Question about Brother ML-500 Typewriter
Can't type @ sign
When I type @ it prints a "n" with a "~" above it.
    Champion:
  • 207 Answers
In ascii ñ code is 164 while @ code is 064. I'm not familiar with typewriters but if it allows characters to be imputed like on PC than press Alt and while holding it type 064. Perhaps codes are mixed for some reason so you can try same thing with 164.
Posted on Apr 17, 2008
How do i use the euro sign?
If the euro sign on your keyboard is above the number 5 simply press and hold shift while pressing 5 and it should type it.
Mar 28, 2014 | Logitech Computers & Internet
How to type pound sign
You are most likely in KBII mode. There should be a slide switch or a top row key with KBII printed above it that requires the code key to turn it off.
DickyO
Jan 21, 2013 | Brother ML-100 Typewriter
Typewrite keys
Above the top row of keys are written things, one of them should be KBII Hold the Code key and press that key, now the other symbol will print
DickyO
May 20, 2010 | Nakajima AE-830 Typewriter
Hp 2100 lazer jet printer will not print with new laptop vista
Many drivers that were supported by X are not supported by Vista. Suggestion to solve this and the numerous problems you will encounter is to revert to XP. Untill then, do the following.
Remove printer
1. Click the "Start" button, type PRINTER in the search box and press Enter.
2. Find the icons which are related to HP LaserJet 2100, and delete them.
3. Right-click on the blank part of the window, and choose "Run as administrator"->"Server Properties".
4. On the Drivers tab, select the listed printer and click the Remove button. Please then select Remove driver and driver package.
5. Open Start menu, input APPWIZ.CPL in the Search box and press ENTER to launch "Programs and Features".
6. Try to remove all related printer software.
Then, please download the latest drivers from the following website and install.
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=14914&prodTypeId=18972&prodSeriesId=25469&swLang=8&taskId=135&swEnvOID=2093
If the above steps do not work, please follow the steps below to clear Printing Subsystem and reinstall the driver again.
Click "Start", type "regedit" in Research Bare and press "Enter". Browse to the following registry key by clicking the PLUS (+) sign:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Printers
Click the PLUS (+) sign to expand Printers key. All current printers installed on your computer are listed there. Please right click each subkey in it on the left pane and click "Delete".
Step 2. Browse to the following registry key:
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control\Print\Environments\Windows NTx86\Drivers\Version-3
Click the PLUS (+) sign to expand "Version-3". All printer drivers which have been installed on your computer will be listed there. Please right click each subkey in it on the left pane and click "Delete".
Step 3:
Locate and then expand the following registry key
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Print\Monitors
View the list of subkeys. There should only be the following subkeys for the default print monitors:
BJ Language Monitor
Local Port
PJL Language Monitor
Standard TCP/IP Port
USB Monitor
If there are any subkeys other than the subkeys that are listed above has to be deleted. To do this, right-click each subkey that is not on the list, and then click Delete. Click Yes when you are prompted to confirm the deletion.
Step 4:
Restart your computer and start pressing the F8 key on your keyboard.
Go to safe mode.
Open "My Computer" and browse to the folder:
Go to the Following folder
(i) C:\Windows\System32\spool\prtprocs\w32x86
(ii) C:\Windows\System32\Spool\Printers
(iii) C:\Windows\System32\Spool\Drivers\w32x86
And then delete all the files and the folders in the following 3 folders.
Check Whether the Spooler services is Working Properly.
Then try to install the latest Windows Vista driver again.
Hope it helps
Jul 26, 2009 | Encore ENPS-2012 3-Port 10/100 Printer...
Not printing in foxpro 2.6 dos to hp laser jet 1020
You write "type the above line at command prompt". I dont't know Where exactly to write? Can you tell me!
Feb 05, 2009 | HP PSC 1610 All-In-One InkJet Printer
Slash / sign and other symbols
Hold down the shift button and press the letter V. Everything printed above the letters on the background of the keypad can be printed by holding down the shift key and pressing they letter key.
Hope that helps.
Jan 24, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Faint type on metallic refills
Faded print is nearly always the 1st sign the batteries are nearly worn out - try new batteries. (it could be that metalic tape requires more power to print than the paper tape)
Jan 18, 2009 | Dymo LetraTAG Thermal Label Printer
@ sign
Could you be using an inappropriate keyboard layout?
Most common issue is US vs UK keyboards, which have the " and the @ sign transposed.
Try typing " and see what you get.
If your @ is above the 2 then you need a US keyboard layout.
If your @ is above the ' then you need UK layout.
If this is the issue, you should be able to change the setting in the "keyboard" part of the control panel.
Sep 12, 2008 | IBM ThinkPad T40 2373 Notebook
@ sign
Does it always print the same thing in place of the @ sign? If so you probably have a non standard printwheel.
DickyO
Aug 28, 2008 | Brother ML-300 Typewriter
How to get the @ sign
You should just have to hold the shift key down and type the @
Aug 10, 2007 | Brother ML-100 Typewriter
Brother ML-500 Typewriter Logo
133 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
