Question about E-Machines eMachines Monitor E15T4
I need instructions on how to connect the memory card from my camera to the e-machine and how to project the pictures on the screen.
    Brigadier General:
  • 10,406 Answers
Take the memory-card to any computer-store, and get them to sell you an adapter which has a USB connector on one end, and a slot on the other end that matches your memory-card.
Insert your memory-card into the slot, and the USB connector into a USB port on your computer, and then open "My Computer" -- you should see a drive-letter for a "removable" device, namely the interface to your memory-card.
Posted on Jul 03, 2010
When i turn on my camera it says the memory card needs formatting i follow the instructions but it doesnt work and keeps saying to format the memory card. this happens over and over and i cannot take...
To understand the photo loss situation, consider a scenario: You format a memory card in Digital Camera, and start to capture some pictures. However, while capturing pictures, your camera shuts down due to low battery. Now, after recharging battery, when you try to access those photograph on the card, you receive the following error message on camera screen:
The Card requires formatting: Additionally, the camera is unable to capture any new photographs.
The main cause for the above error message is corruption of memory card due to conking of battery while a read/write operation was running.
These memory card needs to be formatted before you save any new pictures. It is always a good practice to take backup of card and format it before use. This enables you to fight with any damage done to the memory card and to erase the old data saved on the card. However, the probability of card getting corrupted again (after you have saved new data) still exists.
First try formating with an external SD Card reader connected at PC and test it.
Oct 13, 2011 | Kodak EasyShare C143 Digital Camera
Getting an internal memory full message on my kodak easyshare c143 camera but it only has 9 pictures on it?
The internal memory is very small. You need to be saving the pictures to a memory card instead. However, Kodak cameras have this nasty habit....once you save a picture to its internal memory, it won't save to a memory card. To make your card work, remove it from the camera...go into the camera menu and find "format"....follow the on-screen instructions to erase the internal memory....insert your card and it should work properly.
Apr 11, 2011 | Cameras
"Memory full" displays on screen.
You still need to get rid of the pics on the internal memory. With no card in the camera, go into the menu and find "format" and follow the on screen instructions to erase the internal memory. Then, insert your card and it should work properly.
Feb 12, 2011 | Nikon Coolpix L1 Digital Camera
Cannot download all of pictures onto pc.
First of all, you should forget about using the internal memory...it just causes problems (as you can readily see). Always use a memory card. If any of the pics on your camera are important, you should download them to your computer before continuing. Then, go into the menu and find "reset"...follow the on-screen instructions. Then, with the card out of the camera, go into the menu and find "format"...follow the on-screen instructions. Then insert a blank memory card and go into the menu and find "format" again...follow the on-screen instructions. From this point on, your life will be wonderful.
Feb 02, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Pictures will not goto memory card. They only store to camera, therefore i can only take about 5-6 pictures?
Are the pictures stored in the memory important? Then go into the menu , scroll to "copy" and follow the instructions for copying from internal memory to card. Then, remove your card, bring up a picture from the internal memory and push the delete button...choose to delete all. Then, download any pics on your memory card to your computer using a card reader. Then, insert your card back into the camera, go into the menu, scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Nov 29, 2009 | Panasonic Lumix DMC-TZ2 Digital Camera
Every time i take a picture on my camera it says memory full insert a Sd memory card to transfer and take more photos i havent took any pictures and i inserted a SD memory card
Try this...go into the menu and scroll to "reset"...follow the on-screen instructions. Then, without a card in the camera, go into the menu and scroll to "format"...follow the on-screen instructions. Then if the pics on your memory card are safely on your computer (use a card reader to do this if necessary) insert the card into the camera, go into the menu and scroll to "format" and follow the on-screen instructions. After all this, you should be ok.
Nov 22, 2009 | Vivitar ViviCam 8025 Digital Camera
When I turn the camera on I get the message "memory card error". The only button on the camera which then works is the menu button but it just brings up the screen and then the same error message. Yes, I...
You need to format the card in the camera. Go into the menu and scroll to "format" and follow the on-screen instructions. This will erase and initialize the card . To download pictures, the most trouble-free way is to use a card reader and download to a folder you create on your desktop.
Nov 14, 2009 | Pentax Optio S4i Digital Camera
Kodak easy share C813, the display is over saturated
Using exposure compensation to adjust picture brightness Before you take a picture, you can adjust exposure compensation to make pictures darker or lighter.
The exposure compensation level is shown on the LCD; the LCD gets brighter or dimmer.
OR
You need to upgrade the firmware.
Download this file to your pc and follow the instructions:
Firmware Download
Installation Instructions IMPORTANT: Print this page before continuing.
Prepare your Camera CAUTION: Loss of power during the firmware upgrade can render your camera inoperable.
  1. Connect the optional KODAK AC Adapter, or install a new or fully charged battery in the camera.
  2. If you have pictures on the internal memory of your camera or on a memory card, save the pictures to your computer.
Download and Extract the Firmware File
  1. Download the file to your computer.
  2. Double-click the file to start the WinZip Self-Extractor.
  3. Select Unzip to folder, and specify a location, or leave the default location.
  4. Click Unzip. The firmware file unzips to the specified folder.
  5. Note the location of the folder. The file has a .fw file extension.
  6. Close the WinZip Self-Extractor.
Select a Method
  • If you do not have a memory card and card reader, use Method 1.
  • If you have a memory card and a card reader, use Method 1 or Method 2.
Method 1
  1. Visit the EASYSHARE Software Web page at www.kodak.com/go/easysharesw, and download the latest version of software.NOTE: EASYSHARE Software version 6.x or later must be used during this procedure.
  2. Remove the memory card from the camera.
  3. Turn on the camera.
  4. Format the internal memory of the camera:
    1. Press the menu button.
    2. Select Setup.
    3. Select Format.
    4. Select Internal Memory.
    5. Press OK.
    6. Press OK to continue.
  5. Connect the camera to your computer using a USB cable.NOTE:The first time you connect your camera to your computer, Sync andTransfer Setup or Sync and Transfer Assistant prompts appear on thescreen. Follow the prompts to set up the camera as a device in thesoftware.
  6. Start EASYSHARE Software.
  7. Select Tools > Sync and Transfer Manager.
  8. Select your device from the list in the left column, and then select the Info tab.
  9. Click Update Firmware, and go to the location where you downloaded the firmware file.
  10. Click Open to copy the file from your computer to the internal memory on the camera.
  11. Turn off the camera, and then disconnect the USB cable from the camera.
  12. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes. When it is complete, the camera will delete the firmware file from internal memory.
  13. Turn off the camera, and then turn it back on again.
Method 2
  1. Remove the files from the memory card.
  2. Place the memory card in the card reader.
  3. Open the drive corresponding to the memory card to view the card contents.
  4. Check that a System folder exists on the memory card. If not, create one.
  5. Locate the firmware file on your computer and copy it into the System folder on the memory card.
  6. Remove the memory card from the card reader, and insert the memory card into the camera.
  7. Turn off the camera.
  8. Turn on the camera and follow the on-screen instructions to complete the upgrade. The upgrade takes approximately two minutes.
  9. Turn off the camera, and then turn it back on again.
Sep 10, 2009 | Kodak Easyshare C813 Digital Camera
I can't take a picture with the camera. What's wrong?
The batteries may be low. If you see the low battery icon, recharge or replace the batteries or use the optional AC adapter. The flash may be recharging. Wait until the status light turns green, and try again. The camera may be full. Check the picture counter on the display panel. Erase some pictures, or transfer the pictures to your computer and then erase them. Make sure your CompactFlash memory card is installed. You may need to format your CompactFlash memory card. Check to see if a message is displayed on the camera's LCD screen. The camera may be connected to your computer. When it's connected, you can't use any of the controls on the camera itself. See your user's manual for instructions on taking pictures from your computer.
Sep 12, 2005 | Epson PhotoPC 3000Z Digital Camera
E-Machines eMachines Monitor E15T4 Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
