Question about Hayward Aquabug Above Ground Pool Cleaner Hay500
Can u hookup hayward Aquabug to intex above ground pool without disconnecting existing filter? Will both filters work at the same time? I would like to clean the top of the pool at the same time I clean the bottom!
  • 640 Answers
You Aquabug pool cleaner works WITH your pools filter. You much connect the cleaner to your filter system and the filters suction is what powers the cleaner. Since they operate together, you should always run your filter while you are cleaning, but it will never operate in its normal capacity since you are using it for a different purpose. Here is a copy of the users manual if you have any questions about how the cleaner works.
http://www.backyardcitypools.com/images/Hayward/Aquabug-Manual.pdf
Posted on Mar 30, 2011
How do i connect the filter to an above ground intex pool?
skimmer hose to front of the pump top of the pump to the in of the filter the out of the filter to the return
Jul 09, 2014 | Swimline Hydrotools Sand Filter
My bug worked great last season but this year I will find it stopped in the pool not moving, I will pick it up and push on the feet to get them running again and it will stop again, what do I need to
It may be that you have one of several possible problems that could be the reason for the symptom you are experiencing:
  • Low water flow thru circulation system
    • Dirty Filter
    • Baskets filled with debris
    • Clogged Pump Impeller
    • Clogged suction line between suction port and actual cleaner
    • Clogged/plugged cleaning unit itself
  • Worn gear assembly within the LadyBug
Jun 12, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
How to clean filter on ladybug
No filter.
You can clean out the internals, just remove the screws from below and then the pieces will remove and then additional screws become visible, until you have everything apart. Keep things organized and all will go back nicely.
Take a look at this site listed below...
A lady bug is almost the same unit as a navigator, just has a novelty covering. \
How To Service the Inside of Hayward Navigator Suction Cleaner
Jun 07, 2014 | Hayward Aquabug Above Ground Pool Cleaner...
Where does the hose from the skimmer go in filter or pump
skimmer goes to intake of pump out of pump to filter in out of filter to pool return
May 30, 2014 | Intex 1500 Gph Swimming Pool Filter Pump...
Wish to upgrade cartridge filter pump to sand filter pump. Pool size 15' X 48" / pump 1000 gph - 637R /Item no 56945 Which intex sand filter is the best one?
First, understand that sand doesn't filter as finely as cartridges, so "upgrade" may be the wrong word. Cartridges filter down to about 10 microns, sand filters to 25-30 microns. (i.e.the cartridge will catch particles up to 3X smaller than sand will.)
If you still want to change, get the biggest sand filter available that you can comfortably afford. For superior results look at above ground pump/filter packages built by Hayward or Pentair. Intex products are just built to margin and are not designed for long term usage.
Aug 31, 2013 | Intex "" Metal Frame Pool Set (56998e)...
How do I hook the bug to my sand filter?
You should check out figures 6, 7, and 8 in the owners manual for these pool cleaners. There are detailed pictures that show you how to connect the cleaner to the filter.
Jun 25, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Looking for instruction manual
Here is a copy of the users manual for the Aqua Bug pool cleaners. Hope this helps.
Jun 19, 2011 | Hayward Aquabug Above Ground Pool Cleaner...
Looking for an intex filter pump
The best solution to this problem not to find a replacement intex pump/filter. I suggest getting a system with a 50 square foot cartridge filter and a 3/4 hp pump such as hayward or pentair offers. You will be amazed at the difference a little quality can make.
Apr 07, 2009 | Intex Krystal Clear Model 635 Pool Filter...
Hayward Aquabug Above Ground Pool Cleaner Hay500 Logo
1,057 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
