Question about LG LFX21960 Stainless Steel Bottom Freezer French Door Refrigerator
Lights don't come on
I actually have a LSX21960ST. The lights don't come on. I replaced both bulbs and the switches still cause the door open alarm to sound when they are open.
My wife said at one point, the lights were flashing off and on when the door was open. Now they don't come on at all.
Any advice would be appreciated.
    President:
  • 1,891 Answers
The new bulbs may not be in tight enough . / try spraying them with pam them turn them in they will go in easer and maybe solve your problem .. mm
Posted on Jul 04, 2010
The door open alarm keeps beeping after the door is closed.
open the doors and press the door switch to see of it is operating the lights, if there is no effect when pressing the switch, replace it. the lights being left on while the doors are closed will cause the compressor and light bulbs to do battle as the comp. tries to cool and the bulbs heat the food compartment.
Apr 25, 2016 | Refrigerators
Have beeping noise can I unplug something to fix the problem 2002 kia Sedona
Beeping noise is the car alarm system for door open, key in the hole and the engine is off, parking lights are on and the door is open.
If the beeping sound can be heard while the doors are all closed properly, no lights are on, the key is not in the ignition switch, then one of these systems (doors, lights, accessories) are grounded.
You have to eliminate the cause one by one starting with the door switches which is the most likely cause, followed by the key in the switch sensor found at the base of the ignition switch (you have to open the steering wheel cover to check) and then lastly check that no lights are on when you close the door.
the alarm emitter is found at the end of the console box right below the car radio system.
Oct 08, 2014 | 2002 Kia Sedona
My light doesnt come on when i break the sensor....and my learn light blinks none stop
Random blinking of the learn light is normal.
To have your lights come on automatically when you walk into an open garage, you must START with the lights ON. If you don't want that feature and you want to turn it off, you must START with the lights OFF.
To turn the feature on, turn the lights on manually with the wall switch, then press and hold the LIGHT button for about 10 seconds until the motor unit light bulbs flash. Now, if the light bulbs are on, manually turn them out and then walk out through the open door. The light bulbs should come on.
To disable this feature, start with the light bulbs OFF and everything else is the same.
Feb 17, 2012 | Sears Craftsman LiftMaster Chamberlain...
My interior lights wont shut off and it drains the battery, how do i switch off the fuse so my battery doesnt die?
When you open the driver's side door, you will find a small switch located on the front of the door frame towards the engine compartment. If you push it, the lights should go off. If you push it and the lights don't go off, there is your problem - if the driver's door switch is okay, try the passenger side by doing the same thing.
If that doesn't work and you are sure that you have the panel switch set to off, then you may want to pull the bulb out of the interior light until you can get to the root cause.
You may not be able to pull the fuse without losing other functions too.
Aug 06, 2011 | 1997 Oldsmobile 88
Alarm sounds when you open the drivers door...
Most likely a bad ground switch in the head light switch.
Jan 24, 2010 | 2002 Chrysler PT Cruiser
My 2001 pontiac sunfire dome lights, and reading lights dont work. when i open the door there is also no beep sound. check fuses they seem to be ok. what else should i check?
hello,
is this problem only with the drivers door? or all doors?
if it is just one door you should check the door open courtesy light switch located in the door jamb (it will be in the jamb towards the hood only accessible with the door open) its a small cylinder shaperd switch that sometimes sticks due to corrosion. if its stuck the car has no idea the door is open. if it is stuck try and free it up with some pliers and lubricate with some wd40. another thing could be that the lights are burnt out. check this by turnig your dome lights on manually by turning the headlight switch (this adjusts your gauge lights) all the way until it clicks ...your dome light should be on if not repalce bulb and try again.
As far as the door ajar beep...do you have an aftermarket stereo installed...because the stock radio makes the chime throught the drivers side speaker...
i hope this helps
Aug 14, 2009 | 2001 Pontiac Sunfire
Power and no lites in refrig/freezer; beeping
depending on age of unit, the problem may lie in the light bulb,well the door closing anyway, the newer unit s actuall will shut down all interior lights, in the evnet that teh door is left open for more then 2-3 min, so its possible that a light switch is not being activated so the uit thinks the door is open and has shut down the rest of lights, cooling however does continue normally.
Mar 08, 2009 | KitchenAid Refrigerators
Oven lights
This is likely either a burned door switch or a burned panel switch.  If you used to get a light when you opened the door, you'll need to find and replace the switch.  Also, check the actual sockets of the bulbs...are they in good shape?
Nov 20, 2008 | KitchenAid KESC307 Electric Kitchen Range
Open Questions:
LG LFX21960 Stainless Steel Bottom Freezer French Door Refrigerator Logo
93 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Mike
Mike
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
