Question about Philips 9P6444C 64" Rear Projection Television
My tv is a 64 inch phillips we turn it on and there is no picture.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 72 Answers
Late model transistors have "low" resistance between B & E, typically ~53 ohms. You can check this out by going to the NTE web sitemy tv is a 64 inch phillips we turn it on and - mag-glass_10x10.gif, input the transistor pt nbr, they will show an NTE replacement. At the end of the line, they will have a jpg or pdf diagram of the transistor. I think you will find that 2SD2359 has an internal resistor from b-e and a diode from e-c.
Posted on Jul 03, 2010
Why doesn't it turn on?
Probably the failing power supply finally failed completely.
Mar 07, 2016 | Samsung Pn64d8000 64-inch 1080p 600hz 3d...
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
My Phillips Magnavox 64 inch tv has a green tint to it. what can i do about it and how much will it cost and where can i have it done at?
Your fluid, known as Ethylene Glycol needs replaced in the picture tubes. Normally just the green and blue need done. This is what keeps the face of the tubes cool and after time just like your anti freeze in your car it breaks down and needs replaced. It turns what we call "beer brown". At Philips, we were charging $279.00 to do this. Today, places are charging anywhere from 200-300.
Nov 26, 2010 | Philips Magnavox 9P6034C 60" Rear...
Picture problem
This is a common problem with this TV set. You can get the parts, chips, and instructions to fix it your self from www.TvRepairKits.com
Aug 09, 2009 | Philips Magnavox 51MP392H Rear Projection...
Power light for tv turns on but no picture and no sound comes on tv i have a 50 inch phillips plasma
Check your cables and TV input settings.  Can you get to the on screen menu?  Does anything appear on the screen when the tv is on?
Dec 06, 2008 | Televison & Video
Horizontal lines on top of phillips tv
bad feedback electrolytic in vertical circuit. need tech.
Nov 23, 2008 | Philips TP2797B 27" TV
Sound but no picture 60in phillips television
I beleive you can get a chip to fix this problem from www.magnavoxhelp.com.
Aug 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
2005 phillips crt 27 inch tv
need electrolytic capacitor replaced in vertical circuit
May 07, 2008 | Televison & Video
Phillip tv
Probably bad inverter board. It has a short in inverter board and as soon as it powers up it detects the excessive current draw and shuts the set back off. Open it up, unplug the power supply connections to the inverter board then try to turn it on, if you get a green light then the inverter is bad. Try E-bay for replacement board.
Apr 16, 2008 | Philips 26MD255V 26 in. LCD TV/DVD Combo
Philips 9P6444C 64" Rear Projection Television Logo
115 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
