Question about GE GSS20IEP Side by Side Refrigerator
Pops plug in pops gfi
    President:
  • 1,891 Answers
Ref should not be on g f i / and it's prob a bad gfi // try running it on a contractor et cord 3 wire # 12 or better and it will probley work . and if so replace the gfi . mm
Posted on Jul 04, 2010
What would cause intermitant pop of ground fault. only thing on the line. ground fault has been replaced
Refrigerators are not recommended to be plugged into a GFI outlet. Depending on the age of the fridge there will be spikes in the current the fridge uses at certain times causing the GFI to trip. A GFI outlet is much more sensitive to current than a non GFI outlet that is tied back to the the regular breaker in the electrical panel. Pleazer Appliance...
May 06, 2014 | Whirlpool Refrigerators
When my Mark 6 does its job and shocks a cow it pops the GFI that it is plugged in to. How do I fix that?
Replace the GFI with a standard plug. the unit has its own ground return which cause the GFI to trip.
Jul 10, 2011 | Parmak Solar Fence Charger
No power to the refrigerator. Plug it in and it pops the GFI
Try plugging into another receptacle,possibly your GFI is defective.Could be a bad compressor, shorted wire, shorted defrost heater. A good tech should be able to diagnose your problem quickly.
Nov 23, 2010 | Kenmore 57029 Side by Side Refrigerator
When plugged in the gfi pops what could this be?
HI
If you are just popping the gfi, you probably have a leak the is dripping onto a part of the main circuit. If you are tripping a breaker you have a dead short. Both need to be taken care of.
Apr 15, 2010 | Saeco Magic De Luxe Espresso Machine
Washing Machine Pops GFI Circuit
I agree. could be heater or motor..try disconnecting one wire on heater then trying if still same try unplugging motor plug ...this will say which one..please leave feedback..
Apr 07, 2010 | Fisher and Paykel GWL11 Top Load Washer
Side by side running all day door left adjar. blew gfi reset but not running is there a reset button for the compressor
It could have popped the gfi plug , when in defrost . It can draw up to 6 amps in defrost . Use an extension cord to another outlet not gfi . If in defrost when popped , after plugged in for a little while (28-32 min) , it should cycle on . I wouldn't leave it permanently on extension cord , but replace that plug behind fridge to a normal plug (not gfi) .
Aug 27, 2009 | Whirlpool Refrigerators
Genrator pops braker
GFI's and motor's don't get along with each other,if the motor is just the slightest bit of any moisture,the GFI will pick it up as a ground...Try to run it without the GFI.
Dec 17, 2008 | Coleman Powermate Powermate 5000W...
Fridge is popping my GFI switch
refrigerators are not supposed to be plugged into gfi outlets as they can operate normally and still trip the gfi protector. try plugging the unit into an unprotected outlet and it should work fine. incidentally you'll probably have to replace the gfi outlet as it has probably weakend from being used on the refrig.
Jul 04, 2008 | Frigidaire FRS23R4A Side by Side...
GE GSS20IEP Side by Side Refrigerator Logo
53 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
