Question about Panasonic Lumix DMC-FZ20 Digital Camera
Dropped into sand has sand in zoom and won't work now
    Brigadier General:
  • 11,967 Answers
There's nothing you can do without causing further damage...you need service.
Posted on Jul 03, 2010
Toshiba camileo H10 camcorder. No picture. Screen shows Zoom 1 fail E AF PI fail /.
Hello Charles,
Just to be sure it is NOT a software issue, remove the battery then replace it back after about 5 minutes and then try turning it ON again.
The error you are getting is a "zoom error". A problem connected with your camcorder's optical zoom not working, it is either it has broken parts or something is caught in the zoom mechanism.
If something serious happened to it, like if it was dropped accidentally or a force was applied to it, then it is probably broken parts inside and needs servicing. Otherwise, it could be just dirt or sand stuck inside the mechanism.
To try and resolve the problem with dirt/sand you can:
Hold the camcorder with the lens facing the ground, then tap the side of your camcorder repeatedly.
OR
Use a canned air and spray it into the lens area of your camcorder.
Oct 21, 2011 | Toshiba Video Cameras
How do I get sand out of my OlympusFE-100? Dropped it in the sand now it won't turn on. When it tries to turn on the zoom just goes out and in several times and then it shuts down. I am hoping that I can...
I would be hesitant about cleaning it out yourself. If you use canned air, then you may make the problem worse by blowing sand deeper into the works. If you disassemble, critical alignment of the lense may be lost.
Take the camera to a Wolf's or similar, and see what they can do for you.
Jun 30, 2010 | Olympus Camedia Brio D-100 Digital Camera
Error zoom
Sorry, it needs to go in for service.
Usually this type of fault happens due to sand/ grit in the mechanism or it has suffered a knock/ drop.
If it is grit/ sand then they may just clean the lens mechanism.
If it has suffered an impact, then it will probably need replacement.
Sorry for the bad news.
Cheers.
Sep 22, 2009 | Panasonic Lumix DMC-LX3 Digital Camera
Digital camera got dropped into the sand, and some sand worked its way into the lens and focusing system, and now the camera cannot zoom or focus, but still turns on and takes pictures i have a lumix dmc...
THIS SOUNDS TERMINAL, BUT YOU MIGHT TRY USING CANNED AIR LIKE YOU USE TO BLOW DUST OUT OF YOUR COMPUTER, AND SEE IF IT HELPS ANY. MOST OF THESE CAMERAS ARE MADE WITH THE IDEA THAT THEY WILL NEVER BE TAKEN APART OR OPENED FOR CLEANING ETC. SO, THAT IS THE ONE PROBLEM YOU ARE FACING. I DOUBT IF IT WOULD BE WORTH SPENDING THE MONEY TO SEND IT IN TO BE CLEANED. THAT CAN GET VERY EXPENSIVE IN A HURRY, PLUS TAKE A GOOD MONTH OR MORE FOR THE REPAIR. SORRY, I CAN'T HAVE MORE CHEERY NEWS, BUT THINGS LIKE THIS JUST AREN'T TAKEN INTO ACCORD WHEN THEY MAKE THESE CAMERAS. IF I CAN HELP MORE JUST REPLY TO:
ARCLIGHT1217
Nov 04, 2008 | Cameras
Cant zoom on my DSC-W80 sony cybershot after droping it in the sand at the beach
If you found good information in my solution, please be sure to rate it! Thanks!
Oct 25, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Zoom Error
I think a grain of sand was blocking the zoom tubes. This will not work if the camera has been dropped & the zoom apparatus is bent. It is entirely at your own risk & may invalidate any guarantee but they may charge anyway if you have got sand in. I cut a finger of 80gm computer paper 1cm X 5cm. Inserted this first  around outer zoom tube & worked it all around. It goes in quite deep so be gentle. I switched on to open zoom & tipped out batteries before it had time to close & repeated procedure. When I put batteries back in it worked OK. I repeated procedure with lens fully extended. I found a thin bit of plastic packing worked better as it did not kink so easily. It is still working today having failed 100% before.
Chris
Jul 02, 2008 | Cameras
Zoom Error
We had this problem for about 2 weeks, we discovered that having the camera auto retracted after the "ZOOM ERROR" message, giving the camera couples of light slaps (slap the camera's LCD side and aim the camera down), this fixed the camera right away
Mar 03, 2008 | Olympus SP-550 UZ Digital Camera
Zoom Lens
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension.
Here's some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but they're still worth a try:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 11, 2008 | Fuji FinePix A303 Digital Camera
Sand in camera
no need to take apart just power up and gently pull the lens out and vaccuum the sand out, camera now works perfectly
Nov 09, 2007 | Casio Exilim EX-Z57 Digital Camera
Panasonic Lumix DMC-FZ20 Digital Camera Logo
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
