Question about Panasonic Home Theater System System
F-61 shows on system and cuts off. what do I do?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 99 Answers
F-61 came up on a panasonic home theater system i once owned and switched off.
it turned out to be a faulty cooling fan at the rear of the receiver. once replaced all was well.
hope this helps.
Posted on Jul 04, 2010
  • 2 more comments
  • Hetztronics ltd
    Hetztronics ltd Sep 12, 2010
    hi the hint you give is perfactly fine, becoz the board on AV receiver are highly current balanced by many ways isf some thing is consuming more current then required the MCU denies to start for board safty
    in my case the fan hub bush is broken which was jaming the shaft i replaced bush and solve the problem date 12/09/2010
  • d33c33 Nov 23, 2010
    anybody know where to buy this fan? I've been trying to find replacement parts online
    Anybody know where I can find the replacement part for the fan? I've been researching online and haven't found the part...
  • spritz1 Jan 04, 2011
    Buy the fan from your local computer part dealer - costs no more than 5 EUR. With a small mod it will fit in perfectly. I replaced mine but it did not solve the problem with F61, unfortunately.
I have a Husqvarna 61, it starts fine and will cut wood happily for the first five minutes of use, but then it looses power and stalls. It will start again fine, but then cuts out again soon after....
Start withe the inexpensive stuff first, pull the fuel hose out of the tank and change the filter on the end, by your discription it could also be an electrical issue, the early 61 had a two peice system, an electronic block to the left of the flywheel, and a coil at the right, if you have this system check the where the yellow two wires connect under the head of a self tapping screw under the coil, if the connection is ok it may well be a case of replacing the electronic box. The later 61 has a single peice ignition system, this may be breaking down when it gets hot, and need replacing.
Let me know how it goes, and if you need help with part numbers etc.
Mar 14, 2011 | Husqvarna Garden
SA DT310 showing F61 and closing down
the F-61 code means your audio outputs are bad you must have it repaired
Dec 19, 2009 | Panasonic Home Theater System System
LG Reverse cycle ducted (in ceiling) airconditioning works normally on heating and coooling and then cuts out after 2 days and shows error code 61.This is in 3rd floor apartment. The system can be reset by...
Error code CH61 - CONDENSER PIPE HIGH PRESSURE. This can be due to overcharging of the system or the condenser clogged with dust or an obstruction, or condenser fanmotor not working. Hope this helps.
Nov 16, 2009 | LG Art Cool LA121CNP wall/window Air...
F 61 error on panasonic home theater
the problem is amplifier ic failure you have to change it
Dec 25, 2008 | Audio Players & Recorders
Error61 code
thats a "protect" mode..your audio outputs are stressed and overheating..will need to be replaced soon
Aug 26, 2008 | Panasonic sa-ht800V Home Theater Audio...
Hi fi wont turn on !
hi. im assuming its a technics / panasonic system judging by the F 61 error code? try testing the cooling fan at the rear (assuming it has one) i once had the same error code on my technics amp and it turned out to be a faulty cooling fan. after replacement out of a scrap unit, the amp worked perfect.
Aug 07, 2008 | Audio Players & Recorders
Panasonic Home Theater System System Logo
1,374 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
