Question about Electrolux EIED55H Dryer
New electrolux EWGD65HTS dryer posts fault code E71 following "install mode". gas and electric installed corrrectly.
  • 23 Answers
If this unit is new do not try and fix yourself. if your break anything it will void your warrenty. call electrolux they have great service companys and if they can trouble shot it with you they will overnight the parts to your house and set up service for you. electrolux is a great company and will help you get your dryer fixxed as fast as they can
Posted on Jul 03, 2010
What do i do when my fridgidair electric dryer displays error code e68
Good Afternoon Friend, this is Z. Thank you for your post!
If you are getting an error code E68 on your Frigidaire dryer, it usually indicates that one of the keys (buttons) is stuck closed (active). Let's try entering a "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing after proper diagnosis. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps!
May 22, 2014 | Electrolux Dryers
E60 Error Code on converted 60Hz outlet
E60- Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Unplug your washer for 1 hour and then plug it back.See if this reset helps.
Aug 06, 2008 | AEG L74800 Front Load Washer
Tip
Choosing a dryer.Gas or Electric
A gas dryer saves electricity cost, but requires an installed gas line to the home and special installation. If gas is available for a dryer, the outlay for a gas dryer model may be a good option if your dryer usage is high. An electric dryer costs less, but requires installation and energy costs for a dryer varies with usage. Both types of dryers require proper venting to the outside. Always follow the dryer manufacturer's installation recommendations.
on Aug 17, 2010 | Refrigerators
Electrolux Dryer quit and has a code E 63
Mark, the heating element is underneath the drum, on the left (as facing the front of the unit).
Per the Dryer Tech Data Sheet:
E63 Error Code indicates: [Fault] Heater to Earth Ground [Possible Fault Conditions] Heating element or wiring defective [Possible Solutions] Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest.
To open the cabinet is quite difficult, speaking as a non-professional. There may be easier methods than what I used, but I was successful. First I removed all the screws from the back (there are many). This got the top and the back panels removed. The left side (where I could see the heating element was) gave me considerable trouble until I realized I had to remove the door trim to reveal one last screw. Finally got the side off and swapped out the heater. Much much vacuuming for me. I am still trying to figure out how to clean out the bottom of the duct (underneath lint filter), but that's another post.
Also, just in case you don't have the manual and/or need to order parts, I will include a link.
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Dryer-Parts/model-EIED55HIW0/1412/0151200
For some reason, the Sears Parts Direct website lists the dryer as a Gas dryer, which it obviously isn't, as the part in question is very clearly an electric heating element. Hope this helps.
-Nick
Mar 03, 2014 | Electrolux EIED55H Dryer
Can't get electrolux dryer to perform an installation cycle
Could you please describe the problem you are having a little better?
Dec 02, 2012 | Electrolux EIMED55I Electric Dryer
How do I access the fault codes on an electrolux 1200
I see many posts about Error Codes that aren't in the user manual. Here's what I found: Go to Google and type in "Electrolux Error Codes" and you will find the following site. It details an Electrolux Service Flash that helps with error codes that don't appear in your user manual. Good Hunting!
Customer Error Codes On All Digital Display Frontload Washers - [ Terjemahkan laman ini ]Electrolux Service Flash LN071 02.13.07. NOTE. These customererror codes are not included in the error code chart on the technical data sheet located ...
www.applianceblog.com/...electrolux/886d1212672468-frigidaire-front-load-washer-doesnt-start-frigidaireerrorcodesonalldigitaldisplayfrontloadwasher...
Sep 16, 2012 | Electrolux EW1200i Front Load Washer /...
Electrolux Gas Dryer: E66 error
Should the heater wire have electrical continuity to the housing
Mar 08, 2012 | Electrolux EIED55H Dryer
Hi, My Electrolux Double door refrigator has typical problem and no Mechanic is able to rectify it so far. One of the Technicial told that compressed has gone and he has replaced the new compressor. In...
You have done the extreme service in replacing the compressor and still the complaint is lurking. I think the fault is not identified.The gas pressure and the new compressor pressure being order , you must see if the thermostat is working corrrect, the auto defrost is doing the timed action so that the friddge is working to the efficiency. Unless each of these are checked with the evaluation a correct fault cannot be determined than to suspect.
Aug 30, 2010 | Electrolux Icon 22.6 cu. ft. Counter-Depth...
Electrolux dryer error code e61
There is a 'tech sheet' in the back pf the dryer. Unplug machine, Remove the access panel on the back to get to it. Reach in and it should be there. It will tell you how to do a button check. You have to enter a test mode through the buttons.
The E 61 is a stuck button.
Enter function test mode and perform key
stuck closed (active). (button) test to determine which button is at
fault. Carefully free the and perform the test
again. If button is free but the key struck code
still exists, replace electronic control.
Sep 25, 2009 | Electrolux EIED55H Dryer
Electrolux EIED55H Dryer Logo
459 people viewed this question
Top Electrolux Dryers Experts
John Tripp
John Tripp
John
Are you an Electrolux Dryer Expert? Answer questions, earn points and help others
