Question about Dell Inspiron 9400 Notebook
Laptop screen has vertical lines of garbage 3/4" wide about 3/4" apart. sound system starts making choppy noise after only few minutes powered up. Trying to fix this laptop for a friend - I'm a desktop hardware guy, not super familiar with laptop, but have had good luck in the past. This sounds like a mobo problem, but not sure. Need advice, next steps
  • 1 more comment
  • Adnan Bhatti
    Adnan Bhatti Jul 03, 2010
    I would suspect the RAM first. Download RAM test tool from Microsoft (search on Google), and follow the instructions to scan the RAM. If possible, try to run with only one RAM stick or a replacement if available.
  • nvjeffhoagla Jul 06, 2010
    I will definitely give that a shot, as this is something i was suspecting as well. It's definitely something along that line. The video problem maintains even when running an external monitor so it lends support to this theory. One question though - It doesn't appear to finish booting - no windows desktop or other indications of booting completed show up - can you recommend a command line tool or something that can run in a shell?
  • Adnan Bhatti
    Adnan Bhatti Jul 06, 2010
    You can try HirenbootCD or Spinrite. Search using Google but you may have to pay to use. Try looking for a free DOS boot CD. Anyway, if the RAM is malfunctioning, it can also stop Windows from booting properly. If there had to be hardware fault, I'd choose the RAM as it is easier and cheaper to replace. If it is the chipset or any other SMD, you laptop may need a new motherboard. Just try another RAM and see if it helps.
    Brigadier General:
  • 10,406 Answers
Connect an external monitor to the VGA-output port on the laptop, to see if the video-effects are being caused by the video-card, or by a damaged "internal" LCD screen on the laptop.
Take any genuine Microsoft Windows XP/Vista/7 CD/DVD disk, and "boot" from it. Do the vertical lines appear when booting? If so, you have a hardware problem. If not, then only the currently-installed version of Windows is messing-up your display.
If all else fails, backup all the user's files to an external device, reformat the disk-drive, and reinstall Windows, to see if it's a messed-up version of Windows that is causing the symptoms.
Posted on Jul 03, 2010
Vertical lines appear on my screen on my toshiba sattelite p105-s6147 laptop computer.
looks like the pixels are going try anther screen it should work ok
Jan 08, 2013 | Computers & Internet
Sanyo DP46848 LCD TV has black screen with colored vertical lines
If you wish to get some details; visit the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jun 16, 2017 | Sanyo DP46848 LCD TV
Rolling lines on screen
Sounds like the power supply has a bad capacitor. This problem can inject excessive 60 hz from the AC line into the vertical stabilizing picture system. The hum also my come from the same reason, bad or leaking filter capacitors. Cheaper just to buy a new TV or borrow another TV and connected to your system to see if the problem still occurs.
Mar 16, 2009 | RCA F36668 36" TV
New Garbage disposal, washing machine and dishwasher won't work.
Does not sound like these problems are directly related to the disposer. Grinding sound is most likely the impeller on the washer's pump. The washer gets to the first pump out and is unable to pump due to bad impeller or an obstruction. Bad impeller means replace pump motor. (not very hard) Check water supply to dishwasher. Valve turned off or line kinked? Filter screen at solonoid valve plugged?
Aug 15, 2008 | LG WD-3243RHD Front Load Washer / Dryer
Power went out while tv & Direct TV was on
The garbage on your unused channels are not important, just artifacts from signals not strong enough to produce a picture.
The 'blue screen' on #3 is what many sets use when they sense they are connected (terminated) to 'something' but not receiving any signal.
If sounds a lot like DTV's receiver took a hit.
If you have a second set you can borrow or drag to the receiver, try it first but I don't think it is your problem unless the cable input on it was zapped.
Jul 12, 2008 | Televison & Video
Toshiba 27
you just say horizontal lines / and across a top of your television.I expect your trouble is the vertical line of your television . sound ok? try trouble the vertical section the check the resistor?
Apr 19, 2008 | Televison & Video
White vertical line on left side of screen
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
Samsung DLP HLR5668W has mostly dark picture + grinding noise
Pix looks like a light pipe issue, inside the Light Engine. as far as the shutting down, could be a bad fan causing the grinding and when stopps the DMD turns the set off.
Jul 08, 2007 | Samsung HL-R5668W 56" HDTV
Green vertical lines on the screen
Sounds like you may have some bad filter capacitors in the convergence board. Better take a close look at them before they damage the chips. Good Luck
Ed
NC Electronic
Mills, Wyoming
Nov 15, 2006 | Hitachi 42V710 42" Rear Projection HDTV
Dell Inspiron 9400 Notebook Logo
420 people viewed this question
Alun Cox
