Question about John Deere Two Safety Warning Lights For All Tractors
Warning light is orange with a horizontal line half way up. Above the line is a spray type patern and below is a downward pointing arrow. What does it mean?
1996 saturn dashboard light with arrow pointing downwards possibly battery or radiator image next to arrow?
CHECK COOLANT LEVEL IN COOLANT EXPANSION TANK.SOUND LIKE LOW COOLANT WARNING LIGHT.
Jan 23, 2011 | Saturn SL1 Cars & Trucks
A warning light came on that is a box with a notch on top with an arrow pointing down and a squiggly line near the bottom of the box. Does this indicate some type of low fluid?
that i believe is the low radiator fluid. there is a little black box attached to the radiator just below the fill neck, maybe it got unplugged also.
Aug 10, 2010 | 1997 Pontiac Grand Am
I have a warning light on my car that looks like a wave and an arrow pointing downward. What does that mean? I have a 2000 Saturn SL1.
That is your low coolant level light. Add antifreeze/water mixture to the overflow resevoir
May 12, 2010 | 2000 Saturn SL
SEAT TOLEDO WARNING LIGHTS
Could be the motor-management-warning light, but I guess it's the break-warning light. There might be too little breaking-fluid left in the lines ... A boardcomputer-readout should clarify this.
Otherwise, try parking on an ascending road with the nose pointing up, hit the hand-break and wait like 2 minutes; the light should come on. You might wanna retry it with the car's nose pointing downwards as well ... If so, definitely the breaking-fluid, otherwise probably not ;)
In any case - flashing warning light are never ok, so when you see it again and you're sure it's not just the ABS/ESP warning light, go and have your boardcomputer read-out, since it should contain useful errorcodes ..
Feb 07, 2009 | Volkswagen Passat Cars & Trucks
Trouble light indicator, don't know significance
Hi... thanks for suggesting some kind of assistance at my cost.. but i know it's a simple answer, i just don't have the manual, otherwise i wouldn't of asked. So, i'll ask a mechanic friend next time i'm out and about.
Nov 24, 2008 | 2004 Saturn L-Series
Warning light on my 1997 Monte Carlo
register for yahoo.com if you don't have a user name there. Then go to chevy.com ( you have to have a yahoo id name to log into the chevy site) Then register your car make and model. Once you have done that you can look at your cars owner's manual and it will tell you what each light is on the insturment panel and from there hopefully you can determine what is wrong.
Oct 23, 2008 | 1997 Chevrolet Monte Carlo
John Deere Two Safety Warning Lights For All  Tractors Logo
29 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
