Question about TurboChef C3 Single Oven
Turbo chef is not heating up, coming up on it reads, f8 low heat
    Problem Solver:
  • 14 Answers
The problem with f8 like you have said LOW HEAT
, IF the oven does not warm up in time , which is usually 8 min , it goes into f8 fault code
now please check the hi limit button , on the back of the oven , left hand side, bottom corner, if it reset and starts heating, please check bottom element and temp reading IR , IF it rises very quickly and the elemnt is glowing red , please switch off the unit at the power point , you have problem with the solid state relay, if the temp is slowly rising , then you might only have an issue with the hi limit reset button thermostat, FIRST JUST CHECK THE RESET BUTTON
Posted on Jul 30, 2010
My Chef Classic Wall mounted fan forced oven stopped working. Its grill section working. Fan and the light in the oven working well. Bot oven doesnot heat up. Please give a tip what is probably wrong?
The bake element has gone bad. They can visually look fine but still be bad. To check and replace that element you will unfortunately need to kill the power and remove it from the wall. Remove the back cover. Check for a low resistance (around 16 ohms) across the bake element. If the resistance is high the element is bad. Google the make and model for a replacement element.
Dec 26, 2014 | Magic Chef Ovens
Oven element does not heat up
Ok
1) does the clock come on
2) do the surface burners come on
if you have the clock (so power is getting in, but you can't get any thing to heat up.
You will need to test the outlet it is plugged into. You should be reading 110 from both the left and right sides of the outlet (totaling 220 ac) if you only get it from one side then the problem is in the wiring, and causing the stove to try and run on half the current it needs.
Oct 18, 2014 | Magic Chef 9815 Electric Single Oven
My Subway Turbo Chef is saying wr fail. I self tested and it came up okay, can't find this error message in manual
I have had an F8 error in the past. The wire connecting the top element had broken off. The reason why temperature is not getting up is becaise the top element is not working.
Apr 22, 2012 | TurboChef Ovens
Turbo chef oven heats up too high and not ready
Bad SSR relay. Thermostat is for safety so it tripped first time, however since it's mechanical thermostat( not so accurate ) it didn't tripped on time for next time when it overheat
Jan 31, 2012 | TurboChef TORNADO Electric Oven
Oven not heating
If your oven is gas, like it says up top, then your ignitor is bad...
Check out this tip...
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Heatman101
Mar 07, 2010 | Magic Chef 9122 Gas Single Oven
I have a magic chef range/oven. For the last few months, it has taken longer and longer for the oven to heat up to temp. Now it won't get more than 90 degrees or so. What is the problem??
Turn off the power to the range. Remove the bake element from inside the oven. Be careful not to let the wires go back into the oven cavity. Take a volt/ohm meter set for ohms or continuity and test the bake element leads. If you get no reading replace the element. If you do get a reading,replace the temperature sensor in the oven.
Oct 08, 2009 | Magic Chef Ovens
OVER HEATING
Hello. If the SSR is closed, and the oven is off, then the SSR is bad. You can call turbo chef for a part supplier,if you are able to replace it yourself, at 1800 90turbo.
Dec 16, 2008 | TurboChef TORNADO Electric Oven
Magic Chef oven won't heat up past 200 degrees
You obviously have one or more elements not working, you need to test same, and replace as req'd.
Dec 12, 2008 | Magic Chef Ovens
About my turbochef toster oven it has f8 low heat problem
there is a high limit reset button on the back of the oven .reach around left side if you are facing oven. if that is it but it trips again you have other issues. if that is not it you have other issues possibly k4 k5 ssr or element problems
Nov 15, 2008 | TurboChef TORNADO Electric Oven
TurboChef C3 Single Oven Logo
1,103 people viewed this question
Top TurboChef Ovens Experts
Dennis Boxerman
Craig Butler
Craig Butler
Are you a TurboChef Oven Expert? Answer questions, earn points and help others
