Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
Brush roller not working on Bissell proheat 7920
Took off brush to clean and doesnt seem to want to work when in cleaning position.  only spins when standing upright
My brother changed the roller belt, but now the rollers won't stay up so I can move the cleaner and the water isn't getting sucked up.
Posted on Apr 28, 2008
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Won't spray wate rwhen you press trigger.
When the water won't dispense that usually means that the pump belt is usually stretched or broken. Here is a link to the belt you need and a manual you can view:
Bissell 7920 Belt and Manual
Dec 03, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920. Took it apart how do i align the solution valve
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
fggds
Nov 23, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
How do I take apart my Bissell 7920 ProHeat Pro-Tech
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Here is a tip that will give you all the information you need to fix your Bissell Proheat Vacuum Problem.
heatman101
Jul 16, 2009 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 doesnt spray liquid
Ive oredered the pump belt and brush. after receiving and fixing them i will test the spray if it works.
Aug 18, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
I took off the brush roller to clean it and now I can't get the roller to work unless the machine is standing upright. The side that's not connected to the belt keeps falling out.
The solution for your situation is as follows: You need to put the retraining clips on over the arms to properly put them in place You most likely put the retaining clips on too early.
Apr 17, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
No carpet cleaner coming through
I had exactly the same problem with my five-year old my Bissell 7920, and it's probably a broken pump belt.  See page 19 of your instruction manual for how to replace.  The Bissel ProHeat belt accessory pack costs $3.99 and you get a pump belt and a brush belt.  Since you have to first remove the brush belt to get to the pump belt, you might as well replace both. The first time I did this it took me 15 minutes, but now that I know the drill, doing a belt replacement would take about 3 minutes.
Apr 06, 2008 | Bissell 7920 ProHeat Pro-Tech Upright...
Change the belt on the brush
Dear Norrfam87,here is a website with the manual for your Bissell 7920.
http://www.bissell.com/images/UserGuides/7920.pdf
On page 18 and 19,they tell how to replace the belt !
I hope this helps,EarlsOK
Dec 08, 2007 | Bissell 7920 ProHeat Pro-Tech Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
215 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
