Question about KVH DIRECTV D12 Satellite Receiver
SIMPLE REMOTE CONTROL FOR DIRECTV RECEIVER D12
I need a remote control for D12-100 receiver but only with POWER ON/OFF, CHANNEL UP/DOWN and MUTE buttons.. Do you have any SIMPLE remotes like this?
Try the Flipper.  Its a simple remote control that does what you are looking for.
Posted on Jul 04, 2010
  • simpleremote Jul 04, 2010
    Here is the link:  www.flipperremote.com
How do I setup my dvd to mt tv, i use direct tv
How to Program DIRECTV Remote Control ' DIRECTV ...
https://support.directv.com/.../how-to-program-directv-remote...
DIRECTVTo do this, press and hold the MUTE and ENTER buttons while pointing at your Genie HD DVR, Genie Mini, or Wireless Genie Mini. The screen will display Applying IR/RFsetup. To program your remote to control a regular HDTV (not a DIRECTV Ready TV) or audio devices, follow these steps: Press MENU on your remote.
How to Connect DIRECTV Receiver to TV ' DIRECTV Support
https://support.directv.com/.../how-to-connect-directv-receiver...
DIRECTVHow do I connect my DIRECTV receiver to my TV? Print. Email ... This will help you determine what cable to use to connect your receiver directly to your TV. ... For example, a DIRECTV receiver, DVD player, Blu-ray™ Disc player, o... How to ...
Remote Control Code Lookup - DirecTV
Dec 10, 2015 | Supersonic Televison & Video
Tip
DirectTV RC65 Programming
TIVO DirectTV RC65 Remote Control Programming
Here are the steps to program your TIVO Direct TV RC65 Remote Control:
  1. Locate the 5-digit code for your DIRECTV® Receiver. (See Users Manual)
  2. Power on the DIRECTV Receiver.
  3. Slide the MODE switch to the DIRECTV position.
  4. Press and hold the MUTE and SELECT keys until the green light under the DIRECTV position flashes twice, then release both keys.
  5. Using the number keys, enter the 5-digit code. If performed correctly, the green light under the DIRECTV position flashes twice.
  6. Aim the remote at your DIRECTV Receiver and press the PWR key once. The DIRECTV Receiver should turn off; if it does not, repeat steps 3 and 4, trying each code for your brand until you find the correct code.
Your TIVO DirectTV RC65 remote control is now setup to control your DVR. A digital copy of your remote's owners manual is available here.
Instructions for the RC65 Code Search function to find compatible remote codes are here.
I hope that helps.
on Apr 02, 2010 | Tivo DirectTV Remote Remote Control
D12 100 code
You can just call direct tv and they will be able to help you
Apr 17, 2012 | Sony RM-AV2500 LCD Touchscreen Remote...
How to program Direct TV remote
How to program your DIRECTV remote control:
Press MENU on remote.
Select "Parental, Favs and Setup".
Select "System Setup".
Select "Remote".
Select "Program Remote".
While aiming remote at device, follow onscreen instructions to program remote to TV, DVD, or other device.
How to program the white DIRECTV remote to your TV
Look up the control codes for your DIRECTV remote control.
Make sure your TV is turned on.
Slide the mode switch at top of remote to "TV".
Press and hold the MUTE button. This is located above the number 1 button.
While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
Enter the first TV code you have. The green light on remote should flash twice.
Aim remote at TV and press PWR button once. The TV should power off.
Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6, and 7, using the next code for your TV brand.
If remote control fails to program using all available codes, try scanning for the code.
How to scan for TV codes on your DIRECTV remote
While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
Then enter 9911, the green light on remote should flash twice.
Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
When the TV powers off, press and release the SELECT button.
Note: If the green light flashes three times before TV responds, then all codes have been cycled through. Our remote controls are guaranteed to program to your DIRECTV receiver, however your TV may not be compatible with our remote control.
You can find more help in the Remote Controls section of our Technical Forums at forums.directv.com. You can also use our Interactive User Guide to learn the ins and outs of your remote control.
Apr 11, 2012 | Audio Players & Recorders
Need rca crk17sa users guide for codes for Magnavox TV
Ok it took me a while. Go to this link to find the codes for you remote: 10054 is the most used code for Magnavox. I hope this helps you out. Good Luck!!!!!!!
http://www.directv.com/DTVAPP/content/remote_codes
Here's how to program your DIRECTV remote control:
  1. Press MENU on remote.
  2. Select "Parental, Favs and Setup"
  3. Select "System Setup"
  4. Select "Remote"
  5. Select "Program Remote"
  1. Look up the control codes for your DIRECTV remote control.
  2. Make sure your TV is turned on.
  3. Slide the mode switch at top of remote to "TV".
  4. Press and hold the MUTE button. This is located above the number 1 button.
  5. While still holding down MUTE, press and hold the SELECT button until the green light at the top of the remote flashes twice.
  6. Enter the first TV code you have. The green light on remote should flash twice.
  7. Aim remote at TV and press PWR button once. The TV should power off.
  8. Once the TV is able to power off/on and control the volume, slide the mode switch at the top of the remote back to the left (DIRECTV). Your remote is now programmed.
If the TV does not power off, repeat steps 4, 5, 6 and 7, using the next code for your TV brand.
  1. Make sure your TV is turned on.
  2. Slide the mode switch at top of remote to "TV".
  3. Press and hold the MUTE button. This is located above the number 1 button.
  4. While still holding down MUTE, press and hold the SELECT button until green light at the top of the remote flashes twice.
  5. Then enter 991, the green light on remote should flash twice.
  6. Point remote at TV and press CHANNEL UP button. Tap the CHANNEL UP button repeatedly until the TV powers off.
  7. When the TV powers off, press and release the SELECT button.
Mar 08, 2010 | Televison & Video
DIRECTV RECEIVER
Restart and on the first screen press 02468 it will force firmware update this should also remove "everything". If this doesn't work call Directv I know they can do it with the Rec. and Card #'s
Mar 13, 2009 | Directv D12-300/100 DTV Receiver
I have a Directv RC24 remote control. I am trying
Programming DIRECTV Remote
1. Locate the DIRECTV Receiver's brand and model number
(on the back or bottom panel) and write it in the
spaces below.
2. Locate the 5-digit code for your DIRECTV Receiver (see
page 10).
3. Power on the DIRECTV Receiver.
4. Move the slide switch to DIRECTV icon.
5. Press and hold in the MUTE and SELECT keys until the
green light under the DIRECTV icon flashes twice and
6. Using the number keys enter the 5-digit code. If performed
correctly the green light under the DIRECTV icon
will flash twice.
Magnavox codes:
11454, 10054, 10030, 10706, 10179, 11254
7. Aim the remote at your DIRECTV Receiver and press
that the power key once. The DIRECTV Receiver should
turn off. If it does not turn off, repeat steps 3 and 4, trying
code.
8. For future reference write down the working code for
your DIRECTV Receiver in the blocks below:
Once you have programmed the DIRECTV remote control for
your TV, you may want to activate the TV Input button.
1. Move the slide switch to the position under TV icon.
2. Press and hold the MUTE and SELECT keys until the green
light under the TV icon flashes twice and then release
both keys.
3. Using the number keys enter in 9-6-0 (The green light
under the TV icon will flash twice)
You now have the ability to control the Input select feature for
your TV.
Feb 20, 2009 | Directv RC24 Remote Control
What Universal Remotes Will Control A DirecTV D12-300 Box?
Some of the new Radio Shack universal remotes will work .diff types out there .i would start there first
Mar 15, 2008 | Televison & Video
Jumbo Universal Remote Control
DIRECTV all models 00001, 00002
also use 200-217 from the jumbo hand book good luck
please rate
Dec 24, 2007 | RCA DIRECTV Satellite Remote Control
KVH DIRECTV D12 Satellite Receiver Logo
321 people viewed this question
Top KVH Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a KVH Audio Player and Recorder Expert? Answer questions, earn points and help others
