Question about Hayward SAND FILTER, PRO SERIES
How much sand to i put in my Hayward Sand Filter?
  • 760 Answers
It depends on the model of filter you have. You didn't indicate what model you have. Here is a link to a manual from Hayward. If your model is not in this manual, then look further on this site as they have all models available. http://www.haywardnet.com/products/manuals/pdfs/Manual145.pdf
Posted on Jul 04, 2010
  • 8,404 Answers
About 300 lbs ... check with your pool supply when you purchase your sand to be sure.
4 Suggested Answers
SOURCE: how do i change the sand in the hayward e1001542s
we have changed the sand in our filter but now we cant get the back wash to work we have a davey tagelus 230 i need a diagraham to show how to put the muliti flow value on again
Posted on Oct 31, 2008
  • 19 Answers
SOURCE: How to change sand in Hayward S-200 Sand filter
hayward S-180 filter takes 150lbs, S-210 takes 200lbs not familur with the S-200. To change sand you have to remove the vari flow valve on top. You can either unplumb the filter and roll it over on its side and try washing the sand out or try scooping it out upright. Whatever you do dont damage the laterals on the bottom of the filter. When refilling with sand you want to make sure all the laterals are undamaged and in the down position. I always fill the filter half full of water to keep the sand from damaging the laterals while re-filling the filter with sand. Make sure you use pool filter sand and not play sand!
Posted on Apr 30, 2009
SOURCE: My new Hayward Pool Sand Filter won't backwash.
Hey!
Mine was doing the same thing. I had the hoses switched up. I had the hose from the pump connected to the port marked RETURN (on the Hayward vari pump valve). Not good! I also had the return line hose (from pool) connected to the port marked pump. It happens! The problem is I tried EVERYTHING ELSE before I found my error. This includes a trip to Leslie's to buy a brand new multi port valve (good thing they have a return policy) AND changing out my relatively new sand in the filter AND taking apart the vertical tube and each individual flange at the bottom to clean them out. Please check your hoses FIRST if it won't backwash! By the way...I've been a pool owner for 17 years. I think my experience worked against me since I didn't recheck my work at setup.
NOTE:
It might SEEM like your filter is working because you get suction at the skimmer and water rushing thru the return line into the pool. It's not working if your lines are backwards like mine were! My water started turning green!
Posted on Jun 22, 2013
How to change the sand in a sand filter
remove multiport shop vac the sand out when replacing sand make sure pipe is on bottom and if you have the adapter so no sand will get in pipe also it keeps pipe straight fill with new sand if you dont have that put something in pipe and keep in center of hole when filled take rag out and put multiport back on tighten down put in filter position the n start up
Jul 04, 2014 | Hayward SAND FILTER, PRO SERIES
How much sand do you add to a Hayward Sand filter S-21OT
200 pounds of sand make sure you use pool filter sand make sure not to get sand in pipe
Jun 27, 2014 | Hayward SAND FILTER, PRO SERIES
Changing sand in sand filter
remove multiport shop vac sand out then cover vertical tube and center then add sand see label for amount then add sand and put back together
May 24, 2014 | Hayward SAND FILTER, PRO SERIES
How do you replace the sand in the Hayward 714.
remove the multiport then shop vac sand out when putting back in don't get sand in tube
May 26, 2013 | Hayward SAND FILTER, PRO SERIES
How do I change the sand in my hayward pro series 244t sand filter and how much sand do I put back in?
remove multiport shop vac sand out look at label on filter for sand quantity
May 12, 2012 | Hayward Pool & Spa
Pool filter problem
You have a problem ...
Can you see the little tube that bleeds air out of the return pipe? If not ... see if you can find it and get it to the top of the filter.
Still have sand? You may have a cracked lateral ... remove the sand and check all the laterals. Replace any that are broken.
When you refill the sand ... be sure to put water in first to soften the beating the laterals take from the falling sand.
Jun 14, 2010 | Hayward SAND FILTER, PRO SERIES
I need to change the lateral holder assembly and bottom screen on a Hayward S-200 sand filter. Will I need to remove the variflow valve or will it just come right out?
You will need to remove multiport valve and remove all the sand with a scoop. Not alot of fun. Think about replacing sand with ZeoBrite filter medium when you put it back together
Aug 02, 2009 | Hayward SAND FILTER, PRO SERIES
Replaced sand now filter isnt working
if u used play sand, or any other type of sand thats NOT pool filter sand, that could be the problem. also if there is too much sand or too little sand that could also cause this.
Jun 08, 2009 | Hayward Pro Series 18" Above Ground Pool...
Hayward SAND FILTER, PRO SERIES Logo
339 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
