Question about LG Dryers
Check filter light remains on even though the filter is clean . This us a LG 2515 Electric
  • leehowe1 Jul 03, 2010
    Rylee was exactly right, very fast and willing to stay on and help until the problem was resolved. Or a solution was developed....Outstanding
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. As you have already check that the filter is cleaned then unplug the unit for 5-10 minutes and push & hold the start/pause button for 10-15 seconds and reconnect the unit. If still it won’t work then it’s the sensor that has gone bad and needs to be replaced. Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
    Thank you so much. The dryer does work, and it heats well. So it must be the sensor. Is that something I can do or must be done by a pro.
    Sincerely, Lee
  • Rylee Smith
    Rylee Smith Jul 03, 2010
    If you are not mechanically good in repairs then it is always recommended to contact a professional however, if you want to do it yourself please let me know or do accept the solution if the issue is resolved.
    Thanks
    Rylee
The check filter light keeps blinking and it displays CL in the display area. I always clean the filter after every load and I swept any remaining lint from the vent but it won't reset.
the filter light is just a reminder. it is not connected to a sensor or anything. it is not the issue. the 'CL' code is the issue. CL means that the Child Lock is on. press and hold the child lock button for 3-5 seconds to turn off the child lock.
Aug 22, 2015 | LG SteamDryer Series DLEX4070V 27...
LGLD2302R will not heat up. The filter is clean, the motor is running, the circuit breaker is in correct position. The "flow sense" and "cooling" lights are on...never were before. ...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101][][
Sep 01, 2011 | LG Dryers
I have an LG DLE2532W and the check filter light keeps blinking even though it is clean and the dryer won't work what could be wrong?
There is a thermostat or safety somewhere on the dryer where the filter is and it probably is dirty or bad.
Mar 13, 2011 | Dryers
Dryer will not heat filter light not on
heatman101\
Dec 04, 2010 | LG DLE2514 Electric Dryer
I have a LG digital dryer about 6yrs old- there is cold air when drying and the clothes are still wet. The lights are blinking "drying" and "cooling" and also filter. My husband cleaned out all the link...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Sep 13, 2010 | LG DLE2514 Electric Dryer
Dryer has no heat--even though lint filter and heat exchanger are clean; the light is also off, but the tumbler turns normally
heatman101
Sep 04, 2010 | Bosch Axxis WTL 5410 Electric Dryer
I have a Bosch V20-Ul dryer that is 2 years old. Suddenly stopped creating heat. The dryer drum turns but no matter which cyle I select, it spins for about 1 min, then stops, beeps and the wrinkle block...
heatman101
Aug 09, 2010 | Bosch Axxis WTA 3510 Electric Dryer
Check filter light remains power light blinking
Hi friend,,,
welcome to fixya
try to unplug it for 30 minutes this should reset the control board. and clear any errors it has. and may start working again. let me know how it goes OR
try this to get it in diagnostic test mode have the dryer in standby mode then press and hold more time and less time and then press the power button to get out of this mode you will have to unplug the unit for at least 1 minute
if your satisfied with my solution PLEASE RATE IT
thank u...
Apr 09, 2010 | Dryers
Lg dle3777w dryer filter light remains on and dryer is not working even after cleaning the filter.
I'm sure you solved the problem but as i had the same problem on my electric LG front loader and saw no response i figured I would leave one for anybody else in the future. My girlfriend told me the dryer would not start and as i looke i saw the panel would not power up, I unplugged the power cord for 5 minutes and the LG reset and the panel was on and reading clean filter after checking the filter which appeared clean I tried to restart the dryer at which time it powered off. I again unplugged the dryer and replugged it and again the display read clean filter. I then gtabbed a phillips #2 and unscrewed the filter lint sceen which had a total of 4 scews in the interior of the dryer holding the filter housing unit. Youll see a piece of the housing unit remains screwed into the washer hooked up to two electrical plugs. Seperate both plugs from the unit and unscrew it and remove the unit youll notice two silver strips on the unit and I'm guessing will be covered with a small amount of lint. Clean the unit with a brush and damp cloth inside and out reattach the unit screw first and housing unit and turn on. If the dryer again turns off unplug and youll see the clean filter light. Simply push the custom program light or anything similar and the panel should start working again. I hope this helps someone.
Aug 08, 2009 | LG DLE3777 Electric Dryer
Dryers Logo
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a LG Dryer Expert? Answer questions, earn points and help others
