When the problem started, the picture was fine, I played a DVD, then when I went back to T.V. the color was all messed up All of a sudden I can't get true color, at first there was no green color and plenty of blue. Now there is green, but no blue. Of the four controls, Video, Audio, Setup, and Feature, it won't go to Setup. In the beginning of the problem I did find "tone", now I can't. I assume it's in Setup.
  • 3 more comments
  • cashelton Apr 17, 2008
    It's a NS-32LCD Insignia
    It's a separate DVD/VCR
    Insignia NS-32LCD Insignia
    I don't find PRECH from Menu,
    I've been gone. I just plugged my NS-32LCD Insignia back in and there's no change
  • 13,433 Answers
Does the dvd side still work ok? it might be a problem in the receaver. If all other inputs work ok expt the tv by the way which input is the tv useing?
then its most likely a problem in the receaver.
Posted on Apr 17, 2008
    Genius:
  • 1,142 Answers
May i please know the model and the make of the product in details so that it can help me resolving the issue is a more prompt manner
  • 1 more comment
  • Maanita Chadha
    Maanita Chadha Apr 17, 2008
    You will need 2 new convergence ICs STK392-110 also the 1.8 ohm
    resistor and the pico fuse usually burn with that model. the ICs are
    located on the small board located behind the speaker grille and access
    panel in front. Easy repair go to the following link and you can get
    replacement ICs and any other part you need. And they provide
    installation instructions as well as free on line instant meassaging
    for all customers when they do thier actual repair. Heres the link.
    http://servicemanuals.vstore.ca/
  • Maanita Chadha
    How to access the service menu in this tv: push MENU on the remote
    control, then push PRECH 5 times, now push 1 to 8 to access various
    service menus-1 has horizontial size and position, 2 has vertical size
    and position, others have red push etc. IMPORTANT-write down your
    initial values before you make any changes
  • Maanita Chadha
    Do a power cycle unplug all the power cables leave it turned off for an hour and then turn it back on. let me know the status.
Dp32746 Sanyo Picture is messed up?
try to play a DVD on your TV to determine if the problem is on TV or signal..
If the DVD plays same image you have bad t-con board,.,just replace it to fix the problem..
Aug 25, 2012 | Sanyo DP32746 32 in. LCD Television
DVD not showing a clear picture
test test test 17:05
danke bitte
do not answer test test
sorry
Jul 04, 2009 | Televison & Video
Vhs SP tapes
It sounds like the tapes may be physically damaged, wrinkled or creased. This may have been done when they were played in whatever machine you used 5 years ago. Tapes can also be damaged in storage by heat or humidity. Tapes should also be stored on end in their boxes, not flat. If these tapes were stored flat, the bottom edge might have gotten wrinkled. This can damage the control track and cause playback issues.
May 09, 2009 | Sony SLV-D380P DVD Player/VCR
DVDs on my Sony SLV-D350P DVD/VHS player play in black and white
First try a good quality dvd cleaner. If that does not cure the problem then the video cable may have went bad. I had a system that the cables were never touched & after a few years it needed replaced in order to get my picture back. Hope this helps & please take a moment to rate my answer. Thanks.
Feb 08, 2009 | Sony SLV-D350P DVD Player/VCR
Dvd only playing in black and white
Make sure that you connect all of these connections to the right colored cables.
It seems like you only have the green cable connected. Go back and connect the red and blue for both the tv and dvd.
Aug 06, 2008 | Sony DVP-S500D DVD Player
Pretty colors
Sounds like the other DVD player went bonkers. Try unplugging power on the DVD player you were playing the game on for 5 minutes, then plug it back in.
Apr 02, 2008 | Sony DAV-FC8 System
Picture rolls
Same as sherpi here, player was fine, and all of sudden started rolling and never stops. Rolls with or without a disc in it...seems to play the discs fine, but never quits rolling.
Mar 08, 2008 | Spectroniq PD-1100 DVD Player
DVD no picture but sound ok lg v8824w
hi there, had same problem, try turning on the player then holding the stop button on the remote for five seconds.this should restore the video picture
Jan 19, 2008 | Televison & Video
Screen flicker, color swirls
Mine does the same has done since new, It was sent back and when returned it still does the same. If i tap the top of the screen it comes right again for about 10 miniuts
Jan 22, 2007 | Neovo F-417 17" LCD Monitor
Televison & Video Logo
46 people viewed this question
Top Televison & Video Experts
