Question about Kenmore 24 in. 16039 Built-in Dishwasher
I have two rubber pieces that fell off dishwasher door. is from door hinge and what might they be. pieces are black oval and about 1 inch long. the disherwasher door has little resistance when opening and closeing with out these rubber pieces.both black rubber pieces have split.
2 Suggested Answers
  • 64 Answers
SOURCE: Built in Kenmore dishwasher. In the dark I did a
SOUNDS LIKE YOUR LATCH IS NOT LOCKING. THIS THIS COULD NEED A LATCH OR HINGE AJUSTMENT. BUT ITS YOUR LATCH THAT ISN"T WORKING
Posted on Sep 25, 2009
FELL ONTO DISHWASHER DOOR AND NOW IT WONT CLOSE.HINGES MAY BE STRAINED.HOW DO I REPLACE HINGES
Hello friend, thank you for your post!
It sounds like it could be an issue with the hinges. I would recommend having a technician come out to your home to diagnose your appliance properly. I understand that someone fell into the door and the hinges are not closing but there could be another issue with the door. Hopefully this is helpful. -Matt
Sep 19, 2014 | Electrolux Dishwashers
Take it apart
To make a tool to remove the oval screws. Take a 3 inch hinge pin and use a 9/64 inch drill bit. Drill a hole in the bottom of the hinge pin about 1/8 inch deep. Make sure this fits over the oval screws. Take the hinge pin with the hole in the bottom and squeeze it together in a vice.
squeeze it a fraction until it will lock onto the oval screws. Use a vice grip plyers to hold the tool as you turn it, It worked for me. Bobby Rice
Dec 08, 2012 | Nespresso D290 Espresso Machine
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Leaking door on Bosch dishwasher
I DONT THINK THERE IS A ASSEMBLY MANUAL BUT THE DOOR HINGES IS LOCATED UNDER THE LEFT AND RIGHT SIDE OF THE MACHINE. YOU HAVE TO CHECK THE HINGE PULLEY THEN CHECK THE LOCK.
Sep 23, 2009 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Dishwasher ''soft drop door'' mechanism came apart - door now drops
I had a similar issue as described by mc1bean. One day my Jenair dishwasher door just fell down. The right side spring was fine. The left side spring was still hooked into the door hinge but the cable was laying on the floor in 2 pieces. Over time it wore down and broke. I ordered just the soft drop cable. Now I could not find any installation instructions how to install the soft drop cable. After a few tries I think I got it right. Here are the instructions for hooking up the right side spring with the cable. The spring has to be hooked into the door hinge at the notch closer to the door. The end of the cable with the hook has to be hooked into the other side of the spring. The cable should lead from the bottom around the pulley up to the door hinge again. Now the other end of the cable has to be hung into the door hinge on the notch further away from the door. There is some slack, but it is not quite enough for the cable to get over the pulley when in rest position and undo itself.
I hope this helps others who have the same issue.
Feb 10, 2009 | Dishwashers
Printer fell...extra part?
hmm..well..that may not be your only issue..if the printer fell to the floor.
Oct 13, 2008 | Dymo LetraTag QX50 Thermal Label Printer
Whirlpool dishwasher quiet #1
Have you figured your dishwasher problem out yet? In my Whirlpool, that tube doesn't fit on the wash column, it just snaps on to the lower rack, right above the washer column black rubber gasket... hope this helps!!!
Sep 02, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Door hinges broken and door fell off
yeah very easy and it should only cost at most about £10 undue the old hinge with the 2screws now the door will have two little covers that held the old hinge in place take these out and make sure u get the broken pieces out of them once u have the new 1 put it on the washer and screw down first and then place the covers on the ends of the hinges and put the door in place now redue the screws on the door
Jun 01, 2008 | Candy CN146 Front Load Washer
Door clips fell out
IF THE CLIPS ARE BLACK AND ABOUT 1 1/2 INCHES BY 2 1/2 INCHES THEY GO ONTO THE HINGES AND THE DOOR GOES OVER THE TOP OF THEM, YOU MAY NEED TO LIGHTLY FLEX THE SIDES OF THE PANEL TO GO OVER THE HINGES. THE TOP OF THE PANEL SHOULD SLIDE UP INTO THE CONSOLE BEFORE THE BOTTOM WILL GO IN. HOPE THIS HELPS YOU OUT
Feb 07, 2008 | Bosch 24 in. SHU5305UC Built-in Dishwasher
Kenmore 24 in. 16039 Built-in Dishwasher Logo
238 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
