Question about GE 24 in. Profile PDW7800 Built-in Dishwasher
My dishwasher makes a banging sound, I've checked the arm & even when the washers is empty it still makes that sound. NOW I've ALSO got a sound like a "clothes washer in spin cycle mode" also in the wash mode of my dishwasher. Do I need a service call or should I just replace it since it seems to be falling apart....it's only 2 yrs with min use
  • 10,515 Answers
This is quite a common problem. I would be able to help you, if you could provide few more details. When did you hear the banging noise i.e when filling, start of the cycle, mid cycle or it is always there?
Thanks!!
Posted on Jul 03, 2010
  • 2 more comments
  • baccrt Jul 03, 2010
    it's there from the start. It's been making the noise for a while but the washer spin cycle noise is new
  • taran_2005
    taran_2005 Jul 03, 2010
    Thanks for your response!!
    There could be plenty of reasons for the same. I could tell you few of the solutions that is REALLY common on GE dishwashers.
    1. Check the stainless steel cover on the bottom of the lower rack sprayer.
    If it has been bent downward on either end, it will hit the inside
    panel of the door near the bottom. It may score the panel as it hits on
    each rotation of the sprayer.
    Just bend it back in position, carefully, with a pair of pliers. The
    technique required is similar to bending the pocket clip of a fountain
    pen back into the proper position after it has been sprung out too far.
    You might practice on a pen or mechanical pencil clip to see what I
    mean.
    2. Most likely the tube that feeds the top water assembly is not supported
    well and is thumping around. Try pulling out the top tray and look
    straight down at it (ie: take a birds-eye view). You should see a tube
    leading from the middle of the top dish tray (where the spinning arm is)
    back towards the rear of the dishwasher. Look for a little plastic clip
    that attaches to the dish tray and which holds this tube in place.
    Unclip this from it's current location and slide it backwards towards
    the rear of the dishwasher. Re-clip it to the dish tray as far back as
    you can (you should be able to move it backwards at least two or three
    spaces).
    This will provide better support for the water tube closer to where it
    connects to the rest of the dishwasher plumbing (at the back of the
    dishwasher) and keep it from moving around. Start your dishwasher up
    again and the grinding and thumping noise should be gone.
    3. I have the same sort of sound...moving the little plastic clip didn't
    seem to affect it so i tried "tying it down' at several points on the
    feed tube...no obvious effect on the sound ...it "thumps" starting with
    the wash cycle and stops at the start of the rinse cycle..the "thump" is
    every couple of seconds continuously during the wash.
    Let me know, if that helps you :) unless i have many other solutions. I am sorry,but there is no specific solution as i could not see the machine :(. However, let me know the update, we would try to fix it.
    Note - If the dishwasher is less than 4 years old and cost of repair is less than half the new one, it is worth repair.
    Let me know,once done.
    Hope i helped you.
    Thanks for using ' Fixya ' and have a nice day!!
    I'll give this a try. If I need a service call, how do I find someone reputable (not rip me off ) in my area. Summerville SC. Sometimes the service call alone is $100.00
  • taran_2005
    Give me your zip code, i would go ahead and check someone from fixya directory.
    Thanks!!
Defy dishwasher bottom arm was banging and seems really loose but now no longer turns even though clear and sprays water
Sounds like the bearings have crashed. Time to look underneath and repair it or call a white goods repair agent.
Jun 28, 2017 | Dishwashers
Not washing very well, on investigation the lower arm is not rotating freely (it does turn but not spin). Cannot figure out how to remove arm to investigate further
You can find a manual online. Get a copy & see if they tell you how to remove the arm.
Not sure of the distinction between turning & spinning you cite.
Check that some food item has not become lodged and is binding the arm. Empty the washer, remove the rack & invert on a counter to get optimum access to the arm. The problem may become obvious.
Good Luck
Pete
Apr 30, 2015 | Indesit 18 in. D41 Slim-Line Free-standing...
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Dishes are always dirty, maybe even dirtier after running dishwasher. has hot water, lower arm moves.
Check the outlet holes on both spray arms for clogs. If necessary, remove the spray arms, clean out the holes and empty out any debris inside the spray arms. Verify that the upper arm is turning also.
If the machine does not drain completely at the end of the cycle, the pump drain outlet is partially blocked and you are retaining dirty water for the next load.
You may have a chemistry problem - inferior soap, empty rinse agent dispenser, or extremely hard water.
Improper arrangement of the dishes can prevent some from being washed. Make sure no dish blocks the spray to another.
Jul 23, 2011 | Dishwashers
Miele G892 SC Touctronic dishwasher, intake/Drain light came on. How do I clear the drain?
Evening to you - empty the trays out of the washer - remove bottom wash arms by pulling upwards - below tha is a steel mesh - turn the plastic handle to unlock & remove the mesh - on the left of the tub locate a steel clip - below this is the housing for the pump - unclip & lift upwards - you will get a rush of water its ok - then clean the foodstuffs etc from in here as the propeller or impellar is found - turn machine on as the machine will a;lways start with a pump run - switch off after 20-30secs - check if all clear - clean up & assemble - should be good to go...
Jul 01, 2011 | Miele Dishwashers
GE Dish Washer GSD 2800 DO3 runs a partial cycle...(even empty) and then beep and gives a message on control panel "washer arm blocked". Even ran without dish rack in washer still got the...
the rotating arm has a magnet in it to let the controls know if it is turning. Yours is not turning so
  • check the jets for blockages... you might have to remove the arm to clean them properly
  • make sure there in nothing stopping the arm from turning...spin the arm manually to see if it rotates freely.
  • knives etc sticking upward can stop the arms from rotating on the top rack
  • if you run without the rack the arm will obviously be not telling the electronic it is not blocked because it is not there. the rack must be in the machine with the magnet and the magnet passing correct messages.
  • If there is really no blockage then there is a elect fault that need to be sorted professionally.
  • PS have you taken the arm off anf squirted a hose up the inlet to see if water comes out all of the jets????
Mar 01, 2011 | Dishwashers
After filling and only when rinse commences a loud chattering noise begins. Somewhat like a circuit breaker making intermittent contact. It ends when I cancel and remains silent while the pump empties...
  • It sounds like you have an obstruction with upper or lower spray arm. check to see if the something is stuck in the path of the lower spray arm.
  • move the lower rack out
  • spin the spray arm by hand to see if it is hitting anything
  • if not .....spin the upper spray arm by hand under top shelf to see if it is hitting anything.
  • let me know how this works
Dec 30, 2010 | KitchenAid 24 in. KUDS25 Built-in...
Motor makes noise shortly after starting, makes normal sound level during main body of wash, then makes noise again during what I'm guessing is the rinse cycle. Not sure if it is a pump or motor problem....
Make sure the sprayer arm is turning freely, check for something stuck in the base of the sprayer arm (food or utinsel) preventing it from turning.
Sep 22, 2009 | Dishwashers
Dishwasher is filling up but not washing dishes.it will run the programme and also drain the water
Sounds like the washer arm is not rotating around during the wash cycle.. Can you reach in and manually rotate the arm to make sure it is free to spin? Also, it may be washing but the drain filter has so much sediment in it from previous cycles that it is just redistributing that stuff on you dishes.. check the drain filter too... lastly, is the detergent dispenser opening after a wash cycle? If it is empty ( meaning it has been used) the other things mentioned above are probably the issue.. Hope that helps...
Aug 16, 2008 | Dishwashers
GE 24 in. Profile PDW7800 Built-in Dishwasher Logo
146 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
