Question about Bose Wave Music System CD Shelf System
Our Bose Wave System Model #2000 won't play CD's. Occasionally CD's play most of the the time they do not. Radio is fine. Thanks, Gordon Dickey
hawkwatcher
  • 67 Answers
SOURCE: Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
Posted on Jan 18, 2008
SOURCE: BOSE WAVE RADIO/CD
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Posted on Mar 20, 2008
SOURCE: Bose Wave Radio w/single CD player on top
My Bose Wave Radio/CD developed this problem about a year ago. I don't use the CD player much and kept the unit clean. The disc spins but, the system does not read it. Cleaning the lens with cotton did not help.
Read that Bose charges $75 to fix this problem.
Posted on Sep 24, 2008
  • 20 Answers
SOURCE: Non-working CD in Bose wave radio
Try replacing the battery on the bottom of the system - alot of people miss it because you have it constantly plugged into the mains, but replacing this (somehow) re-sets the system, and 9 times out of 10 solves the issue.
Posted on Dec 31, 2008
VOTIT
  • 2071 Answers
SOURCE: Bose Wave System CD does not eject
Just unplug your power supply for 3 hours to reset the unit and to dissipetate power surges.
Hope it may helps;
Posted on Jun 12, 2009
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
I want to play my iPad through my boze radio
What is the model number of your Bose Wave?
May 24, 2012 | Bose & Wave& Music System
Bose wave awrc-1g cd player spins but does not play.
You have done what i would have suggested, the Bose Wave unit will need to back to Bose for service, and there is a good chance they will need to replace the laser pickup assembly and cost should be considered even thoe it is top of the line.
Apr 02, 2012 | Bose Wave radio/CD remote control -...
My Bose Wave radio/cd won`t play cd`s anymore. The radio works great. The cd player worked tonite, the would stick in a certain part of a song. Very intermittent. Now tries to read the disc, then says disc...
"I`ve used an aerosol air can to clean thru the cd slot"What type? not an "empty" can of paint, hairspray, chemical of some sort i hope. Compressed air at most I hope. If not, that's your Bose out the window!
The lense sounds like it needs a clean, you can buy these in disc for with tiny brushes on. Made by BIB and Allsop amongst many brands
Aug 30, 2010 | Bose Wave Music System CD Shelf System
Can't play burned cds through bose
get a 3.5mm male to 3.5mm male cable(one end to the laptop headphone jack and the other end to the AUX jack of the Bose wave music system), you are good to go...
Jan 01, 2010 | Bose Wave Music System CD Shelf System
Having trouble getting CDs to play
clean the lense that senses the CD. had same problem, cleaned with damp tissue, problem solved
May 04, 2009 | Bose Wave Music System CD Shelf System
Recorded audio CD will not play
Most likely the recorded format is wrong and that is the cause.
May 05, 2017 | Bose Wave Radio
No power
Unfortunately Bose will not release their schematics or parts lists, effectively giving them a monopoly on repairs. Their web site, www.bose.com, offers to repair most Wave radios for $100 or to give owners of broken sets a $200 allowance towards the purchase of a new Wave. Before spending the big bucks though, you might want to check out the new HD radios. Better sound and a MUCH lower price.
Nov 11, 2008 | Bose & Wave& Music System
Bose Wave Radio with non-Bose speakers.
bose cd will not work but radio is fine
Jul 28, 2008 | Bose & Wave& Music System
Cd play problem
Laser is dead. Call bose and they will service it for you for about $75.
Aug 17, 2007 | Bose Wave Music System CD Shelf System
Bose Wave Music System CD Shelf System Logo
81 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
