Question about Kenmore Washing Machines
What does fr21 mean on a front loader kenmore he3
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F21 means long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
I have a kenmore elite he3 front loader washer. it gives me a f11 code when i attempt to wash a load.
F/11 is serial communication error code. It means the communication between the central control unit (CCU) and the motor control unit (MCU) is not good. Possible causes include worn or failed drive system components, faulty CCU or MCU, broken wiring harness, faulty drive motor, or faulty wiring harness connections in the CCU, the motor, or the MCU.
Jun 09, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite dryer runs cold no heat
Most of the time its the thermal fuse part # 3390719
Jul 21, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Check Pump on front loader kenmore HE3 elite
Remove the lower front panel 3 screws across the bottom. Pump will be behind this panel.
May 26, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 front loader shows an error message of F02. It doesn't complete the rinse cycle as a result.
There is a trap on washer pump I just found to be full of the same **** you find in sink trapp. That is probably why I had same problem. could also be kinked hose or pump issue. The experts at fixya just walked me through it. best ten bucks i ever spent.
Good luck Scott
Apr 05, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 Front Loader Washer Cold Water Intake problem
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Mar 30, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
"suds" error in kenmore elite HE3 front loader washer
Try a vinegar rinse or there are also defoaming products available.
Jan 02, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer HE3 kenmore Elite
ok " there is a filter on that line ,it has to be cleaned
to locate filter, follow hose back to filter
filter will come apart for cleaning
Jan 11, 2008 | Kenmore 44832 Front Load Washer
Washing Machines Logo
44 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
