Question about E-Machines eMachines Desktop PC
Wont boot up
Emachines wont power up even though fans are working and led light is on in motherboard. Isnt power supply, or graphic card. blinking light from hard drive doesnt work either
  • 63 Answers
Try to change your RAM,if same also
try to change your graphic card if u use it...
happy trying..
good luck..
Posted on Apr 17, 2008
Boot up
did you put the 4pin power in the board and 24 pin in then check the cpu fan in the right place make sure that all plugs are in the right place as well put in video card
Jun 10, 2013 | EliteGroup ECS A740GM-M Motherboard -...
Installed a Graphics Card on my Emachine. Made sure it is in the PCIX slot correctly and seated right. I also installed a Power adapter cable (20 PIN - 24 PIN ATX) to utilize the other 4 pins for use with...
Sounds like there isnt enough power even with the adapters your powersupply cannot give you enough sustained power to run the system if you take the card out does it boot normally? even just disconnecting the power to the card?
Mar 26, 2011 | E-Machines W6409 (7234) PC Desktop
Blank sreen.Fan is working. LED indicator is lighted but blinking rapidly.
Try a different monitor. If the second monitor doesn't work disconnect the power and then re-seat the video card. Also, check the RAMs - make sure they're seated as well. Start-up the computer and verify that the hard drive LED is blinking randomly - if it is, more than likely the computer is working properly. Your monitor could be bad as well as the video card. If the VGA port is on the motherboard, then you have an on board graphics card instead of a video card. In that case, the motherboard is bad.
Nov 19, 2010 | E-Machines eMachines Desktop PC
Emachines w3507 power
detarch all accessories or hardware connected to the system , then bring out the power pack itself out completely look for a soldering led to test the functionality of the power pack itself if it rotates the fan of its pack by looping the first hole to the third hole cable in the power pack connector that will head into the motherboard. therefore, check the mother board if there is any damage on it like some component if all this is false . then plug the power pack to the outlet and fix the connector of the power pack to the motherboard after detaching both cd drive , floopy disk drive leaving the hard disk and the memory . then change the memory card and press on the system there should be a solution from all this . the problem should be from the Memory not to be able to start up the system but go through those process i have given you before concluding it was the memory ok....
kindly rate this solution......
May 05, 2010 | E-Machines Bestec ATX-300-12E Rev. D 300w...
No post case is open i see da fan is working there is a little led that is red that blinks the card is a 3870x2 ddr 4 version from power color my power supply is a 880watt and it works well
Take all but one stick of ram out of your computer and try to boot the system. Usually when your mobo wont post and your video card flashes red you have a bad ram module.
Mar 01, 2010 | ATI Computers & Internet
My comp wont boot up
Try reinstalling the OS, I hope this will resolve this issue.
Aug 02, 2009 | Computers & Internet
Emachine 3240 possible power problem?
I would suggest try to swap the power supply out with another known good power supply.
I've seen where even though the light on the motherboard is lit, it is not getting enough power to start the machine up, especially if you have a higher end video card connected to it.
Jul 09, 2009 | E-Machines eMachines Desktop PC
Won't boot
power supply isnt putting out enuf power
Apr 25, 2009 | Intel Motherboard
MOTHERBOARDS
Is it the fan of your mainboard & processor is running when u turn the power on?.. If no.. check the power supply.. it may be damage.. If yes.. try reconnect the RAM.. or even the graphic card..
Sep 15, 2008 | Dell Computers & Internet
Emachines 1900+ gets power to the monitor and computer but wont boot
Buy a dianostics card, and find out if its the RAM, CPU, OR Motherboard. (sounds like a ram or CPU problem though) if you have more than one stick of ram in the system, take one out, and power it up, if still not response, to the other stick out, and put the stick you took out the first time, and put it back in.
Aug 03, 2006 | E-Machines eMachines Refurbished EMA...
E-Machines eMachines Desktop PC Logo
234 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
