Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
How do i switch my contacts between the phone and memory card?
My screen has gone blank, i can make calls by individually typing in the numbers. But i have bought a new phone because of this but need to get the numbers to my sim card. So i need it button by button, thanks if you can help.
Ditto - anyone got the sequence?
Posted on Apr 21, 2008
How do I unblock a number?
Go into contacts look for his name , edit his info screen the top right look For 3 dots right hand side a drop down list should appear say unblock. Another way choose phone or contacts you will see 3 dots and choose setting look for block numbers. This feature shows all contacts you have blocked whereas the contact screen do individual contacts..
Hope this helped , Happy New year!!!! ??
Jan 02, 2018 | Cell Phones
Saying memory full
first switch of your phone then press the star(*) three(3) and call button holding these button and switch on the screen displays blank white screen for sometimes and then on .
this method will format all datas in your phone memory,so be sure to backup your contact and messages in the phone memory to the memory card
Oct 26, 2010 | Nokia N97 mini Smartphone
I have a General Electric 27956FE1 1.9 GHz 1-Line Cordless Phone. The screen has gone blank. It doesn't respond to any buttons. Any ideas?
i just called the support number about this. if the screen has gone blank it means all pictures even the default sample pictures have been deleted from the phone. put a memory card with pictures in the phone, unplug the phone to reset, plug it back in and you should be able to get pictures off of the memory card
Jun 10, 2010 | General Electric 27956FE1 Cordless Phone
My HP, Nokia N70 Music Edition,now the screen is blank, the number can't to receive a call n can't to call anywhere...plz help me
Hi
perform this steps below..
1.remove memory card..(take phone book backup either in to MMC or any other sim)
2.Now type this code *#7370#
enter security code default is 12345
It will reset to factory settings..
3.Now insert MMC if this issue still persists format memory card also.
4.Still if this issue is there contact service center they will format User Area using UFS3 software.
Regards,
Suraj.
Feb 18, 2009 | Nokia N70 Cellular Phone
My Nokia N70 cell phone Screen is white blank
formating your phone may fix the problem
Here’s how to hard reset or format your Nokia N70 mobile phone:
1) Switch off your phone
2) Press and hold these 3 keys together:
-green dial key
-the star key(*)
-the number 3 key (Ugh, I wish I had three hands…!!)
3) Power on the phone
Warning: Do not release the keys until you see a formatting screen and even after the phone has started. Wait until the initial sound starts to play and the hand animation is displayed.
Before formating make sure that your battery is fully charged. Copy all your important contacts, messages, calender, etc in your memory card and your phone should be fully charged window.google_render_ad();
Oct 21, 2008 | Nokia N70 Cellular Phone
Fon screen faded and went off itself
dnt use local memory cards.its the 100% virus problem..first u hv to format ur memory card and then format ur mobile with jaf .dnt use bluetooth to receive data from other mobiles.reply post
Sep 27, 2008 | Nokia N70 Cellular Phone
How to delete phone memory from a nokia 6070
Hi-
To delete all the contacts and the details attached to them from the phone or SIM card memory, select Menu >
Contacts > Delete all contacts > From phone mem. or From SIM card. Confirm with the security code.
To delete a contact, search for the desired contact, and select Options > Delete contact.
To delete a number, text item, or an image attached to the contact, search for the contact, and select Details.
Scroll to the desired detail, and select Options > Delete > Delete number, Delete detail, or Delete image.
Deleting an image from contacts does not delete it from Gallery.
Pls rate as fixya if it helps, THANKS!
Jun 30, 2008 | Nokia 6630 Cellular Phone
Sony ericsson k800i blank screen need to transfer numbers from phone memory to sim card
Thats a cool phone, pity its screen is broken.... Here is my suggestion
  • If you got keypad lock then unlock the phone
  • Go to menu usually by pressing the top right key...
  • Press 8, which should take you to contacts
  • Press the top right key which would take you to More
  • Press up using the joystick, this should highlight Options
  • Then press the middle of joystick, which would take you into options
  • Press up using the joystick again, this should highlight Advanced
  • Press 5 to backup the contacts to memory card or press 8 to back up your contacts to SIM
Check the memory card or Sim on another phone...
May 10, 2008 | Sony Ericsson K800i Cellular Phone
Sony ericsson W700i
most of the SE phone have two types of contact saving
1- in phone memory
2- in SIM card memory
if u have contacts saved in SIM memory but u r using
phonebook memory then it is default
if u save any contact in phone memory u have an option too
to copy it to SIM memory
for deleting a contact it will behave like this:
for example, u have a contact saved in phone memory
as well as in SIM memory
if u delete this contact, then it will be deleted from phone
memory but not from SIM memory
and when u are called from same number
(which is not present in Phone memory but is in SIM)
it displays the name again
Jan 17, 2008 | Cell Phones
Display Issue
format once before that u back up the phone memory in memory card ... And to format switch off the phone and again switch on the phone simultaneously pressing the dial key ,* and 3 ... u'l get a black screen called formatting ...
Dec 03, 2007 | Nokia 7610
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
23 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
