Question about Marshall Mg15dfx 15-Watt Combo Guitar Amplifier
Can hear sound only with earphones - Marshall Mg15dfx 15-Watt Combo Guitar Amplifier
  • Marshall Master
  • 5,603 Answers
Either the speaker is blown OR more likely, the switch on the headphone jack fails to connect the speaker when headphones are unplugged. The contact gets bent causing the problem.
Posted on Jul 04, 2010
I have everything set up and then when I plug in my phone and play the music no sound will come out, just a humming noise.
Check that you DO have signal from the phone..
Some smart phones 'autodetect' an earphone and won't drive a signal wire.. So use a two way 'splitter' in the signal lead from the phone to monitor maybe..
Mar 02, 2015 | Music
My Roland FP8 plays very quietly through its own speakers, through an external amp & speaker and through the earphones. There is a hissing/crackling/static sound too from the speakers. Anyone
A number if things can be wrong with it, from the audil preamp to the the audio amplifier. Even as simple as a bad volume control. Does the actual noise change patterns when you move the volume?
Jan 03, 2015 | Roland Music
I can hear only one side of the sound coming out from Korg triton extream keyboard. It's not the cable problem for sure. i tested both the earphone out put and the Left and right out put. Did a
So you're saying with headphones you also only hear one side? I would suspect the internal amp is panned all to one side. There are also several other settings in this unit where pan can be set so you may have to check several areas. If you don't have any specific custom settings made I would try a restore to factory defaults. If that doesn't resolve it you likely have a hardware failure which is likely not repairable. I strongly suspect a panning issue though.
Aug 18, 2012 | Korg Music
No sound
may be a problem with it try contacting the manufacture nd see what they say
May 10, 2012 | Korg MA-30 Ultra Compact Digital Metronome...
What caused my wurlitzer model no. 625 to stop playing after removing the ear phone plug I had inserted? I get electric static when turned on so I know it's getting electricity.
Well if the removing the earphone plug and the unit no longer working aren't a co-incidence? Then perhaps the earphone socket has faulted and cut off the speakers, output. You see in an earphone socket there is an additional set of contacts, that makes & breaks the line to the speaker and routes it to the earphones, often these contacts will stay open, after the plug is withdrawn. and thus stop any output from going to the speakers. Or sometimes the solder join on the PCB can break and the effect is the same.
The only way to tell is to examine the unit and check this out. As mooted before though, i do wonder if this isn't a co-incidence, and the fault is to do with something else, often these units fail in the area of the output amplifier IC's. The unit really needs to be put through the troubleshooting procedures to exactly tell. If one was to attempt a DIY, then at the least one would need to obtain a service manual, for these steps and to obtain the parts numbers to buy any spare parts.
http://www.jukeboxparts.com/new_page_4.htm
Above is a place to assist you with a service manual, should you wish to DIY? However, Wurlitzer's are a complex device, and my professional recommendation is to get a "Quote" for any prospective repairs, from a Wurlitzer repairer.
Jul 25, 2011 | Music
I bought a factory refurbished xga-3000 gemini amplifier and conected it to my behringer mixer expecting a thump. but it barely sounded like a sound of earphone at maximum volume. I read power supply to...
A large amp like this likely has protection circuit (probably a relay) that doesn't connect the speakers until the amp is stable and balanced. You relly need the schematics for the amp.
Jun 21, 2011 | Gemini Sound Products GEMINI XGA 3000 3000...
Hello, I connect my headphones to the Alesis DM6. As result, i can listen my drumming, while i'm playing. But, the sound is not always good. Sometimes I hear, only on one side the music, or it is...
you have a bad cable (wire) or a bad jack (where you plug in your earphones) plug your output into another device (guitar amp for example) and see if the problem persists. if it does then it is most likely internal problems with the output jack. If this is the case you will have to take the unit apart to find out where the problem is. if you're not comfortable doing this then you will have to take the unit to someone who is.
Mar 17, 2011 | Alesis DM6 Performance Electronic Drumset...
Berhinger acx 1000, power on, no sound amp not working, everything lights up on display but no sound or amplification
Just had the baby brother (ACX450) with this problem...opened the amp... screws from sides and or top (including 2 hidden under handle covers).
The power cable from the power transformer had come off the connector on the circuit board in spite of goo they had put on it. Put connector back on and secured the cable and works perfect,
Since your display lights, yours is likely a different problem. I have also seen similar ones that the cable to the speaker had been pulled off its connection on the circuit board, rendering no sound. See if you have sound at headphone jack. and if none, how about the preamp output jack? Note you will only hear the left side using earphones as these jacks are monaural.
Feb 06, 2011 | Behringer Ultracoustic Acx900 Acoustic...
I have a Wurlitzer Funmaker Organ Model 445 Super Sprite Syntha Solo with an earphone jack under the right corner of the organ keybed. I have lost the original earphones and can't find one to fit into the...
There are only a few sizes of jacks that are likely size in these units.
1/4. 1/8, and 5/32 plugs.
Radio Shack has adapters between almost any sizes.
I do not have one of these units and documentation searches come up empty.
Sep 10, 2010 | Music
I have a CVP-96. when any key is presses and released it makes an audable bump sound when it returns. The return thumps actually intrude on soft music. Silenced with earphones the noise can be heard across...
There is OFTEN a felt strip that the keys come up against at the lip of the case, either near the end of the keys or right where they disappear near their middle. SOMETIMES this strip gets knocked off.
Jan 03, 2010 | Yamaha Full-Size Keyboard
Marshall Mg15dfx 15-Watt Combo Guitar Amplifier Logo
147 people viewed this question
Top Marshall Music Experts
Michial Gueffroy
matt martin
matt martin
Leonard Jeffrey
Level 1 Expert
Are you a Marshall Music Expert? Answer questions, earn points and help others
