Question about Microsoft Xbox 360 Console
I have the same problem: Sound but no picture! I tried to disassembly my xbox and try to clen it a bit, and turn it on again but nothing happened. (Careful! if you disassembly your xbox, the garanti doesn't cover anylonger.) And after i tried to push Y, Lefttrigger at the same time while the xbox starts! and nothing happen.. Should i try the towel trick ? Could it sowel the sound but no picture problem?
  • Microsoft Master
  • 4,806 Answers
Don't try the towel trick!!!! It will damage the Xbox even more.
The problem is caused by a bad design flaw in the heat sinks X-clamps. when the motherboard warms up it pulls the connections away from the GPU (graphics processing unit). This is your problem at the moment.
What you need to do is force the Xbot to overheat.
Get a couple of cue tips (cotton buds) and remove the cotton from each end and then bend them at one end making a large L shape.
Remove the AV lead, hard drive and any ethernet or wireless box from the Xbox and make sure its turned off.
Lay the Xbox on its side (flat) and look behind the Xbox where the air vents are. If you look close enough you will see two fans (you made a torch to see them correctly)
Insert a cue tip between the fan blades of both fans to stop them rotating.
Turn the Xbox on and leave it on for around 5-7 minutes watch the power button on the Xbox until you see just 2 red flashing lights. This means it has overheated.
When you see the 2 red lights remove power and leave the Xbox to cool down for about half an hour.
Connect the AV lead and all other things like the hard drive etc and power it up.
You should now have a working Xbox but there is a chance it will do it again. If it does you will need to modify the X-claps.
My recommendation to you is when you play the Xbox leave it layed on its side.
Good luck and regards.
Posted on Jul 03, 2010
No picture
I've had this happen to me a few times. Either cycle through your sources (until you get to the one for your xbox) or turn the TV off and turn it on again after 10-15 seconds.
Mar 25, 2010 | Microsoft Xbox 360 Console
38 '' RCA TV XBOX Model 36V550T, lost the picture
Does it only happen when you use your Xbox?
Try pulling the cable in and out between the TV and Xbox
Dec 05, 2009 | RCA 36V430T 36" TV
Console boots up, got sound but no picture
The Scaller chip on your xbox 360 went basically there is nothing you can do... This is going to sound really strange but the system is already toasted wrap it with a towel and let it over heat the chips again this is a temporary solution but it does work... Under no circumstances would i tell you to continue to do it but if your just trying to finish a game you might aswell, Either way you are going to have to get another one....
Apr 20, 2009 | Microsoft UNO for Xbox Live Arcade Full...
X box 360 powers up but no sound or picture
Well this is just a sign that the RROD error is going to happen.
If your system is still under warrantee and you have not tampered with the warrantee sticker than I recommend that you just send this system to microsoft and they shoud do the repair for free but if you would like to know how to fix it yourself keep reading:
The way to fix this is to first reflow the solder on the motherboard by using a heat gun then you will also have to preform the X-Clamp fix Here are the tutorials for both things you have to do:
How to Disassemble Your 360: http://xbox-experts.com/e/tutorial.php?n=disassemble
Reflow: http://xbox-experts.com/e/tutorial.php?n=heatgunisol
X-Clamp: http://xbox-experts.com/e/tutorial.php?n=xclampeng
Apr 02, 2009 | Microsoft Xbox 360 Console
My xbox 360 has no sound and now no picture when it is turned on
check the brightness on your tv..or u cud have the wrong PAL settings..i sort of had the same problem but it was the settings on the console..
Feb 16, 2009 | Microsoft Xbox 360 Console
I have a game stuck in my xbox360.
open your tray aand if it doesnt open hit it but not to hard
Dec 30, 2008 | Microsoft Xbox 360 Console
PS3 picture ans sound
make shur the cords arnt lose
Jul 28, 2008 | Sony Playstation 3 (PS3) Console
Sound with no picture
Have you looked at the side of the cable and made sure that the switch is set correctly? you have to select either HDTV of AV I believe. If that isn't the problem, try hooking it up through a different input on your television. I don't think it's your xbox because with any hardware failure, you would get the RRoD (red ring of death). I would definitely troubleshoot the TV. Try to hook up a regular DVD player in the input that your xbox is in and see if it works.
Jan 29, 2008 | Microsoft Xbox 360 Console
Xbox 360
Try turning the xbox on and pressing the TV/Video button on the tv or remote a few times and see if the picture comes up.
Sep 15, 2007 | Microsoft Xbox 360 Console
Sound But No Picture
This Just happened to me. There seems to be a lot of solder issues with the 360. I bit the bullet and tried the towel trick, where you over heat the 360 for about 20 min. I Let it cool for 20 more min, and it now works fine, I have a inner cooler now to keep from overheating again.
Jul 31, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
198 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
