Question about Garden
Is it neccesary to tamp the crushed rock in a basement floor prior to pouring concrete?
    President:
  • 3,085 Answers
If you want a rough surface, do not tamp.
Posted on Jul 03, 2010
Is there a concrete floor sealant that eliminated moisture seeming through the concrete slab?
if you want to seal the surface a epoxy paint is good !
but if the water come from under the concrete slab only a hole with aggregates ( small rocks ) and a swamp pump works fine !
Oct 04, 2015 | Washing Machines
Sweating concrette floor what can I do to stop it from sweating
You have high humidity in your basement turn on a fan in the basement or dehumidifier
Jan 16, 2014 | Dupli-Color 20002100: Shield-Crete Epoxy...
Installing a bathtub on concrete floor
Other than chopping out more concrete.elevating the tub is probably your only other solution. I would think 2" would be adequate.
Hope this helps.
Bob
Feb 08, 2012 | Crane & Co Crane Plumbing 2430W Whirlpool...
How should you winterize a lawn tractor in the northeast?
I pour seafoam into gas tank & run it for a short time. Then I remove the battery & take it into the house & put it in the basement by the furnace on a piece of wood, do not put battery directly onto concrete floor, it will drain power, I have had the same battery for approx 7 years now.
Dec 11, 2010 | Craftsman Garden
Basement plumbing. I want to put in a basement bathroom and my plumbing drain from the house is 4' from the basement wall. I need to put in a sewer basket and venting. any diagrams to follow?
My suggestion is to build up the floor where the tub will be maybe 12" above original floor and u can make a couple steps up to the tub the whole length of tub
Dec 10, 2010 | Home
Our basement floor has been dug up including the floor drain. How do you go about replacing this. our contractor wants to put crushed rock for the water to drain into the drain and concrete over this.this...
He sounds about half right, but I would want to know if the water is in the basement all the time? or does it come through the slab? The walls? Is there any water? You don't need forms of any kind in a basement or patching a big hole, the hole is the form, fill it up and level it off. He might be concerned about a dry trap if there is one on the floor drain. Depends on where it drains to. Sewer? It is code now for floor drains to have trap primers on them so they stay full. No gas. Hope this helps.
Jul 02, 2010 | Plumbing
I've packed gravel and sand on the basement floor, the edges have been trimmed with 3'' foamboard, before I lay the entire floor with 3'' foamboard I am caught between using a vapor barrier between the...
I would use the vapor barrier Unless you plan on taping all the seams and using care to not open them during the pour the foam will not act as a vapor barrier. I feel vapor barrier is critical an code in some areas.
Apr 20, 2009 | Hardware & Accessories
Pouring concrete
I live in N.W. Wisconsin and they do pour cement in 20-30 degree weather. They have the concrete supplier mix with hot water and also add calcium chloride. The ground must be thawed with no frost in it. They pour the cement and if finish it and then cover it with tarp blankets. This does add cost to the project and if you can wait for warmer weather I highly recommend you do.
Hope this helps.
Bob
Feb 22, 2009 | Plumbing
Are concrete slabs suitable for a stable floor?
So long as you level the floor and put at least 2 inches of cushion sand down they should be fine. If you don't use the cushion sand, there will be too many variables as far as movement. The if you tamp the pavers down, sweep sand into the cracks, and lightly wash it off, the sand acts as mortar, keeping the pavers from moving too much. Because pavers aren't typically reinforced, they are only as strong as the underlay, or substrate, so make sure you do a good job prepping and they will be fine.
Nov 27, 2008 | Teac CD-P1250 CD Player
Garden Logo
278 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
