Question about Gemini Sound Products iKEY
Hi recorded a file on my ikey under .WAV but now cannot play it. Does anyone have any ideas what went wrong , the file is fairly big could it be this?
  • tassi75 Jul 03, 2010
    Hi, it just did not allow me to open the file or move it
    Brigadier General:
  • 10,406 Answers
Yes, it's possible that it could take a while to "open" a large file. How long did you wait before declaring that it "cannot" do it? Any error-messages?
Posted on Jul 03, 2010
I did not convert my files into the wav format and my hard drive crashed. Was able to get an expert to recover data, but we cannot find the files for the 43-127 telephone recorder. Does anyone know the...
The RadioShack 43-127 Digital Voice Recorder records in .wav format.. You don't have to convert anything. It records, saves, and transfers what it records as .wav files.
RadioShack Digital Voice Recorder 43 127 Records Telephone Conversations
Unfortunately, when hard drives crash, data stored on them is often lost due to corruption to the magnetic surface of the discs themselves, or to actual physical damage. If no .wav files are able to be seen, they may have simply been lost.
If those files still exist and are able to be retrieved from the disc surface, they will be in the same location within the directory structure that you originally saved them to.
Sep 20, 2017 | Radio Shack TRC300 Voice Recorder
Making Midi Files for Importing to Tascam 2488
You should always work in wav format if possible because there is a loss of quality with mp3 which is a compression format in which bits are lost in order to compress the file size.
There are a number of wav editors available which will allow you to load a stereo wav and then save it as a mono wav. The free one I use is called Audacity.
When working with FL or Reason I will sometimes import files to the Tascam, or I will take the outputs from my PCs sound card and line them into the tacams inputs and record them live. I only tend to do this with programs (like synths) where I am using an external midi keyboard and can play live what I want to record.
With basic drum pattern tracks I'll usually create them on the PC, save as wav, convert to mono, and then import to a track on the Tascam.
hope this helps.
bd.
Jun 25, 2009 | Tascam 2488 Portastudio Multitrack...
Mikomi ET858 digital voice recorder suddenly switched from saving files as .WAV to .ACT, whatever that is. Can play interviews on machine itself, but can't save them to computer. Help! How do I switch it...
Hi all,
I recently bought this little headache of a dictation machine to help me with my Law revision. Had similar problems but have worked out the following:
The machine appears to have 2 modes of recording - LP and SP. When the machine is in LP mode, it appears to be a format for the machine itself to allow for longer record time. Because of this individual format it will not play back on computers. If, however, you change it to SP mode (from what I can ascertain from the VERY unhelpful user manual is 'high quality recording' i.e. standard WAV format) it saves the file in a .wav format which is playable on computers.
To switch it from LP to SP (this is on my dictation machine only - i take absolutely no responsibility for breakages etc):
Turn on
Press 'M' to cycle to 'REC' mode
Use the Volume control to cycle between SP, SP VOR (no idea what VOR is i'm afriad), LP and LP VOR
Record as usual.
I've made test recordings on both SP and SP VOR and both save to WAV format and can be played back through a computer.
If anyone knows what VOR is then please shout back.
Hope this helps.
Liam
Apr 10, 2009 | Dictaphone Walkabout 5210 Digital Voice...
I have an RCA Rp5120-a digital voice recorder. I have been converting my files to wave than to mp3 files. Now everytime I try to transfer them I am told the file is corrupt and cannot be copied! Does...
first bring it in on a pc use the soft ware in the rca recorder then save as a wav because ti is voc file..so now it is a wav file you canplay a wav file if you can't.open it in quictime and save it in quicktime and every plays QT. thank you hope this works
Apr 04, 2009 | RCA RP5010 Digital Voice Recorder
I recorded two hours of music from the FM radio using my JNC SSFM2 series MP4 player. The firmware version on the player is BKSD01NB22_32 2007-10-30 9.1.52 2005-01-09 When I stop recording I am able...
The recording from radio that did not want to work in iTunes was made in WAV format. To solve the problem I went to settings and changed recording format to MP3. When I recorded in MP3 format from the radio with my JNC SSFM2 series MP4 player and copied it into iTunes on my computer, iTunes played it without a problem.
Apparently WAV format is used on PC and MP3 is used on Apple Mac.
Jan 05, 2009 | JNC Computers SSF-M2 Digital Media Player
T sonic 630 4GB recording has only bells 30 secs no voice!
The system should support the .wav format. install latest version of media player
Dec 23, 2008 | Transcend T SONIC 630 MP3 Player
Computer to FAT patition to DP01
The DP01 needs wav files to be in mono in order to import them. Make sure you're not trying to import stereo wav files.
Jan 24, 2008 | Tascam DP01 All-In-One Recording Package...
.voc files
right click on your files on the recorder then go to make .WAV file to save to your computer and be able to play it. hope this helps!!
if anyone has the software that came with this recorder i could use a copy i lost mine...
tubby365@yahoo.com
thanks!!!
Jan 13, 2008 | Audio Players & Recorders
DENPA WAV FILES CORRUPTED!!
Hi Guys,
I have the same corrupted file, but you can recover it by using the GoldWave software. Just type"Goldwave" in google, follow the link and download the software, install it. From that software open the corrupted file, and then save it as a new copy. ( It will fix the problem when opening the file, where you can see it). They try to play the new saved file, shld be fine.
all the best.
Oct 30, 2007 | Denpa USB-24 Digital Voice Recorder
Gemini Sound Products iKEY Logo
49 people viewed this question
Top Gemini Sound Products Computers & Internet Experts
David Payne
David Payne
Are you a Gemini Sound Products Computer and Internet Expert? Answer questions, earn points and help others
