Question about Dryers
Want a building code for venting clothes dryer into basement in Colorado Springs Colorado
  • 487 Answers
Your local code enforcement officer can help
you with this simple question
Posted on Apr 18, 2008
Clothes aren't getting dry
Check your vent hose and where it exits the building, clean away all lint anything blocking the vent cap or in the vent hose. Remove the vent from the back of the dryer and make sure it is all clean and clear there and make sure the betn is not kinked up when putting the dryer back into it space. Now before you blow me off, if any of this is true for your dryer the heat will build up and trip the thermostat causing it not to heat properly and the blower wheel can not move the air to collect the moisture and remove it from inside the dryer. Also, any sagging vent line can collect moisture which turns to a puddle of water in the line and this to will not allow your dryer to dry the clothes. Good luck I hope I have helped you.
Mar 30, 2014 | LG Tromm Electric Dryer
I currently live in the midwest and today has been an extremely humid day (90 degrees+ and 84%+ humidity). I used our LG gas dryer (Model # DLG2241W) earlier this weekend and it worked fine. Tonight, when...
Water in the drum anytime after drying a load of clothes is not normal.
Was the load prior to you having found the condensation fully dried? If not, check for lint in the vent system and make sure that air is coming out of the vent (the flap or louvers on the vent cap should open fully on a short vent line). Even so, this would not account for a small amount of standing water in the drum.
The first thing that came to mind was outside air being drawn in through the vent. If you have air conditioning and a well-sealed house, the warm, moist air hitting the cool drum (in a relatively dry atmosphere) may cause condensation. Check the outside vent to ensure that the vent cap flap (or louvers) is (are) closing all the way. Convection or air flow from the basement to a vent fan in an upper level might cause this.
Please let me know if I can help further.
Jul 18, 2011 | LG Dryers
Lint is building up in the dryer vent outside and the dryer is heating up but not drying the clothes
you will need to clean out or replace the vent line as you clothes will not dry if there is a restriction in the line.
Oct 04, 2010 | Bosch Nexxt WTMC 6300 Electric Dryer
Dryer produces heat, but clothes don't dry
Sounds like the vent has a lint build up inside of it. A moister sensor detects any lint build up and keeps the heat in check. The dryer will produce very little heat this was. Clean the entire venting tubing and it shall run better for you
Jul 08, 2010 | Maytag Atlantis MDG6400AW Gas Dryer
Clothes do not dry completely on one cycle
Check your dryer vent (the entire length) for lint build-up. Check that the vent is opening properly (the flapper type can come loose and block air-flow).
Those are the most common reasons for an inefficient dryer.
I hope this helps.
(we have had the vent get blocked by the flapper)
Apr 03, 2010 | Whirlpool WED5300S Electric Dryer
I have a g e clothes dryer The top of the dryer
usually a clogged or obstructed vent hose or outside vent causes this. Also check inside the dryer (when cool) to see if there is lint building up inside, hindering air circulation.
Nov 02, 2009 | Frigidaire FEQ332E Electric Dryer
Do i need to vent my 3510 dryer
Maybe not. What did the manufacturer say about venting? Are you prepared for a house full of dust? What about all the extra moisture you will trap inside?
In the past, in the winter time, to conserve heat, I have vented my dryer to the inside through tripple thick nylon womens hose. I didn't save enough $ to offset the dust I got in my basement.
Another consideration: What does your local housing authority (building inspecctor) say?
If you ask me, I'd say vent.
Let me know what happens - Thanks
A
Sep 14, 2009 | Bosch Axxis WTA 3510 Electric Dryer
Water build up nin dryer vent
Hi, W/D here.
It would be best in your circumstance to slope your vent like one might slope a drain. 35 feet is waaaaay too long, 20 feet is max, and you can deduct 6 feet for every bend. If you can reconfigure your vent to a sloped drain, this will help.
The coolness of the basement is a contributing factor, but normally, it doesn't figure into the issue.
If you cannot shorten your run, or slope your line, you might do well with a trap that would have a mini sump pump in it. These are available from A/C companies, and are automatic in their operation. I have had one in one of my units, and the cost wasn't unreasonable. You can probably find one on-line (EBay?)
Venting into the basement may resolve your water issue, but you still have to deal with the lint that "escapes" the lint trap. Most of it will likely wind up in the air conditioner, and all over whatever you have in your basement.
A mini sump sounds like your best option, even if you have to set up a schedule to clean it out occasionally.
Best regards, --W/D--
Aug 12, 2009 | Maytag Dryers
Maytag stackable washer/dryer gives off a lot of moisture
you answered your own question, its not producing to much miosture, its not releasing hte moisture with in the clothihng, Id be willing to bet that you have a MAJOR clog within the venting!!!!!!
Mar 28, 2009 | Maytag Dryers
I have a lg dryer model dlg2532w gas dryer it does get warm
if the cloths are warm and wet the problem is not with the dryer but in the venting. check the air flow at the end of the line (where the exhaust leaves the building) if the air baffels are not fully opening when the drier is on there is probably an issue with the venting. remember to tape up the venting joints after inspecting it because it is also the exhaust for the gas. hope this helps.
Sep 25, 2007 | LG DLG5988 Gas Dryer
Dryers Logo
94 people viewed this question
Top Dryers Experts
