Question about Frigidaire FSC23F7D Side by Side Refrigerator
The ice maker is leaking water into the tub. It shuts off when you lift the bar
    President:
  • 1,891 Answers
Replace icem maker as if it were the valve it would not shut odd when you stop the ice maker .. mm
Posted on Jul 04, 2010
Kitchenaid icemaker will not shut off when bin is full of ice. Model: KUIS18NNXSo
Is there a wire/bar that goes across the ice bucket? As ice fills the bar raises up and eventually goes high enough to shut the maker off until the level goes down.
You can manually lift the bar up to ~ horizontal until it clicks in place and stays there. That should shut it off until you move it back down. If there is no bar, then I guess there in no way your ice maker knows when it is full and keeps producing. Perhaps the bar was removed, bent or broken off. At least tht is one type of ice maker I'm familiar with. Other types my have different ways to tell the maker it's full.
Mar 12, 2018 | KitchenAid Refrigerators
Ice maker drips water into freezer.Makes ice but doesn't shut off when full.
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
Aug 6, 2015 - If the ice maker doesn't make ice but you can see the arm swing intomotion and you hear a ... 4Check the water line that enters the back of the freezer for a blockage. Find the water shut-off valve behind the refrigerator or under the sink, turn it off, ... If your ice maker keeps making ice, even when it is full:.
Refrigerator's Ice Maker Leaking Water ' ThriftyFun
www.thriftyfun.com/tf37813274.tip.html
If your refrigerator ice maker is leaking water, the first step is to locate the source. ... Its not the ice maker - in the floor of the freezer is a small drain that lets the ... I shutthe water supply off but water dispenser still leaks even though no ... My side by side refrigerator leaks water into the ice bin when filling the ice tray with water .
Dec 26, 2015 | Refrigerators
How do I shut off a Frigidaire ice maker?
Hello Russell:
My name is peter. I am a retired field service refrigeration technician.
You did not provide any information on your unit. Your model number is on a label on the side wall of your fresh food section.
Depending on the type of ice maker that you have the shut off is different. Some ice makers have a lever are that you lift up. Others have a shut off button.
The normal cycle is 8-10 ice dispenser deposits a day.
Tell me what the problem is. Give me the model number. You have one of those nasty bottom freezers?
Feb 27, 2015 | Frigidaire Refrigerators
Ice Maker leaks water into the ice collection tub.
The ice maker is not metering the water correctly and it will need to be replaced. Here is the part to order.
Jul 06, 2013 | Frigidaire FRS26R4A Side by Side...
I just received a Sunpentown model IM 100 from a friend with no instruction manual. I?m not sure where to put in the water in the ice maker. Also there is a plastic male threaded drain on the left side of...
The outside male thread drain should have a cap to hold the water; this is the drain for draining the unit. Filling the unit is as you described, simply lift the lid and add water into the tub. It should not be leaking water from under the unit ... that could be a problem. Good luck!
Dec 05, 2010 | Sunpentown SPT IM-100 Portable Ice Maker,...
Ice maker is dripping water into the ice tub and making a big block of ice. Is there an oring or something that may be leaking
Your ice maker inlet valve has gone bad.
Turn the ice maker off by lifting the wire that s on the side of the ice maker up until you feel it click then it should stay in the up position. This is off. Do not use your ice dispenser as it can be damaged by the clumped ice and leave the ice maker off as well until you replace that valve. The part number you need is 67005154.
To replace the valve you will need to trace your water line from the valve to the nearest cutoff. Turn the water supply valve off. You will also need a towel to catch the water that comes out of the lines and you will need to UNPLUG THE REFRIGERATOR so you don't get shocked. Then replace the valve. Turn the water on and look carefully for a leak. What I do is wipe my fingertip around all the joints a few times drying them each time til I get a few dry wipes. Turn the ice maker on and again look for leaks after the water cycles in. If all the joints are dry after you should be good to go.
Thanks for asking.
May 26, 2010 | Amana ASD2622HRS Side by Side Refrigerator
Ice maker leaks water, when you lift the bar that turns ice maker off it stops. haven't taken front cover off yet. is there a valve or seal in there.
I would suggest replacing the complete icemaker . Some icemakers , due to the coating , bubble inside or the coating wears off . When the coating wears , water will "eat" thru the pot metal aluminum . Also some have sensors that are not sealed well , and water will leak thru the seal . The quickest and most reliable way , is to replace the icemaker ( 1 year warranty on new icemaker ).
Sep 09, 2009 | Refrigerators
Crosley side by side ice maker makes to much ice !!!!!!
Most ice makers have a wire bar that senses when the ice bucket is full. The bar lifts up when new ice is made. The ice maker determines if the ice bucket is full by lowering the bar back down after the ice drops into the bucket. If the bar hits the ice cubes in a full bucket, the ice maker shuts off. If the bar drops all the way and dosen't touch ice cube, the ice maker continues making ice until the bucket is full.
So you likely have one of the following problems:
1) The wire bar is missing or bent. Check to make sure that when the bar is pushed up, the ice maker stops making ice. Most bars will 'click' into the up position so you can shut the ice maker off. Push the bar up until it clicks into the up position and wait overnight to see if it makes more ice. If there is no wire bar over the ice bucket, that is your problem.
2) The switch the wire bar is connected to is malfunctioning. If you push the wire bar up and the ice maker continues to make ice, this is likely your problem. You will need a new ice maker unit. Try Appliance Parts Pros or EBay for a new unit.
Jan 07, 2009 | Hotpoint HSS25GFP Side by Side...
LG Refrig ice maker on model LSC27950 overflow bar i think is stuck in one position because it made to much ice and jammed it up. now no ice is being produced
you lift the bar up to shut the ice maker off . or the ice fills and shuts the ice maker off . simply push the bar back down to star the ice maker in operating again
please rate solution thanks
Oct 19, 2008 | Refrigerators
Ice maker leaking
Sometimes the frozen chunk of ice in the back of your ice tub is caused by the tub being overfilled. The ice cubes pile up so high that they come in contact with the defrost heating element in the bottom of the ice maker. This melts the already formed cubes and form a blob of ice in the rear of the tub.
If the "icicle" is forming even when the tub is relatively empty, then it is probably a leaking solenoid valve. This is an electric water valve that opens and closes according to demand. Like any valve, it has seats that eventually leak, especially in areas with hard water. This will need to be replaced. Water filters go a long way in increases the usefaul life span of the valve and will also improve the ice quality.
Dec 02, 2006 | Kenmore 53642 / 53644 Side by Side...
Frigidaire FSC23F7D Side by Side Refrigerator Logo
216 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
