Question about Fuji Cameras
I HAVE JUST GOT THE CAMERA WITH NO INSTRUCTIONS
I HAVE JUST GOT THE CAMERA WITH NO INSTRUCTIONS IT TAKES A GOOD PICTURE BUT THEY ARE IN BLACK AND WHITE HOW DO I GET THEM IN COLOUR
  • kakima Jul 03, 2010
    There's probably a setting in the Shooting menu. I wish I could be more specific, but unless you specify the model I can't give you any more details.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Fuji Master
  • 102,366 Answers
Having received no response in over a month, I assume this is no longer a problem.
Posted on Aug 09, 2010
When i take a picture, my picture comes out black the camera turns on fine, batteries are charged and everything. but the screen is black. it acts as if it was going to take a picture but the screen does...
Your camera may be manifesting shutter not opening problem. It needs to get to a camera service/repair shop.
However, it's good you physically check whether the lens isn't blocked or covered with anything
Oct 12, 2017 | Nikon COOLPIX S6 Digital Camera
Camera opens normally, only takes black pictures
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
May 09, 2010 | Canon PowerShot A530 Digital Camera
Apparently takes pictures ... but black out the screen .... if you turn on and everything but can not see anything ... Sorry about my English
I see nothing on the monitor screen when I want to capture a picture. The screen monitor remaind black but I can capture new pictures. when I press the play button, I can't see the picture. When I retreive the picture from the camera to a computer, I realize the picture is black and I can't distinguish anything.
But when I introduce the good picture from my computer to the Digital Camera, from the Sceen Monitor, I can visualize only the good picture I introduce in mysefl.
The flash is working properly, the on/Off button is ok, the lens appear to be normal.
My Digital Camera is Casio EX-S880 EXILIM
Jan 29, 2010 | Casio Exilim EX-S880 Digital Camera
My camera takes picture but there all black? The
Last year my Canon PSA60 got the black screen in shooting mode. Menu display was normal and so the picture review mode.
Canon service center replaced the image sensor for free. When it happened again, I asked the service center for unit exchange (trade-in/upgrade program). Now I have my PowerShot S5IS. Good bye PSA60.
Canon has issued this in their notice page: http://support-asia.canon-asia.com/index.jsp?fuseaction=support&prod_type=notices-digitalcameras-lcd
Regards,
Herry Chris
Aug 11, 2009 | Canon PowerShot A60 Digital Camera
Not taking a complete picture
Broken focus mirror pin. Gently lift mirror and see if the tiny focus mirror behind folds flat to the bigger mirror. If not then the pin needs replacing. Problem is that it takes some time and most of the camera needs to be disassembled to get to it inside.
Nov 22, 2008 | Canon Rebel XT / EOS 350D Digital Camera
BLANK (BLACK) PICTURES
symptom 1: referred to as FFB (Firts Frame Black). this is when you do not use the camera for a while and when you attempt to take the first snap shot, the Shutter is either stuck, or takes a blank/black picture (some cases the picture came out bluish). Sometimes the camera would freeze and you would need to remove the battery and re-insert it in order to reset the camera. Usually the camera comes back to life and and is usuable for a while until you store it. Sony will fix this free as they identified it as a design flaw in which the remedied (incorrect gear size for the Shutter charge assembly). Contact Sony support as they own all Minolta camera assets and tell them you have the FFB or First Frame Black problem and they will set up a ticket and instructions on where and how to send it.
symptom 2: Camera does not respond at all to the shutter release. Focus is fine, menu works, every function works no problem except for the most important - taking a picture (releasing the shutter). When you first turn on the camera, you hear the Antishift module attempt to center the CCD with a series of clicking noise for 5 or so seconds (not a good sign, also called the death rattle). All 5 AS bars in the view finder are blinking. In this case, the Tebure Assembly (AS Module) has failed and will need replacing. This is not cheap - sending it in to Precision Camera will run you around $250-$280. You can do it yourself if you order the assembly from Sony: Item - ( TEBURE ASSY ), U3008233U, $118.22 ea. via 1-800-488-7669 (will take 3-4 weeks). And follow the service manual to install and calibrate it (via the service manual download at http://www.dyxum.com/dforum/topic36109_post396839.html#396839).
However, if your camera experienced the FFB and then siezed (symptom 2) you can probably still get Sony to repair it free as its one charge for a complete camera repair. Call them up and tell them your situation.
Jul 23, 2008 | Cameras
Problems taking pictures
Six months - Yes warranty.
Yes vendor still liable
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
No Picture
new battery
new smart card
all setting ok
Jun 11, 2008 | Fuji FinePix F401 Digital Camera
Black dot
maybe a bad ccd imager. the peice that takes the picture (converts color to digital)
Feb 27, 2008 | Kodak EasyShare CX7530 Digital Camera
Problem with pictures and zooming
If you cannot find a solution to your problem you may want to email fixityourself@gmail.com. He has good advice and good used parts at a fair price.
Sep 03, 2007 | Sony Cyber-Shot DSC-S40 Digital Camera
Cameras Logo
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
