Question about NetGear DG834G Router
How to change default gateway - NetGear DG834G Router
    Sniper:
  • 126 Answers
I accept with Mr.Govinda for his comment on Ip details, moreover i was used to a site called, http://www.ip-details.com/ it was very useful and it is very cheap, i think for your further queries please you can have a look on it
Posted on Aug 17, 2010
  • 2,260 Answers
Default gateway is the IP address of the router.
Connect the computer to the router.
Open the setup page of the router using the current default gateway number.
On the setup page of tghe router, you will see the router local IP address.
You will find the current IP address of the router there.
If you want to change the default gateway, you can change the router Local IP address.
Make sure that it will be a private IP address only and not the public IP address.
suppose the current default gateway is 192.168.1.1.
You can change it to 192.168.x.y. X and Y will be the number between 0 to 254.
Click Here for more information about the routers and network
Posted on Jul 03, 2010
Not able to change the default gateway. It just takes what ever the IP address is
Are you using DHCP to obtain the IP address? If so, typically the gateway will be automatically assigned, and if the DHCP server does not have a gateway programmed in the printer will default to it's own address. Change the IP setup to manual and you will be able to put in any address you want for the gateway.
Jul 12, 2011 | HP LaserJet 4250n Printer
I am unable to access my blitzz bwp611 router. I have tried 192.168.1.254 and 192.168.0.1 to no avail. How can I gain access to this router?
The router should be accessible from the Default Gateway IP Address of your network. Examples I have found are like this:
http://portforward.com/english/routers/port_forwarding/Blitzz/BWA611/Command_and_Conquer_Red_Alert_Counterstrike.htm
you can check you default gateway by opening a command window (Start CMD, right click CMD on the Menu for Vista/7, Start, run cmd for XP) on the command line type IPCONFIG
This will give you your IP address, Subnet Mask and Default Gateway IP address. Type the Default Gateway IP address in to you address line of the browser, you should get a sign in prompt. Unless you changed the default settings, the username and password should be left blank. That should give you access.
Jul 10, 2011 | Blitzz Technology (BWP712) 802.11g/b...
Hi,how do i suppose to get connected on my acer pad?
use the default gateway ip in your web browser. you usually have to accompany that with a user name and password. the default gateway is usually 192.168.1.1...but can change from vendor to vendor. do an ipconfig on your computer and that should tell you your default gateway.
May 09, 2011 | Acer Computers & Internet
How do i lock my internet connection so others can't use my connection
Hi onlyforu48,
I see that you want to put Security on your Network Connection.
1. First we need to find out what Default Gateway your Router has, this depends on what Router you have. To find your Default Gateway we need to click on Start then click All Programs, Accessories, Command Prompt, this will show you a black window with a blinking cursor.
2. In Command Prompt type in IPCONFIG then press enter, this should should pull up information showing your IP Address/Subnet Mask/Default Gateway, we need the Default Gateway info only it should look like an IP Address ex. 192.168.2.1
3. Once we have your Routers Default Gateway we will need to open Internet Explorer or any browser that you my have on your computer, type in the Default Gateway on the Address bar then press ENTER, this should prompt you for a user name and password. If you have changed your Routers user name and password please use the User Name and Password that you have created if you haven't changed any thing on your Routers user name and password then you can try admin for the User Name and password for the password or admin and sometimes you can just leave it blank.
4. Once inside the Routers settings page look for wireless then under wireless look for security this should give you the option to create a Network Key in your router, make sure your write down your network key on a piece of paper incase you may forget.
I Hope this will help regarding your Router security question, have a nice day.
Apr 03, 2011 | Computers & Internet
Hi, could you help me connect to default gateway when setting up a router. I tried connecting to http://192.168.2.1 but doesn't work. thanks.
Hello! Try to configure your network card`s IP address to 192.168.2.x (x = 2-255) and make sure the router is reseted to its defaults. To do this go to Control Panel > Network and Sharing > Change adapter settings and then right click on your network card > Properties, highlight IPv4 and click Properties. You just need to enter the IP and the Subnet Mask. After you`re done configuring the router change everything back to defaults.
Mar 13, 2011 | Computers & Internet
Wii will not connect to internet
Try to change the router channel number. Nintendo suggests to put it on ch 7 or 11. You can do this from a computer that is connected to the internet through the same router. Open up a browser an in the address bar type in your default gateway to login into your router and change the options. Each router is different and might have different default gateways. For example Netgear routers usually have the default gateway 198.168.1.1 but others will be different. You can find your default gateway by:
WinXp
1.Click start
2.Click run
3.type cmd - enter
4.type ipconfig - and it will display your info.
Win7
1.Click start
2. type cmd in the search bar and when you see cmd.exe click it once (usually the top find)
3.then type ipconfig - and it will display you info
After you find your default gateway number type it into your browsers address bar, no www or http needed. Just type it as it is.
Each router's configuration page is different so I would suggest that you consult your manual on how to change the wifi channel, or broadcast channel, or even radio channel. All of those sould be terms that are used. Hope this helped.
Feb 04, 2011 | Nintendo Wii Console
My wii sucks and wont connect to our internet
WinXp
1.Click start
2.Click run
3.type cmd - enter
Win7
1.Click start
How to change dns
I am not familiar with Edimax, personally...however, you can find out a lot of information by understanding a bit about the computer attached to it.
Assumptions:
It's a home network
You are running a Windows machine
Your windows machine is connected to the Edimax router
Your Edimax router is also your default gateway
drop to a command prompt (start, run, CMD, enter)
Type ipconfig and hit enter
This will get you your IP address of your local machine as well as the subnet mask and the default gateway.
Once you have the default gateway, you can connect to it via Internet Explorer. You will need to set it up as http://192.168.1.1 (where the IP address is your default gateway)
At that point, you will need your router password
Once you get in, you can then poke through your settings and manually change the ones you need.
Hope this helps.
Nov 11, 2008 | Edimax Computers & Internet
Changing default gateway
how are you connecting to the router?
Is it by the serial cable or network cable ?
Sep 23, 2008 | Cisco 2501 Router
NetGear DG834G Router Logo
1,435 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
