Question about Kenmore Dishwashers
My Kenmore 15882 dishwasher continues to fill with water. We keep pressing the cancel button to drain the water. Any ideas?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the dishwasher is overfilling it’s caused because of water-inlet valve going bad. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. If the water-inlet valve is defective, you need to completely replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
Kenmore elite dishwasher model 630 Smart Wash light is flashing
You may want to try:
Press a series of four buttons in quick succession. Press "Heated Dry," "Normal Wash," "Heated Dry" and "Normal Wash" to instruct your Kenmore dishwasher to run a short diagnostic test.
Wait for two minutes while your Kenmore dishwasher runs its diagnostic test.
Press the "Cancel/Drain" button once your dishwasher has completed its diagnostic test. This should reset your dishwasher control panel.
Check to make sure that there's no standing water in the bottom of your dishwasher. Standing water in your dishwasher may indicate that your dishwasher has stopped mid-cycle. You will need to press the "Cancel/Drain" button before you can reset your dishwasher control panel.
Dec 18, 2013 | Dishwashers
Dishwasher will not start. The clean light is flashing on and off. If I push the cancel button it appears to be draining but there is no water in the tub and it just continues. When I push the start...
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Jan 20, 2011 | Kenmore 24 in. 16039 Built-in Dishwasher
Kenmore dishwasher M# 665 s#16632000 STOCK# FL4313714 It is leaving about 2in. of water in the bottom once its done with the wash cycle. When I push the drain /cancel button and take drain hose off the...
I would remove the bottom panel of the dishwasher and remove the drain hose from the pump. On some of the Kenmore Dishwashers you can remove the drain spout where the drain hose attaches to and clean. Sometimes something will catch inside the drain spout.
I hope this helps.
Feb 03, 2010 | Dishwashers
'clean' light flashes
Press the normal wash then heated dry buttons in the same sequence two to three times. The unit will enter diagnostics mode, but can be stopped by pressing the cancel button.It will clear any existing faults and makes the dishwasher to operate normally.
To prevent the issue from recurring, run your hot water faucet first to ensure that hot water is present in the entire supply line before starting the filling.
Oct 18, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Kenmore Ultrawash QuietGuard 3 Dishwasher not draining or rinsing
Not draining may either need new drain motor. or something is blocking the drain pipe.
Spots on dishes means you are using to much detergent or the wrong kind of detergent.
Your owners manuel should tell you what type to use.
Nov 18, 2008 | Kenmore 24 in. 15932 Built-in Dishwasher
Water slowly filling cabinet when dishwasher is off.
either
leaking valve - to check, turn water off and see if it still happens
or
if appliance is plumbed in to a spigot on the sink trap, then when you empty sink, some of the water finds its way into the dishwasher via the drain hose. to cure, take the drain hose as high as possible under the sink in a swan neck
Oct 08, 2008 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Dec 29, 2007 | Dishwashers
Dishwashers Logo
109 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
Fred Sops
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
