Question about Briggs & Stratton Pressure Washer Projectpro Spray Nozzle
Brute 2100 psi 1.9 gpm how does the soap siphon work?
How do i prime the pump on the soaper or chemical dispenser on my troy built 2550 psi pressure washer?
There is no need to prime. But you do need to use the black spray nozzle to get soap to siphon out.
if that doesn't solve the problem let me know
Oct 26, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
Will not siphon
This model pressure washer will only siphon from the soap dispenser when you have the low-pressure nozzle attached and then will only sort of dribble out the suds. Good for sudsing, but no good for cleaning. You'll have to suds 1st then change to a highwe pressure spray nozzle to perform the actual cleaning. If it won't siphon with the low pressure nozzle either, then check for a blockage (old, dried soap) in the suction line tubing. Hope this helps!!
Oct 19, 2014 | Dewalt Pressure Washer. 3000 PSI 2.5 GPM...
Troy bilt pressure washer not siphoning soap
clean and soak all valves if do get work do not leave solution in it over time.carb cleaner with that little straw
Oct 19, 2014 | Troy-Bilt XP 3000 PSI 2.7 GPM Gas Pressure...
Why the water is running from detergent siphoning tube?
The siphoning mechanism on almost all power washers use "The Venturi" effect to suck up the detergent. Basically, there's no pump...the force of the water passing the siphon hose causes a vacuum which draws the detergent up the tube. There's a small ball that is supposed to fall and block the tube when the trigger is released so it sounds like it got jammed up in there somehow. You could it apart and free it up but I would recommend just purchasing an external detergent dispenser. Home Depot carries them for about 15 bucks. They allow you to use soap with high pressure and bypass the always problematic siphon system.
Jun 08, 2014 | Troy-Bilt 2700 PSI 2.3 GPM Gas Pressure...
Why won't the cleaning solution come out of the hose for Husqvarna 3100 PSI 2.8 GPM Gas Pressure Washer 020490?
Most people I run into with this problem are trying to get the cleaning solution to work with one of the high pressure tips, usually red, green, white or yellow. The only way to make the machine use the cleaning solution is with the low pressure, soap tip, usually black. With the high pressure tips there is too much back pressure for the solution to be picked up and mixed into the water stream.
Apr 28, 2014 | Husqvarna 3100 PSI 2.8 GPM Gas Pressure...
2600 PSI Pressure washer will not draw detergent up
I posted an answer to no soap on the Karcher Factory-Reconditioned 2,600 PSI 2.3 GPM Gas Pressure Washer G 2600 VHR. Same machine I suppose, but use the black 65 l degree low pressure nozzle.
It's in the manual , I missed it and had a hell of a time trying to figure it out. If that doesn't work check the check valve on the pump(Where the soap hose is) , see if it's gummed up.
Be careful taking it off there's a spring and ball bearing in there.
Apr 09, 2013 | Karcher Garden
What is max. gpm and pis of the wisperflo punp 011773
Your question sort of requires two answers as the max flow and max psi are not the same yet relate to one another.
The max flow is ~105 gpm at ~26 ft./hd or 11.3 psi.
The max psi (head) the pump can operate under is 40 psi or ~85 ft./hd at which flow is ~35 gpm.
In other words, in a pipe system with low resistance it moves up to 105 gpm and in a very complex system with lots of elevation changes and a lot of resistance the pump will move about 35 gpm.
PSI as read on a gauge on a filter attached to this pump will NOT be the same as the ratings I am giving you here.
John
Aug 24, 2011 | Pentair Whisperflo 1 12 Hp Pool Pump Wf26...
I have a 2750 PSI pressure washer with a 6.5 hp Honda engine. The soap mixer will not work. Any ideas? Please advise Tahnks
Check the draw tube and soap inlet for a clog. The soap mixer works on siphon action so an obstruction is pretty much all that can go wrong with it.
Jun 27, 2011 | Honda Garden
John deere 3800psi pressure washer will not siphon detergent. the water end does fine but cannot get any soap
The only way the washer will draw soap into the line is with either the black tip installed or with no tip in wand at all.There is a ball and spring inside of the pipe that the siphon hose hooks to so when you use the washer with alot or even a little pressure the ball is forced up and blockes off the soap inlet port.So if you use it with no tip in the inlet port is open cause the ball isnt being forced up by back pressure.I hope this makes sense.
May 18, 2010 | Dewalt 3800 PSI Pressure Washer
Briggs & Stratton Pressure Washer Projectpro Spray Nozzle  Logo
434 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
