Question about Bunn Margarita Machine Ultra 2 Slush Granita Maker
Have ultra 2 - it will power on go thru reset procedure then power off. then it will not power back up, any ideas?
  • Bunn Master
  • 2,237 Answers
Not getting enough power. make sure it'son it's own 15 amp circuit. or you might have to replace the fuse inside.
Posted on Aug 25, 2010
I lost my romote to my roku and it got reset. how do i set it up again without the remote
Hello
Reset Roku without Remote:
Soft Reset
From Menus (Newer Models - 4, Premier, & Ultra)
1. From the Home screen, select "Settings" > "System" > "Power" > "System restart".
Using Button (Older Models)
1. Find the "Reset" button on the back or bottom of the device. Some models will require a paper-clip to press the button.
2. Press the button, then release after about one second. The device should reset successfully.
Power Pull If none of the above soft reset options work for you, you may need to disconnect the power cord for about 20 seconds, then plugging it back in.
Hard Reset
A hard reset will clear all settings from the device and reset it to factory defaults.
Via Menu (Newer Models - 4, Premier, & Ultra) If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku and reset it to factory default settings.
From the Home screen, select the following depending on your device:
1. "Settings" > "System" > "Advanced system settings" > "Factory reset".
2. "Settings" > "Factory reset" > "Factory reset" > "Yes".
1. Remove all cables except the Power cord.
2. Press and hold the "Reset" button on the back or bottom of the device for about 20 seconds. Some models will require a paper clip to press the button.
3. Continue to hold the "Reset" button, then remove the Power cord from the back of the unit.
4. Release the "Reset" button, then plug all of the cords back into the device.
The Roku should factory reset, then walk you through the setup process again.
For any help Visit us: www Support Roku Com
Mar 21, 2018 | Roku Televison & Video
Screwed up
Try first unplugging tv and box from power for ten minutes.
Give details on tv model and equipment used.
Oct 13, 2008 | Fortec Star Lifetime ULTRA
How to reset onida true ultra slim 29
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Feb 19, 2017 | Ultra Televison & Video
Leap pad ultra
IF you forgot the wifi password, there is a reset button on the router that you can use to reset it back to the settings that it came with. If you use that you will have to reset a new password.
Feb 20, 2014 | LeapFrog LeapPad Ultra eBook: DisneyPixar...
Denon AVR 2105 5years old has worked perfectly. Now all of a suddend Zone 2 does not come on. Any ideas why after working perfect for so long?
Bad button on the remote? or
static discharge from being touched can cause all kinds of strange problems.
I would reset the micro processor back to default settings..
RESET PROCEDURE
1. PUSH MAIN POWER SWITCH OFF
2. WHILE HOLDING THE FOLLOWING KEYS DOWN, PUSH MAIN POWER SWITCH ON
AVR-2105 or AVR-885 Front Speaker A and B (2 keys)
Let the front panel blink 3 or 4 times and then release the keys (buttons)
You will have to do your set up again i.e. speaker size, assign inputs, FM presets etc.
Aug 25, 2013 | Audio Players & Recorders
Cannot connect wirelessly thru the router
try first resetting your router. then try relocating the router, have it away from interferences such microwave,refrigerators, or any gadgets that emits electronic noise.
if still the problems persists, try checking on the router's manual, or the website of the router manufacturer.routers have different specific step and procedure on how to setup wireless connections
Jul 02, 2010 | D-Link Xtreme N DIR-655 Wireless Router
Starview clone box no sky sports or setanta any ideas as to why? I am ex telewest now virgin
Just updated following below, got the lot back
have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Jun 10, 2009 | StarTech.com StarView SV211K 2-port KVM...
Starview box missing channels, sky movies etc any ideas?
Got this from another site,
sometimes channels change frequency so they dont work,have u tried a factory reset 0000 to delete,power off at back/on and autoscan ur provider,and emu to on,usually brings them back,do not scan thru splitters as u will lose channels.
Apr 02, 2009 | StarTech.com StarView SV211K 2-port KVM...
Installed 3d ultra mini golf adventures deluxe on a PC. After launching, there is a delay, then the computer responds that it "can't find orginal disk or authenticate." The disk is in the drive. any ideas?
If you have more than 1 CD/DVD Drive, try a different one...
Otherwise restart your PC, if that still doesn't work then follow this procedure :
1 : Deinstall 2 : Restart Computer 3 : Reinstall 4 : Restart Computer 5 : Restart Computer again 6 : Try again
Jan 04, 2009 | Vivendi Universal 3D Ultra...
Component out doesn't work on Denon AVR-3805
You can try resetting the unit, it is a procedure that can make things start working again. Be aware that it will put all settings back to factory defaults, and you will need to go thru and set everything back up again. If it does not work, then you most likely have a component failure that will require serious electronic troubleshooting and this would be best done by a professional.
Here is the reset procedure.
1. Turn power off with the main power switch on the front display, this should make the red led go out. There are 2 power switches on these Denon's. One is a bigger switch and is used most often, the other is a small mechanical switch that is normally left turned on at all times.
2. Hold down the "Direct" and "Pure Direct" buttons together (both at the same time) and while holding them down you turn the power back on again with that little power switch you just turned off.
You should see all the lights in the display light up and then it will turn on to the default setting which, if my memory is right, will be the tuner at it's lowest setting.
Then go thru and reset everything back the way you like it and need it. Make sure that all the video inputs are properly set for each function so you are not trying to get a composite signal out of a function that may be set for S-video or something like that.
Hope this is some help for you.
Dave
Nov 08, 2008 | Denon AVR-3805 Receiver
Open Questions:
See all Bunn Margarita Machine Ultra 2 Slush Granita Maker Questions
Kitchen Appliances - Others Logo
98 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Jerry Greenberg
Jerry Greenberg
Steve
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
