Question about HP Compaq Evo n610c Notebook
Windows xp will not load goes to compaq screen then will not load in safe mode, with networking, or with command prompt, last known good configuration or restart normally, goes to windows start up, but immediately stops and goes to a blue screen too fast to read, and goes back to compaq screen. i do not have the system recovery to factory defaults disc
  • Adnan Bhatti
    Adnan Bhatti Jul 03, 2010
    During boot, press F11 repeatedly to restore from hidden partition.
    Sergeant:
    Champion:
  • 324 Answers
Run scan disk from bios, sounds like you have alot of disk errors
Posted on Jul 04, 2010
  • German Isales
    German Isales Dec 24, 2010
    Sup guys i found the cure to this horroble blue screen death for this N610c. Ok i called hp and they wanted $69.99 for tech support well just imagine what i told them to do lol. Anyway i did my research and guess what i found out. That the updated driver is made to screw up your connection so that you have to call tech support and they can steal your money.
    Im a computer technician since 1990 and what i discover was that beautiful driver that works here is a list of drivers that cannot be used on the Evo N610C because it causes conflits that no one can fix i know for sure.
    List of the no no drivers are:
    These drivers will make your screen go from windows to BLUE.
    ap29156
    sp28252
    sp29156
    Here is how i fixed the problem i deleted everything that had to do with LANMultiport drivers every single one then i searched my laptop to remove the rest of the lost files.
    Once that was done the i installed this driver (sp23031)
    Once that was installed and the puter rebboted the wifi card found my wireless connection and asked me to input my Network Key and walla it works great now without any problems.
    Im using windows XP Home i just bought memory cause im installing windows 7 32 bit.
    Finally the key is this driver (sp23031) for both home and pro eddition.
    Here is the link to download your driver:
    http://h10025.www1.hp.com/ewfrf/wc/softw...
I need to do a System Restore on a Gateway 7322 Laptop
try running this virus FREE prog No cost- removes too...: http://www.f-secure.com/en_EMEA/security/tools/online-scanner/
Jun 29, 2010 | Gateway 7322GZ Notebook
Unit wont start, gray screen then goes to a screen with options on how to start unit and then goes blank
Answer:To load the last known good configuration in Windows 2000 / XP reboot the computer and as it's booting booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Last Known Good Configuration" and press your Enter key.
Trouble Getting into Windows 2000 or Advanced Options menu - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message as the computer is booting. If this occurs instead of pressing and holding the "F8 key" tap the "F8 key" continuously until you get the startup menu.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
As can be seen from the above example, you should be able to highlight and press enter to load the last known good configuration. Once completed the computer should restart and attempt to load into Windows.
Will running the Last Known Good Configuration delete anything?
No, running the last known good configuration will restore your last good system settings and will not delete anything. The only thing you may have to reinstall programs you have recently installed because the configuration for those programs may have been lost.
Jan 27, 2010 | NEC Versa VX Notebook
Will Not Boot/Keeps Rebooting
suspected hard disk faulty or OS corrupted.
to check, take out your hard disk and put it in other laptop. if the problem persist your OS is corrupted. In that case, you need to reformat your OS in a defaulty factory settings.
May 22, 2009 | Compaq Presario R3000 Notebook
Computer continually rebooting problem
You could try a windows repair install.
Apr 19, 2009 | Compaq Armada E500 Notebook
Laptop Will Not Boot
chose start windows normaly
Apr 14, 2009 | Acer Aspire One PC Notebook
HELP!! (dell precision 340) im getting 4 screens when i turn on m
Reboot into Safe Mode by repeatingly tapping on F8 while in process of rebooting and then select "last known good configuration". If that fails reboot again to safe mode and select safe mode with command prompt and in the command prompt type "chkdsk /f /r " <enter>
If that doesnt work do place your Windows CD into the Cd-Rom, reboot and select option "Repair"
Jan 02, 2009 | Dell Precision 360n PC Desktop
My compaq Presario V6000 will not start windows, it continously loops to an options screen with the following start options; Safe mode, safe made with networking, Safe mode prompt command,Windows last...
what you are describing is the blue screen of death, meaning theres a hardware or software problem, try to boot into safe mode and perform a system restore, if that doesn't work use your XP cd, let it load the drivers and the ask it to fix the existing XP installation, anything that you have saved in my documents should be safe and the problem should be solved. If the blue screen reappears then you have a hardware problem
Nov 13, 2008 | Compaq Computers & Internet
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Evo n610c Notebook Logo
157 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
