Question about HP Photosmart D7360 All-In-One InkJet Printer
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in the box never used? I have several PCs and I'd like them all to have the capability to print using wireless. Can you help?
  • HP Master
  • 1,679 Answers
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Posted on Jul 03, 2010
Signal not strong enough can I boost it
The "Wireless / Advanced" configuration window contains a setting for transmit power. Be sure it is set to 100%.
Otherwise, your only options are to replace the antenna with a booster antenna, or to add a stronger wireless router as an access point to your current setup. Using a booster antenna requires the D-Link to have a removable antenna, which it may not have -- none of the documentation calls this out as a feature.
Keep in mind that if you are trying to use this router over excessive distances, boosting the router's own power will not necessarily improve your connection, because the broadcast power of the remote PCs is also a limiting factor.
Dec 02, 2010 | D-Link DSL-2640B Wireless 11/54Mbps ADSL2+...
Connect Sprint PCS Sierra Wireless Aircard 402 home network??
Yes, you need to get in the router settings and disable DHCP in LAN configuration. That should do it. Also enable the ICS for the Air card. (Right click on Sierra Wireless icon, properties, advanced, check the box next to Allow others networks user to connect through this computers internet connection)
Sep 24, 2009 | Cell Phones
Where do I locate wireless router settings SSID?I am trying to set up a wireless HP Photosmart C6380 All-In-One to connect to my new Macbook?
Go to your Router's "System Summary" and go to Home Network tab. Then click wireless settings. SSID = Network Name.
Jun 16, 2009 | 2wire 2700HG-B Router (2700HGB)
Two pcs running vista home edition wired to router ok. laptop wireless ok. advent pc running windows xp wireless cannot see belkin router but can see outher router in my area. router is a belkin N wireless...
Check the router settings, if the router is set to only use 802.11N wireless it won't pick up a computer that is using 802.11G or 802.11B wireless.
Good luck
Nov 14, 2008 | Belkin Computers & Internet
Linksys Adapter and 2wire router
  1. ensure that a wireless connection is created in control panel on the pc, it may not even be attempting to connect
  2. ensure that the router wireless is turned ON, it may have been turned off as a security measure when no wireless pcs were used
  3. The security settings on the adaptor may be set to the office network and locked
    wep password at home is different or not enabled, so the secured adaptor will not connect.
make any changes from a cable connected pc (no chance of data loss)
access the routers settings page and check the settings,
then ensure the adaptor rom if present is set to the same settings
Jul 16, 2008 | 2wire 2700HG-B Router (2700HGB)
Internet access problem with a Linksys 54g router
Try setting the default gateway on the laptop to the ip address of your ICS gateway machine. Some routers separate the wireless and LAN connections on different subnets.
Try comparing your laptops ip information with that of one of the working wired computers. You can do this by going to Start up to run and type cmd then click "ok"
At the black prompt screen type "ipconfig" without the "".
You want to compare the IP Address, Submet Mask, and Default Gateway.
If one has an ip of 192.168.1.* and the other has 192.168.0.* then the wireless and wired are on seperate networks.
If the subnet masks are something like 255.255.255.0 and 255.255.255.1 they are on seperate subnets. Both should be fixable by putting in the same default gateway.
For example if your ICS gateway is 192.168.1.1 then set that as the default gatway on the wireless laptop. This can be done by going to start >> Control Panel >> Network Connections then right click your wireless connection and goto properties then double click on the "Internet Protocol (tcp/ip)" option. This will list all of your ip information (if its static) if its dynamic (ip gotten from router) you can still click "Use the following DNS server address" and set preffered dns to the gateway ICS ip. Or click "Advanced" and click Add under Default Gateways and add the gateway ICS ip there.
Jun 20, 2008 | Computers & Internet
Question on setting up two computers
Yes, I have pretty much the same setup at home. Wired desktop and wireless laptop. On the back of your wireless router, there should be 4 or 5 wired connections which you can use. You will only have to use the setup disk on one computer. Basically, the setup disk is for the router, not the computers, it simply guides you through the router configuration process. You can also do this manually, the manual for the router will give those instructions as well.
Apr 07, 2008 | NetGear WGR614 Wireless Router
How to use this unit as a Access Point for an existing Wireless Home Network
set the second router through the web menus to a different ip address, cant have 2 devices on the same (default) 192.168.0.1 address, try 192.168.0.2 (example only) to stop data collisions
connect by cable secondary router lan port 1 to the primary router lan port 4 (any lan port to any lan port),
drag secondary router upstairs on its cable and install it wherever you want
set two routers on different channels.
set all wep settings on both routers the same.
set all pcs to 'auto channel' select
wireless adaptors in pcs will then select strongest signal at any point and transmit thru that router
Feb 15, 2008 | D-Link AirPlus DI-614+ Wireless Router
SETTING UP WIRELESS NETWORK AT HOME
Yes your computer based on your model number should be able to support a wireless router.
Now... you did not specify if this is or is not a second computer that is trying to access the router which is hooked up to another computer and modem. If you are trying to access it you will need a wireless nic adapter installed on the Dell. To access the router. Please comment on what the case may be in your situation.
Oct 10, 2007 | Dell Dim.9150 Pentium D 820 Dual...
HP Photosmart D7360 All-In-One InkJet Printer Logo
261 people viewed this question
Seeker5211
Seeker5211
