Question about Ryobi Three Trimmer Combo
Ratio for oil and gas on a ryobio weedeater
I have a ryobio weedeater, i have forgot the ratio of oil to gas
My Ryobi 725r (multi attachment) requires a 32:1 fuel oil ratio. The owners manual calls for a 4oz bottle of oil per gallon of unleaded fuel. I had been buying other brands for my oil but recently found out that they are only 3.2oz of oil. Ran my weedeater for at least two years with that mix and have not had any problems with it. I would say it's best to use the manufacturers specs though.
Posted on Aug 03, 2010
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 183 Answers
If you are using stihl oil the ratio is 50:1
Posted on Jul 29, 2010
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
Jan 01, 2015 | Weedeater Garden
What is gas to oil mix ratio on weedeater string trimmer
The ratio is 40:1 Just add 3.2 ounces of 2 cycle oil to one gallon of fuel. Be sure to cap off the tank and shake to distribute the oil throughout the fuel before adding to weed eater.
Sep 19, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Need gas to oil ratio Toro weedeater Modle 51950A
Hi lcauchon...
Use a 50:1 ratio 1 pint 2 cycle oil to 6 gallons of gasoline..
Please take time to rate me
Sep 23, 2011 | Garden
How do you know whether to use 50:1 or 40:1 gas/oil ratio mix in a 2 cycle engine ?
should be written in the manual and on the lid if not i always run 40 to 1 better safe than sorry to much oil ratio can foul a plug running to light on oil can blow the motor
Nov 07, 2010 | Weedeater Featherlite Blower 18 Cc 150 Mph...
What is the correct gas/oil mix for a john deere weedeater?
4 oz generic 2-cycle oil to a gallon of fuel for a 32:1 ratio. It using JD Exact oil the ratio is 50:1 using 2.6 oz of JD Exact oil.
I hope this helps you.
Jun 17, 2010 | Garden
Need to know the gas:oil ratio for weedeater FL1500
100 ml of 2cycle oil to 4000 ml of fuel..Which is 40/1 ratio
100 ml of 2cycle oil to 5000 ml of fuel.. which is 50/1 ratio
4 o/z is 118.29411875006815 ml to 1 gallon of fuel (3.79 litres or 3790 ml) Which means 32/1 ratio...I find that to confusing,so it is easier to say 100 ml of oil to 3200 ml of fuel ===32/1.
Oct 27, 2009 | Poulan Featherlite Gas Blower, with Low...
What is the oil/gas ratio for a Ryobi RY30550 weedeater? 50:1? Thanks
50:1 is too high. That is normally for a chainsaw which is much more severe duty. Normally for a weed whip its 25:1. They usually say on the gas cap but if not 25:1 is a good ratio that never fails (have done commercial landscaping for years) I use this ratio if I don't have a guide from the manufactor of the weed whip..
Aug 30, 2009 | Garden
What is the gas to oil mixture ratio for a GTI15 weedeater?
40:1 is the recommended ratio by the company that made the weedeater. But it has been my experience that 32:1 allows the engine to last longer.
Jun 24, 2009 | Garden
How much 2 cycle oil do i add to one gallon of gas in a fl20 poulan weedeater?
usually it is a 40:1 ratio . the ratio should be printed on gas cap for one gallon 40:1 would be about 3 oz.
Jun 23, 2009 | Measuring Tools & Sensors
Gas to oil ratio
this mixture for this weedeater is 40:1 or 40 to 1
Hope this helps You
please rate me
Jul 19, 2008 | Electrical Supplies
Ryobi Three Trimmer Combo  Logo
709 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
