Question about KitchenAid Architect Series KEMC308KSS Electric Double Oven
Kitchenaid Architect Electric range model KESA907PWW02 Error F2E0 STUCK KEY. Can't get rid of this error. Have shut off breaker for several hours -problem comes right back.Any ideas? Thanks M.S.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error F2-E0 on your kitchen aid means that the keypad is shorted and to resolve this issue you’ll have to replace the electronic range control/clock (ERC). Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 03, 2010
Kitchen Aid Superba double oven
f5e1 is a door locking error. try shutting off power for a minimum of 2 minutes to reset the control board. If you still get the error replace the latch. Here is the part to order.
Jun 19, 2013 | KitchenAid Architect Series KEMC308KSS...
Fault code F2E0
Your key pad is shorted.Replace the electronic range control clock.
Mar 17, 2012 | KitchenAid Architect Series KEBC107KSS...
Error reads F2E0? Can anyone tell me what this means?
Need model off range . Pull out the drawer and is on the side of opening
Nov 20, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
After a power outage my oven is unable to work
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.(((((((((
Jun 06, 2010 | KitchenAid Architect II KEBK206SSS...
Have JKP86 oven and the controls on the oven do not work. Get an F7 error code
The F7 error code on GE ovens indicates either the control has detected one of the key pads on the interface/control is stuck or the clock ( ERC ) itself is faulty.
The first step in determining if it's simply a stuck key pad is to push the cancel/off key ( If you haven't already ). If that fails to clear the error try to shut off the 40amp breaker to the range at the service panel, leave it off for several minutes and upon resetting it the error will either return or the issue was a stuck key pad and you're good to go.
If the error does return after turning the power back on, you'll likely require a new ERC ( clock/timer ) unfortunately.
Hope this was helpful in moving you forward. Thank's for visiting "fixya" today and good luck.
Please take a moment and rate the information provided here accordingly.
macmarkus :)
Apr 10, 2010 | GE JKP86 Electric Double Oven
Getting an error code on the display F2E0 (stuck key). When I was wiping off the display. Is there a way to reset this?
Sometimes you can get lucky by pressing all keys at random several times each. If that does not work you will have to replace the keypad.
Oct 09, 2009 | KitchenAid KEBC101 Electric Single Oven
Oven preoblem kitchenaid ykers807sp "err f2e1 stuck/shorted key " showing
If you've determined the keypad on your Kitchenaid oven, range, or wall microwave is faulty and youre searching for an obsolete part, http://www.FixYourBoard.com has replacements by Ledgestone Technologies. These units are backed with a 2 year warranty. Save your $ and save your oven from the landfill. We have you covered! Call 512-355-1108 for more information and to order. We're happy to help you solve your problem!
Jul 17, 2009 | KitchenAid Architect Series KEBC107KSS...
Lost power now oven won't do anything...
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.^^^^^
Aug 07, 2008 | KitchenAid Architect Series KEBC208KSS...
Error code
I called the salesman where I bought the oven, and he used to be an installer.  Suggested flipping circuit breaker off/on.  It worked, and oven works for now.  However, something must be wrong to require this intervention.  Another web site (www.repair-help.com/kb/index.php?article=30) listed the F6 codes as possibly having something to do with improper grounding.  So we will get a service call.
Aug 06, 2008 | KitchenAid Architect Series KEBC107KSS...
Kitchen aid oven not heating up
THERE IS OVENSHUTDOWN THERMAL FUSE IN THE BACK THAT WILL SHUT DOWN THE ELEMENTS. I AM LOOKING FOR THE FUSE.
Jul 20, 2008 | KitchenAid KEBC107 Electric Single Oven
KitchenAid Architect Series KEMC308KSS Electric Double Oven Logo
461 people viewed this question
Top KitchenAid Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a KitchenAid Oven Expert? Answer questions, earn points and help others
