Question about Pelikan Pelican 2360 LED Flashlight
How do I check the LED lights on my Pelican 2360 Flashlight? My flashlight has stopped working. I have replaced batteries, correctly aligned them(+/-), there is no sign of corrosion or loose connections.
Replace batteries on flashlight
Maureen, Coleman Graphite Flashlight replace batteries. Remove bottom cap, it will be on tight, if you do not have good strength in your hands use a pair of pliers or channel locks. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to change the batteries in Mag Lite
Aug 26, 2016 | Coleman Graphite Flashlight
How to disassemble a zoom focus flashlight
Ultrafire/CREE XML XM-L T6 LED 1600LM Flashlight Torch ...
? 27:39
https://www.youtube.com/watch?v=lsPdC-xgxTU
Oct 15, 2013 - Uploaded by Richard Lloyd
Here is a link to this CREE XML XM-L T6 LED 1600LM flashlightat ... 1600LM Flashlight Torch Lumen Zoomable Review/Disassembly/Mod.
CREE Flashlight - How to Fix Frequent Problems - YouTube
? 8:04
https://www.youtube.com/watch?v=zJpQAvum0bM
Dec 21, 2010 - Uploaded by motorbiking
How to repair your flashlight if the LED stops working, if it changes mo... ... Mini Cree Led Q5 Ultrafire Flashlight Torch Adjustable Focus Zoom ...
Disassemble HausBell CREE Flashlight (replace battery ...
Jan 19, 2016 | Cameras
Our flashlight stop working even with a brand new battery
The bulb may be blown. If the bulb is ok then you may have a broken wire, corroded connections or a bad switch.
Jul 20, 2014 | Eveready 6V Super Heavy Duty Lantern...
Won't work after changing batteries
If the flashlight was working properly before you changed batteries, it's most likely that some tolerance is off by just a smidge so that you're not getting quite the right contact to close the circuit. You can make a thin wafer out of aluminum foil that's folded over and over onto itself and use that as a shim to increase pressure on the battery cartridge. That may be all you need.
If there is a switch on this light, as opposed to a simple screw on/screw off pressure connection, I would try checking continuity in the switch to make sure that is working correctly. Many manufacturers cut corners on the fit and construction of their flashlight swtiches, so a part can go out of alignment quickly and easily, causing failure of the switch until you can nudge those parts back in line.
Nov 25, 2012 | Leatherman Led Lenser L7 Flashlight
Pelican 7060 flashlight manual
FlashMax G179 - Waterproof CREE LED Flashlight
Adding the particular FlashMax G179 water-proof, powerful DIRECTED Flashlight. This kind of torchlight will be one thing to seriously acquire anxious about. It really is really potent. Remarkably resilient. Water-proof. And also makes use of Cree LED's, and that means you realize you'll get white colored mild together with decades regarding program using this attentively developed Flashmax DIRECTED Flashlight.
Apr 17, 2012 | Pelican 7060 LED
What kinds of a flashlight the brightest?
Check out this WEB site for super bright LED flashlights.
http://www.nextag.com/super-bright-led-flashlight/stores-html
Nov 28, 2011 | Camping, Backpacking & Hiking
LED Flashlight Battery Drain Problem
This particular flashlight uses a microchip that consumes the power of the batteries, whether in use or not. Loosen the case to where the batteries go in, so there is no contact with polarity. Or just take the batteries out completely and replace them for actual use.
GGBMDB
Apr 05, 2009 | Stinger Streamlight 75000
Pelican 4300
Send it back to Pelican. They have a lifetime warranty and are one of the few companies that actually stand behind their products.
Nov 30, 2008 | Pelikan Pelican 4300 Nemo Flashlight
Pelikan Pelican 2360 LED Flashlight Logo
87 people viewed this question
Top Pelikan Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Pelikan Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
