Shut off the breaker to disconnect electrical power to the range.
Remove the screws and gently pull the sensor forward.You can see the probe in the oven in the top left or right corner. It is pencil sized and about 5 inches long. You would need to get to the back of the oven to replace it.
There should be enough wire available to access the plug.
Unplug the sensor.
If you have a volt/ohm meter, you can measure the resistance of the sensor to verify that it is bad.
The normal resistance at room temperature is about 1100 ohms.
If it is open (measures infinite resistance) or significantly higher than 1100 ohms, then it will certainly need to be replaced.
If you suspect that it is okay, you could have a wiring failure or a failed electronic oven control board.
Thanks for using Fixya.
Good luck and have a nice day.
Posted on Jul 03, 2010
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Softener does not dispense and we get a code F 30
This error code F30 flashes when the central control unit (CCU) cannot drive the dispenser motor to the proper dispensing position and hence the softener dispensing problem. Disconnect power then remove the top panel and check the dispenser motor assembly for damage or broken parts. You may run a diagnostic test then take a look at the dispenser motor and observe how it behaves. Replace the dispenser motor assembly if damaged.
Click on the link below for the troubleshooting details of this problem and instructions on how to run a diagnostic test.
Troubleshooting Error Code F30 on Whirlpool Duet and Kenmore Elite Front Load Washers
Jun 19, 2011 | Kenmore HE2 Plus Front Load Washer
My kenmore elite oven is giving me a F30 error message. what is this code?
Sorry to read about your problem, I hope this helps you out.
f 30 is a the oven temperature sensor open, thats the probe in the oven area
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 02, 2011 | Kenmore Elite Stainless Steel 40" Dual...
I have a Kenmore Elite slide in range. The stovetop works fine along with the twist knobs. But the touchpad buttons and the oven doesn't work at all. When i tried unpluging it to reset it, it flashes an...
The F30 error code means the temperature sensor probe is open. First check the wiring, then check the probe. And if necessary, switch to a meat thermometer instead of a sensor probe. F31 is the error for a shorted temperature sensor probe.
Dec 27, 2017 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
We have a Kenmore HE5t that has an F30 error code. When you start the washer it just keeps clicking and won't fill. Any advice?
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 11, 2010 | Kenmore Elite HE5t Washer
Kenmore elite 49962 washer error code f30
hi sir, please check the following link. it tells about cause of the problem[Error Code F30]. http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
kindly rate me.. thanks for using fixya..
Feb 11, 2010 | Kenmore 49972 Front Load Washer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Stove oven does not workit,s a kenmore stainless steel
I have experienced a f30 code on my oven...I was told to change the oven sensor probe which i did....The code still comes up!!! SEARS IS NOT ANY HELP
Jan 20, 2008 | Kenmore 46123 Stainless Steel Electric...
Kenmore Elite slide in range F30 error
I had the same F30 error problem but fixed it. On my professional series Frigidaire, there are 2 resettable red button locations. I discovered that only one is in the rear of the oven. After going to the breaker box and shutting off the power, pull out the stove enough to work, unscrew the rear screws (I didn't unscrew all of them, just enough to work back there). The small red button is on a small black round piece with two purple wires feeding to it. That was not my problem. Mine was the other red button behind the control panel. Pull off all 4 knobs, unscrew by hand the large black rings that are underneath the knobs, pull out the whole panel. Look back and right (below where the right knobs were located) to find the 2nd red small button. Push to reset. Check this one first since it is easier to do.
Dec 27, 2007 | Ovens
Kitchen Ranges Logo
263 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
