Question about Koolatron CocaCola Fridge Red Compact Refrigerator
Not working I got this Coca Colaunit from my sister and it worked great for a while. Then the temperature started to read abnormally high, so I unplugged the AC to reset it and it worked a gain. Then it started to read higher and higher, and a reset would not work. Now, finally when turned on the fan dosent come on and there is E2 on the display which I assume is some kind of error code. Any help is appreciated
Code h 4 in sharp photocopier model ar5520n
Description Heat roller low temperature detection
When the fusing temperature is lower than 150C° after 55sec from the start of warming up. When the warming up complete temperature is not reached in 30sec from reaching 150C°. When the fusing temperature is lower than 100C° after 20sec from ready start. When the fusing temperature is lower than 145C° when printing." Causes Thermistor abnormality Heater lamp abnormality Thermostat abnormality Control PWB abnormality
Aug 08, 2015 | Sharp MX-3610N Color Photocopy, Print &...
Code active, unplug coolant sensor dash gauge stops reading
What make vehicle ? some vehicles have two coolant sensors . One for temp. gauge an another one for the ECM / PCM input. Do you have a check engine light lit ?
A DTC will be set if an abnormal reading occurs, P0116 for sensor performance, P0117 low input or
P0118 for a high input. The coolant temperature sensor temperature reading should closely match the
air charge/manifold temperature reading on a scan tool if the engine has not been run for over an hour.
The sensor circuit can be checked for proper voltage using a voltmeter.
Jun 03, 2015 | Cars & Trucks
How to remove an error e000000-0001 for canon 4035i. I have tried to remove but I fail
Abnormally high temperature (detected by main thermistor)
The main thermistor detected an abnormally high temperature (240 deg C) during temperature control. - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB.
Mar 10, 2015 | Canon Office Equipment & Supplies
C449 error code in toshiba e studio 2540c
error C 449 Heater lamp abnormality after abnormality judgment (temperature abnormality at high temperature)
first of all just reset error with simulation may just malfunction error procedure for rest error for heater related.
turn copier off
hold down 0 & 8 while turning it on power switch
then press digit numbers 4 0 0 then press start key
then 0 key and set
Jul 26, 2014 | Toshiba e-Studio 2540C Multifunction Color...
Please how do I clear the H 4 display on my Sharp AL 2020 copier machine
Content
Detail
150C after 55sec from the start of warming
up.
not reached in 30sec from reaching 150C.
100C after 20sec from ready start.
145C when printing."
Cause
Check and remedy
Use SIM 5-02 to check the heater lamp blinking
operation.
When the lamp blinks normally.
Check the thermistor and its harness.
Check the thermistor input circuit on the control
PWB.
When the lamp does not light up.
Check for disconnection of the heater lamp and
the thermostat. Check the interlock switch.
Check the power PWB and the lamp control
circuit on the MCU PWB.
Use SIM 14 to clear the self diagnostic display.
Mar 06, 2013 | Office Equipment & Supplies
I have an System ERROR E001 following Error E808 on my canon 2016j copier and waht shal i do me out guys
E001 0000 Abnormally high temperature (detected by main thermistor)
E001 0001 Abnormally high temperature (detected by sub thermistor)
The sub thermistor detected an
abnormally high temperature (295 deg
E808 0000 Fixing drive circuit failure
- The heater does not turn on.
- A fixing drive motor failure was
detected.
- Replace the fixing drive motor.
- Replace the power supply PCB.
Feb 19, 2011 | Canon iR 2016i Black and White Copier
Canon ir 2016j
E003 0000 Abnormally low temperature (detected by main thermistor)
After the temperature detected by the
main thermistor has reached the
specified value, it does not reach the
specified value during initial rotation.
0001 Abnormally low temperature (detected by sub thermistor)
sub thermistor has reached the
Jan 09, 2010 | Minolta EP4000/5000 CS/PRO Copier
2001 pontiac aztec, temp guage shows (very) high) temp reading. I take the battery cable off, replace cable, then it appears normal. I have done this for 4 months, everything is OK. Now it no longer solves...
if you have high miles, 75k or more I would go ahead and have tempature sensor and thermostat it self change. I don't see battery cable would have any bearing to the temperature guage or cooling process. Both switch work almost the same, at time it work well other time it read or work incorrectly because it a sign of unit becoming faulty. If the temperature sensor is faulty half of the time it well give you incorrect reading however if the temp sensor working properly and the Thermostat is not, you will also get a high temp reading due to the Thermostat is not working properly allowing the hot antifreeze to flow out from the engine to the radiator which cause the hot antifreeze to be remain lock up in the engine block. Thermostat suppose to open and close when it reach its temperature; at the same time I would also replace thermostat switch which operate the cooling fan. all three tend to go bad over times; replacing all three is a great ideas. Thermostat, thermostat switch and temperature sensor.
Oct 21, 2009 | 2001 Pontiac Aztek
Error code C6020
Sounds like you have a faulty thermistor. (heat sensing device) The 6020 indicates an abnormally HIGH temperature. If the readings are greatly different in the two thermistiors or one is not touching the hot roller could also be the problem.
Jul 30, 2009 | Copystar Office Equipment & Supplies
Ford 2000 exped temerature indication reading about 4 deg high
reset the system pull the neg battery cable for 15 mins
Mar 07, 2009 | 2000 Ford Expedition
Koolatron CocaCola Fridge Red Compact Refrigerator Logo
Top Koolatron Refrigerators Experts
Ilia Bichin
richie46
Jerry Kramer
Jerry Kramer
Are you a Koolatron Refrigerator Expert? Answer questions, earn points and help others
