Question about U-Line Icemaker
U-line Echelon model #U-CLR2160S-40 Display shows
U-line Echelon model #U-CLR2160S-40 Display shows power off. Can not get it to turn on. Could it be a aboard problem?
What does 34F ER mean
Put a freezer thermometer in the freezer and see if it reads +34 degrees, then put it in the refrigerator. If the freezer reading is above 0 degrees, say +34, then the freezer is too warm. If the refrigerator is reading 34 and the freezer is way cold, then the refrigerator is getting too cold. This could be either a thermostat setting too cold or the sensing isn't reading properly or a much more serious issue. Generally a refrigerator should be no warmer than +40 but not freezing either +32 degrees and a freezer should be about 0 degrees. Make sure nothing is blocking the air flow duct work or where the sensors are located.
Aug 14, 2014 | U-Line Echelon Combo® CO2175DWR Compact...
Uline Echelon Ice Maker P1 error code
P1 is a indicator of a slow or clogged drain check to make sure that every thing is draining good if line is clear make sure pump is coming on to pump the water out of the bin. once all is clear unplug the unit for an hour then plug back in this will clear code unless you still have a drain issue.
Jan 17, 2014 | U-Line Icemaker
Coleman echelon 9.T furnace will not turn on. Red light blinking
sounds like it is the pressure switch try jumping it out on some models you fool the heater in too working or see if the tubes are blocked , there should be some codes on the front panel or the fan panel
Apr 27, 2010 | Coleman Propane Forced Air Heater...
Power went out; now U-Line has no power. Circuit breaker checked; power is plugged in.
1st make sure you dont have 2 dashes in the display. If you do then the board will have to be programmed. If its blank or 0 then unplug the unit for a min. then plug it back in. It should work.
Dec 28, 2009 | U-Line 2115R Echelon Series 15"...
I need to know how to get to reduced row echelon form
i tried to graph a simple function but it wont show the lines it will only show the graph
Mar 17, 2009 | Casio FX-9750GPlus Calculator
Percenteg Function problem in my Casio MJ - 120 Model Calculator
I found it by myself, I can help you.
1. Press (AC)
2. Hold (Rate) for about 2-3 second
3. Press (Set / TAX+)
4. Input the tax rate
5. Press (Set / TAX+)
6. Hold (Rate) for about 2-3 second again
7. Press (Set / TAX+) again
And Then you can test the rate .
From Thailand
Mar 12, 2009 | Casio Office Equipment & Supplies
U-Line CO2175FS-00 Echelon
Depends, if you have the later models, you can able to retighten it a the handle, it is removeable, but if you have the old version, too bad, you have to replace the whole door. You can try to call U-Line at 800-779-2547 to see which one you have.
Nov 08, 2008 | U-Line Echelon (CO2175FS01) Compact...
U-Line Echelon Model B12115
Whne you are on site, call 1-800-779-2547 for help. This is U-Line's tech support line,
http://www.u-lineservice.com
May 26, 2008 | U-Line Icemaker
U-Line Icemaker Logo
52 people viewed this question
Top U-Line Kitchen Appliances - Others Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
jasbo
jasbo
Are you an U-Line Kitchen Appliances - Other Expert? Answer questions, earn points and help others
