Question about Vizio L32 32 in. LCD HDTV
Have a blue vertical line that goes from the bottom of the picture up about 12" and about 3/16" wide. Located 12" in from the right side of picture that won't disappear.
  • 201 Answers
If you still have line when you change your inputs and if it affects the menu most likely the lcd panel is bad and will need replacement. If not under warranty the panel will cost more than the tv did.
Posted on Jul 04, 2010
My Samsung PS50A410 plasma TV has developed two vertical lines down the right side, one at 60 mm and the other at 350mm. Both are approx. 20mm wide with an indistinct picture behind.
vertical lines as apposed to horizontal indicate bad lowerr connections in the ribbon cables inside the TV at the bottom sometimes they can be fixed but most times your panel is failed
Feb 12, 2018 | Samsung Televison & Video
How do I remove three vertical colored lines from my Television. One vertical line is green another is red and the final one is blue.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
May 24, 2015 | Panasonic Viera Tc-p50u50 Hd Plasma Full...
We have a vertical green line on the right side of our screen. We can get rid of it by moving the picture over but then it is off center.
any verticle bar which is blue, red green about an inch wide can be fixed by replacing a control board in the set. Board number 6871QCH038C. Can be ordered through Parts Store.com for about 112.00....easy to install yourself, located behind two larger boards which are ribboned together. Takes about an hour.
Jun 29, 2009 | LG 42PC1DA 42 in. Plasma HDTV
LG RU-42PX11 42 plasma TV has black bar
The screen does not work properly .Ribbon wire fails.
Mar 31, 2009 | LG 42PX5D 42 in. Plasma HDTV
VIZIO P42hd PS42a plasma Picture has two vertical lines (one red/orange, one blue) going down the right-hand side of the screen. Lines are clearly visible
The panel is almost certainly bad. The only fix for this is to replace the whole panel which would cost more than the whole TV.
Mar 30, 2009 | Televison & Video
Blue vertical lines
Yes...your light engine/optical block is shot... 1500 dollars.
Jan 25, 2008 | Sony Grand WEGA KDF-50WE655 50" Rear...
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Bowing in the middle like an hour glass
OUCH!!!! Don't kick me...would be my response if I were your TV
Convergence amps problem.
If it works after a kick I'd say poor solder joints on the convergence amp leads
Dec 17, 2006 | Zenith IQB50M90W 50" Rear Projection...
Vizio L32 32 in. LCD HDTV Logo
89 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
